[mpich-discuss] MPICH mpiexec can't run if you install matlab
Brock Palen brockp at umich.edu
Thu Mar 17 13:30:41 CDT 2011
Just to throw in,
matlab uses mpich2 for its parallel toolbox, if you are not going to use that box try removing it.
Matlab also used a different launch method, I know when using mpiexec I had to use --comm=pmi (this is osc mpiexec)
Don't know if that helps an mpich guru out in your issue.
Brock Palen
www.umich.edu/~brockp
Center for Advanced Computing
brockp at umich.edu
(734)936-1985
On Mar 17, 2011, at 2:25 PM, Nicolas Rosner wrote:
>> it returns nothing if you run in the command line
> What exactly do you run that returns nothing?
> Does that mean that this same MPICH2 installation was working
> correctly until you installed Matlab?
> N.
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
