[mpich-discuss] Execute in two machine
Jayesh Krishna jayesh at mcs.anl.gov
Thu Jun 7 09:43:35 CDT 2012
 The "-machinefile" option allows specifying a machine file (you can create a text file using notepad containing the ipaddresses of each node in a separate line) containing the information about nodes where your MPI processes would be launched.
 You have two options with respect to your executable,
1. Copy the executable to the same location (e.g. "c:\mpitest") on all the nodes
OR
2. Share the directory containing the executable and use the "-map" option of mpiexec so that each process can map the shared drive.
 As mentioned before "Windows developers guide" contains a lot of information related to your questions.
Jayesh
----- Original Message -----
From: "Sinta Kartika Maharani" <sintakm114080010 at gmail.com>
To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
Sent: Wednesday, June 6, 2012 10:58:47 PM
Subject: Re: [mpich-discuss] Execute in two machine
Hi. I have set all the nodes with the same windows username and
password. But, I still confuse how to use commang "-machinefile"
Whether each node must have the executable file? Or simply just on one
node and then shared to all nodes?
Thanks
2012/6/4 Jayesh Krishna <jayesh at mcs.anl.gov>:
> Hi,
>  You need to have the same Windows username (with the same password) available on all the nodes in your cluster (the two machines in your email). I would recommend using the "-machinefile" option (see the Windows developers guide for details - http://www.mcs.anl.gov/research/projects/mpich2/documentation/index.php?s=docs) to specify the list of hosts to execute your job.
> Regards,
> Jayesh
> To: mpich-discuss at mcs.anl.gov
> Sent: Sunday, June 3, 2012 1:30:35 AM
> Subject: [mpich-discuss] Execute in two machine
> Hai, I have two machine with same specification, Windows 7 Ultimate 32
> bit, RAM 2GB. The ones have processor Intel Pentium Dual CPU T2330
> @1.6GHZ and the others Intel Core Duo T2450 @2GHZ . The name of the
> machine : sinta-pc\sinta and kartika-pc\cs-7
> I want to execute a program in both machine, what's the command?
> Because when I try (in kartika-pc) with command "mpiexec -host
> sinta-pc hellompi.exe", appear warning "credentials for CS-7 rejected
> connecting to sinta-pc; aborting L unable to connect to sinta-pc"
> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
