[mpich-discuss] Persistent communications between 2 computers
Jayesh Krishna jayesh at mcs.anl.gov
Fri Sep 9 12:40:34 CDT 2011
 Can you explain what you are trying to do (in your code) ?
Jayesh
----- Original Message -----
From: "Thierry Roudier" <thierry.roudier at kiastek.com>
To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
Cc: mpich-discuss at mcs.anl.gov
Sent: Friday, September 9, 2011 12:10:31 PM
Subject: Re: [mpich-discuss] Persistent communications between 2 computers
Hi Jayesh
My answers below:
> # Which version of MPICH2 are you using (Use 1.4.1p1 - http://www.mcs.anl.gov/research/projects/mpich2/downloads/index.php?s=downloads)?
No I am using the 1.4 version
> Can you run cpi.exe (C:\Program Files\MPICH2\examples\cpi.exe) using mpiexec ?
Yes
> # How are you running your code (Copy-paste the mpiexec command) ?
mpiexec -hosts 2 192.168.1.11 192.168.1.12 teststart
> # Can you run your code on a single machine ?
Yes... by using the command mpiexec -n 2 teststart. There is no error.
> # ...to sock in the Windows Registry, the behavior of persistent communications is more stable ... Do you still get errors ?
I did more tests today, and the error does not depend of the channel
parameter, and only occurs on the first time I call the MPI_Waitall
method (for rank==0). To correct the problem, if the first MPI_Waitall
failed, I just call a second time the MPI_Waitall method.... to be sure
I am synchronized. And it works.
I did a second test: If I decompose the MPI_Startall and MPI_Waitall
calls in successive MPI_Start/MPI_Wait calls for each request, I don't
get the error... but a such sequence increases the time to exchange data
over the network.
I also noticed the error only occurs after a certain time... as if the
communication is blocked... and the MPI_Wait function reached a timeout.
If the communication is blocked, the sequence of the send/receive is
probably the cause. But I didn't try to exchange the order (Send,Recv)
in the requests table... just some thoughts.
Thierry
On 09/09/2011 6:10 PM, Jayesh Krishna wrote:
> Hi,
> # Can you run cpi.exe (C:\Program Files\MPICH2\examples\cpi.exe) using mpiexec ?
> Regards,
> Jayesh
> From: "Thierry Roudier"<thierry.roudier at kiastek.com>
> To: mpich-discuss at mcs.anl.gov
> Sent: Thursday, September 8, 2011 4:24:58 PM
> Thanks Darius for your reply.
> Unfortunately, what you suggested doesn't work. I still have the same
> error message. But as the error only occurs on some transactions, I
> avoid the crash by using MPI_Errhandler_set(..., MPI_ERRORS_RETURN). And
> I handle the error in my program.
> I also saw by setting the MPI parameter "channel" to sock in the Windows
> Registry, the behavior of persistent communications is more stable.
> -Thierry
> On 08/09/2011 5:25 PM, Darius Buntinas wrote:
>> The error message indicates that the second process was unable to look up the address of the other process.  Rather than using "localhost" use the actual address or name of the machine.  See if this helps.
>> -d
>> On Sep 8, 2011, at 1:46 AM, Thierry Roudier wrote:
>>> Hi all,
>>> I want to use persistent communications to exchange data (below is the code I use). It works well on a single computer (mpiexec -n 2 teststart). But if I want to distribute the code on 2 computers (Win7) by using the command line: mpiexec -hosts 2 localhost 192.168.1.12 teststart. Unfortunately it doesn't work, and I got the following message:
>>>> Fatal error in PMPI_Waitall: Other MPI error, error stack:
>>>> PMPI_Waitall(274)....................: MPI_Waitall(count=2, req_array=004208B0, status_array=00420880) failed
>>>> MPIR_Waitall_impl(121)...............:
>>>> MPIDI_CH3I_Progress(402).............:
>>>> MPID_nem_mpich2_blocking_recv(905)...:
>>>> MPID_nem_newtcp_module_poll(37)......:
>>>> MPID_nem_newtcp_module_connpoll(2669):
>>>> gen_cnting_fail_handler(1738)........: connect failed - The semaphore timeout period has expired.
>>>> (errno 121)
>>>> ****** Persistent Communications *****
>>>> Trials=             1
>>>> Reps/trial=      1000
>>>> Message Size   Bandwidth (bytes/sec)
>>>> MPID_nem_newtcp_module_connpoll(2655):
>>>> gen_read_fail_handler(1145)..........: read from socket failed - Le nom rÚseau spÚcifiÚ nÆest plus disponible.
>>> And below is the code I use.
>>> Thanks a lot for your help.
>>> -Thierry
>>>> #include<mpi.h>
>>>> #include<stdio.h>
>>>> /* Modify these to change timing scenario */
>>>> #define TRIALS          1
>>>> #define STEPS           1
>>>> #define MAX_MSGSIZE     1048576    /* 2^STEPS */
>>>> #define REPS            1000
>>>> #define MAXPOINTS       10000
>>>> int    numtasks, rank, tag=999, n, i, j, k, this, msgsizes[MAXPOINTS];
>>>> double  mbytes, tbytes, results[MAXPOINTS], ttime, t1, t2;
>>>> char   sbuff[MAX_MSGSIZE], rbuff[MAX_MSGSIZE];
>>>> MPI_Status stats[2];
>>>> MPI_Request reqs[2];
>>>> int main(argc,argv)
>>>> int argc;
>>>> char *argv[];  {
>>>> MPI_Init(&argc,&argv);
>>>> MPI_Comm_size(MPI_COMM_WORLD,&numtasks);
>>>> MPI_Comm_rank(MPI_COMM_WORLD,&rank);
>>>> /**************************** task 0 ***********************************/
>>>> if (rank == 0) {
>>>>    /* Initializations */
>>>>    n=1;
>>>>    for (i=0; i<=STEPS; i++) {
>>>>      msgsizes[i] = n;
>>>>      results[i] = 0.0;
>>>>      n=n*2;
>>>>    for (i=0; i<MAX_MSGSIZE; i++)
>>>>      sbuff[i] = 'x';
>>>>    /* Greetings */
>>>>    printf("\n****** Persistent Communications *****\n");
>>>>    printf("Trials=      %8d\n",TRIALS);
>>>>    printf("Reps/trial=  %8d\n",REPS);
>>>>    printf("Message Size   Bandwidth (bytes/sec)\n");
>>>>    /* Begin timings */
>>>>    for (k=0; k<TRIALS; k++) {
>>>>      n=1;
>>>>      for (j=0; j<=STEPS; j++) {
>>>>        /* Setup persistent requests for both the send and receive */
>>>>        MPI_Recv_init (&rbuff, n, MPI_CHAR, 1, tag, MPI_COMM_WORLD,&reqs[0]);
>>>>        MPI_Send_init (&sbuff, n, MPI_CHAR, 1, tag, MPI_COMM_WORLD,&reqs[1]);
>>>>        t1 = MPI_Wtime();
>>>>        for (i=1; i<=REPS; i++){
>>>>          MPI_Startall (2, reqs);
>>>>          MPI_Waitall (2, reqs, stats);
>>>>        t2 = MPI_Wtime();
>>>>        /* Compute bandwidth and save best result over all TRIALS */
>>>>        ttime = t2 - t1;
>>>>        tbytes = sizeof(char) * n * 2.0 * (float)REPS;
>>>>        mbytes = tbytes/ttime;
>>>>        if (results[j]<   mbytes)
>>>>           results[j] = mbytes;
>>>>        /* Free persistent requests */
>>>>        MPI_Request_free (&reqs[0]);
>>>>        MPI_Request_free (&reqs[1]);
>>>>        n=n*2;
>>>>        }   /* end j loop */
>>>>      }     /* end k loop */
>>>>    /* Print results */
>>>>      printf("%9d %16d\n", msgsizes[j], (int)results[j]);
>>>>    }       /* end of task 0 */
>>>> /****************************  task 1 ************************************/
>>>> if (rank == 1) {
>>>>    /* Begin timing tests */
>>>>      n=1;
>>>>        MPI_Recv_init (&rbuff, n, MPI_CHAR, 0, tag, MPI_COMM_WORLD,&reqs[0]);
>>>>        MPI_Send_init (&sbuff, n, MPI_CHAR, 0, tag, MPI_COMM_WORLD,&reqs[1]);
>>>>        n=n*2;
>>>>        }   /* end j loop */
>>>>      }     /* end k loop */
>>>>    }       /* end task 1 */
>>>> MPI_Finalize();
>>>> }  /* end of main */
>>> _______________________________________________
>>> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
>>> To manage subscription options or unsubscribe:
>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
