[mpich-discuss] MPICH not executing more than 1 process on Windows 7
Jayesh Krishna jayesh at mcs.anl.gov
Mon Feb 27 09:48:37 CST 2012
 Your problem seems to be with the MPICH2 installation. Please uninstall MPICH2 and re-install it using the steps mentioned in Section 9.4 (not 9.1) of the Installer's guide (http://www.mcs.anl.gov/research/projects/mpich2/documentation/index.php?s=docs).
Jayesh
----- Original Message -----
From: "Nicholas Goodman" <Nicholas.Goodman at Colorado.EDU>
Sent: Sunday, February 26, 2012 9:14:54 PM
Subject: [mpich-discuss] MPICH not executing more than 1 process on Windows 7
  I have just installed MPICH2 on my Windows 7 Professional (64-bit) laptop.  I am using the current stable, 32-bit MPICH2 installation and Microsoft Visual Studio 2010.  I have run into a problem running any MPI program with more than 1 process.  If I run either my own hello-world code or the cpi.exe example with "-n 1", the program completes successfully.  If I run an MPI program with "-n 2", it hangs and does not do anything unless I kill the program.  I have included the output of my console below (the #### lines are my comments about what's going on).  Do you have any suggestions?
#### Using -n 1, the program returns correctly
C:\Program Files (x86)\MPICH2\examples>mpiexec -machinefile hosts -n 1 -user AYBABTU\nick cpi.exe
Please specify an authentication passphrase for smpd:
Enter the number of intervals: (0 quits) 1
pi is approximately 3.2000000000000002, Error is 0.0584073464102071
wall clock time = 0.000041
Enter the number of intervals: (0 quits) 0
#### If -n 2 used, nothing happens:
C:\Program Files (x86)\MPICH2\examples>mpiexec -machinefile hosts -n 2 -user AYBABTU\nick cpi.exe
Please specify an authentication passphrase for smpd: Please specify an authentication passphrase for smpd:
#### If I <CTRL>-<C> the program (after 30 seconds), the following happens
mpiexec aborting job...
job aborted:
rank: node: exit code[: error message]
0: 127.0.0.1: 123: mpiexec aborting job
1: 127.0.0.1: 123
thanks,
  Nick
 Nick Goodman
 MS Candidate, Computer Science
 University of Colorado
mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
To manage subscription options or unsubscribe:
