[mpich-discuss] mpich2-1.3.2p1 compile error
Anthony Chan chan at mcs.anl.gov
Wed May 4 12:29:33 CDT 2011
Your configure output shows that hwloc added -fvisibility=hidden to CFLAGS
and that causes the make failure.  Could you send us this file
src/pm/hydra/tools/bind/hwloc/hwloc/config.log
in your build directory ?
A.Chan
----- Original Message -----
> Anthony,
> Probably line:
> PATH: /neem2/huangwei/apps/mpich2-1.4rc2/bin
> caused the confusion, but it is the log file for 1.3.2p1.
> (As I tried 1.4rc2 before and put that line into my path.)
> Attached are two files of the configure and make output
> (saved to files).
> Thanks,
> Wei Huang
> huangwei at ucar.edu
> VETS/CISL
> National Center for Atmospheric Research
> P.O. Box 3000 (1850 Table Mesa Dr.)
> Boulder, CO 80307-3000 USA
> (303) 497-8924
> On May 4, 2011, at 10:43 AM, Anthony Chan wrote:
> > The config.log you sent is from mpich2-1.4rc2 not mpich2-1.3.2p1
> > that you originally reported to have problem. Also pgcc does not
> > seem
> > to have option -fvisibility=hidden which AFAIK is a gcc option...
> > Need your configure and make outputs to find out what's wrong.
> >> config.log which is generated automatically by configure isn't what
> >> I need yet. We need the configure and make outputs as shown
> >> on your screen, see MPICH2's top-level README file for more
> >> details.
> >>> Attached is the config.log.
> >>> Thanks,
> >>> Wei Huang
> >>> VETS/CISL
> >>> (303) 497-8924
> >>> On May 4, 2011, at 9:40 AM, Anthony Chan wrote:
> >>>> Can you send us the configure and make outputs as stated in the
> >>>> README ?
> >>>> A.Chan
> >>>>> Hi, there,
> >>>>> I tried to compile mpich2-1.3.2p1, and configure with:
> >>>>> setenv CC pgcc
> >>>>> setenv FC pgf90
> >>>>> ./configure \
> >>>>> --prefix=/neem2/huangwei/apps/mpich2-1.3.2p1
> >>>>> When I compile, I go the error message below.
> >>>>> How do I solve this issue?
> >>>>> Thanks,
> >>>>> Wei
> >>>>> VETS/CISL
> >>>>> (303) 497-8924
> >>>>> Making all in src
> >>>>> make[5]: Entering directory
> >>>>> `/neem2/huangwei/src/mpich2-1.3.2p1/src/pm/hydra/tools/bind/hwloc/hwloc/src'
> >>>>> CC topology.lo
> >>>>> pgcc-Warning-Unknown switch: -fvisibility=hidden
> >>>>> PGC-S-0170-Designated initializers are not supported
> >>>>> (topology.c:
> >>>>> 497)
> >>>>> (topology.c:
> >>>>> 509)
> >>>>> PGC/x86-64 Linux/x86-64 6.2-5: compilation completed with severe
> >>>>> errors
> >>>>> make[5]: *** [topology.lo] Error 1
> >>>>> make[5]: Leaving directory
> >>>>> make[4]: *** [all-recursive] Error 1
> >>>>> make[4]: Leaving directory
> >>>>> `/neem2/huangwei/src/mpich2-1.3.2p1/src/pm/hydra/tools/bind/hwloc/hwloc'
> >>>>> make[3]: *** [all-recursive] Error 1
> >>>>> make[3]: Leaving directory
> >>>>> `/neem2/huangwei/src/mpich2-1.3.2p1/src/pm/hydra'
> >>>>> make[2]: *** [all-redirect] Error 1
> >>>>> make[2]: Leaving directory
> >>>>> `/neem2/huangwei/src/mpich2-1.3.2p1/src/pm'
> >>>>> make[1]: *** [all-redirect] Error 2
> >>>>> make[1]: Leaving directory
> >>>>> `/neem2/huangwei/src/mpich2-1.3.2p1/src'
> >>>>> make: *** [all-redirect] Error 2
> >>>>> compiler info:
> >>>>> neem>pgcc -V
> >>>>> pgcc 6.2-5 64-bit target on x86-64 Linux
> >>>>> Copyright 1989-2000, The Portland Group, Inc. All Rights
> >>>>> Reserved.
> >>>>> Copyright 2000-2006, STMicroelectronics, Inc. All Rights
> >>>>> Reserved.
> >>>>> neem>pgf90 -V
> >>>>> pgf90 6.2-5 64-bit target on x86-64 Linux
> >>>>> Reserved.
> >>>>> Reserved.
> >>>>> _______________________________________________
> >>>>> mpich-discuss mailing list
> >>>>> mpich-discuss at mcs.anl.gov
> >>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
