[mpich-discuss] mpich2-1.4.1p1 - Installation
Rajeev Thakur thakur at mcs.anl.gov
Mon Feb 27 18:44:45 CST 2012
The machinefile should be in the directory from where you are running the mpiexec command, or you can give the full path to the machinefile. You need to be able to ssh from one machine to the other.
On Feb 27, 2012, at 5:05 PM, Bernardo Augusto García Loaiza wrote:
> My machine file content is
> sistemas.eafit.edu.co:4
> slave-1:2
> slave-2:2
> Thanks for your help, Best Regards again.
> Ingeniero de Sistemas
> Estudiante de Maestría en Ingeniería Informática - Universidad EAFIT
> http://about.me/bgarcial
> 2012/2/27 Bernardo Augusto García Loaiza <botibagl at gmail.com>
> Dear friends of Mathematics and Computer Science Division Argonne National Laboratory
> I am installing mpich2 for paralell procesing practice.
> I took the following guide http://www.mcs.anl.gov/research/projects/mpich2/documentation/files/mpich2-1.4.1-installguide.pdf
> In the page 5, you speak about of create a file named machinefile, wich content is the list of hosts in the cluster.
> This file must be created in any particular path? What is the location?
> I was installed mpich2 in tres hosts (one master and two workers), building the package file.
> When i enter the instruction mpiexec -n 3 -f machinefile /usr/local/mpich2-1.4.1p1/examples/cpi
> where:
> 	• The machinefile file is located in /root/ in all hosts in the cluster.
> 	• -n 3 make reference to the number of hosts in the cluster. It's correct? or -n 3 make reference to the cores in each host?
> The output of  mpiexec -n 3 -f machinefile /usr/local/mpich2-1.4.1p1/examples/cpi is :
> <Picture 10.png>
> When i enter the instruction mpiexec -n 6 -f machinefile /usr/local/mpich2-1.4.1p1/examples/cpi , the output is:
> <Picture 8.png>
> The system try setup connection through ssh with other hosts, but wait and fail.
> I appreciate your valuable help and collaboration.
> Best Regards
> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
