[mpich-discuss] mpiexec.hydra.exe.stackdump in Windows 7
Dungan, Kerry kdungan at hpti.com
Sat Jul 30 16:57:20 CDT 2011
I am trying to run a program and I keep getting a stackdump. The same process runs fine on my Vista core i7-920 machine. My new machine is running Windows 7 on a core i7-2720QM. For both machines, I have mpich2-1.4 installed with g++-4 using mpic++ as the compiler. The program compiles fine. When running the output executable alone, i.e. ./test, I get "Hello world!" as expected. When running the program with mpirun, I get the stackdump. In fact, it does not matter what executable even nonexistent, mpirun gives a stack dump
Specifically,
mpirun -verbose -n 1 test
host: kdungan-PC
mpiexec options:
  Base path: /home/kdungan/mpich2-install/bin/
  Launcher: (null)
  Debug level: 1
  Enable X: -1
  Global environment:
    HOMEPATH=\Users\kdungan
    MANPATH=/usr/local/man:/usr/share/man:/usr/man:
    APPDATA=C:\Users\kdungan\AppData\Roaming
    RCAUTOPLAY=C:\Program Files (x86)\Roxio\OEM\Roxio Central 5\
    ProgramW6432=C:\Program Files
    HOSTNAME=kdungan-PC
    TERM=cygwin
    PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 42 Stepping 7, GenuineIntel
    WINDIR=C:\Windows
    EMC_AUTOPLAY=C:\Program Files (x86)\Common Files\Roxio Shared\OEM\
    PUBLIC=C:\Users\Public
    OLDPWD=/home/kdungan/mpich2-install/bin
    USERDOMAIN=kdungan-PC
    CommonProgramFiles(x86)=C:\Program Files (x86)\Common Files
    OS=Windows_NT
    ALLUSERSPROFILE=C:\ProgramData
    windows_tracing_flags=3
    USER=kdungan
    windows_tracing_logfile=C:\BVTBin\Tests\installpackage\csilogfile.log
    TEMP=/tmp
    COMMONPROGRAMFILES=C:\Program Files (x86)\Common Files
    BURN_AUTOPLAY=C:\Program Files (x86)\Roxio\OEM\Roxio Burn\
    USERNAME=kdungan
    CPP=cpp-4
    PROCESSOR_LEVEL=6
    PATH=/home/kdungan/mpich2-install/bin:/usr/local/bin:/usr/bin:/cygdrive/c/Program Files/Common Files/Microsoft Shared/Windows Live:/cygdrive/c/Program Files (x86)/Common Files/Microsoft Shared/Windows Live:/cygdrive/c/Program Files/Dell/DW WLAN Card:/cygdrive/c/Windows/system32:/cygdrive/c/Windows:/cygdrive/c/Windows/System32/Wbem:/cygdrive/c/Windows/System32/WindowsPowerShell/v1.0:/cygdrive/c/Program Files/Intel/DMIX:/cygdrive/c/Program Files (x86)/NTRU Cryptosystems/NTRU TCG Software Stack/bin:/cygdrive/c/Program Files/NTRU Cryptosystems/NTRU TCG Software Stack/bin:/cygdrive/c/Program Files (x86)/Intel/Services/IPT:/cygdrive/c/Program Files/Dell/Dell Data Protection/Access/Advanced/Wave/Gemalto/Access Client/v5:/cygdrive/c/Program Files (x86)/Windows Live/Shared:/cygdrive/c/Program Files (x86)/Common Files/Roxio Shared/DLLShared:/cygdrive/c/Program Files (x86)/Common Files/Roxio Shared/OEM/DLLShared:/cygdrive/c/Program Files (x86)/Common Files/Roxio Shared/OEM/DLLShared:/cygdrive/c/Program Files (x86)/Common Files/Roxio Shared/OEM/12.0/DLLShared:/cygdrive/c/Program Files (x86)/Roxio/OEM/AudioCore
    PSModulePath=C:\Windows\system32\WindowsPowerShell\v1.0\Modules\
    FP_NO_HOST_CHECK=NO
    PWD=/home/kdungan/ImageMaster/src
    SYSTEMDRIVE=C:
    PROCESSOR_ARCHITEW6432=AMD64
    LANG=C.UTF-8
    USERPROFILE=C:\Users\kdungan
    PS1=\[\e]0;\w\a\]\n\[\e[32m\]\u@\h \[\e[33m\]\w\[\e[0m\]\n\$
    LOGONSERVER=\\KDUNGAN-PC
    CommonProgramW6432=C:\Program Files\Common Files
    PROCESSOR_ARCHITECTURE=x86
    LOCALAPPDATA=C:\Users\kdungan\AppData\Local
    !C:=C:\cygwin\bin
    CXX=g++-4
    ProgramData=C:\ProgramData
    SHLVL=1
    HOME=/home/kdungan
    PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
    HOMEDRIVE=C:
    PROMPT=$P$G
    COMSPEC=C:\Windows\system32\cmd.exe
    TMP=/tmp
    SYSTEMROOT=C:\Windows
    PRINTER=Send To OneNote 2010
    PROCESSOR_REVISION=2a07
    INFOPATH=/usr/local/info:/usr/share/info:/usr/info:
    CC=gcc-4
    NUMBER_OF_PROCESSORS=8
    SESSIONNAME=Console
    COMPUTERNAME=KDUNGAN-PC
    _=/home/kdungan/mpich2-install/bin/mpirun
  Hydra internal environment:
    GFORTRAN_UNBUFFERED_PRECONNECTED=y
    Proxy information:
      [1] proxy: kdungan-PC (1 cores)
      Exec list: test (1 processes);
[mpiexec at kdungan-PC] Timeout set to -1 (-1 means infinite)
[mpiexec at kdungan-PC] Got a control port string of kdungan-PC:51002
Proxy launch args: /home/kdungan/mpich2-install/bin/hydra_pmi_proxy --control-port kdungan-PC:51002 --debug --demux poll --pgid 0 --retries 10 --proxy-id
[mpiexec at kdungan-PC] PMI FD: (null); PMI PORT: (null); PMI ID/RANK: -1
Arguments being passed to proxy 0:
--version 1.4 --interface-env-name MPICH_INTERFACE_HOSTNAME --hostname kdungan-PC --global-core-map 0,1,0 --filler-process-map 0,1,0 --global-process-count 1 --auto-cleanup 1 --pmi-rank -1 --pmi-kvsname kvs_1612_0 --pmi-process-mapping (vector,(0,1,1)) --ckpoint-num -1 --global-inherited-env 60 'HOMEPATH=\Users\kdungan' 'MANPATH=/usr/local/man:/usr/share/man:/usr/man:' 'APPDATA=C:\Users\kdungan\AppData\Roaming' 'RCAUTOPLAY=C:\Program Files (x86)\Roxio\OEM\Roxio Central 5\' 'ProgramW6432=C:\Program Files' 'HOSTNAME=kdungan-PC' 'TERM=cygwin' 'PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 42 Stepping 7, GenuineIntel' 'WINDIR=C:\Windows' 'EMC_AUTOPLAY=C:\Program Files (x86)\Common Files\Roxio Shared\OEM\' 'PUBLIC=C:\Users\Public' 'OLDPWD=/home/kdungan/mpich2-install/bin' 'USERDOMAIN=kdungan-PC' 'CommonProgramFiles(x86)=C:\Program Files (x86)\Common Files' 'OS=Windows_NT' 'ALLUSERSPROFILE=C:\ProgramData' 'windows_tracing_flags=3' 'USER=kdungan' 'windows_tracing_logfile=C:\BVTBin\Tests\installpackage\csilogfile.log' '!::=::\' 'TEMP=/tmp' 'COMMONPROGRAMFILES=C:\Program Files (x86)\Common Files' 'BURN_AUTOPLAY=C:\Program Files (x86)\Roxio\OEM\Roxio Burn\' 'USERNAME=kdungan' 'CPP=cpp-4' 'PROCESSOR_LEVEL=6' 'ProgramFiles(x86)=C:\Program Files (x86)' 'PATH=/home/kdungan/mpich2-install/bin:/usr/local/bin:/usr/bin:/cygdrive/c/Program Files/Common Files/Microsoft Shared/Windows Live:/cygdrive/c/Program Files (x86)/Common Files/Microsoft Shared/Windows Live:/cygdrive/c/Program Files/Dell/DW WLAN Card:/cygdrive/c/Windows/system32:/cygdrive/c/Windows:/cygdrive/c/Windows/System32/Wbem:/cygdrive/c/Windows/System32/WindowsPowerShell/v1.0:/cygdrive/c/Program Files/Intel/DMIX:/cygdrive/c/Program Files (x86)/NTRU Cryptosystems/NTRU TCG Software Stack/bin:/cygdrive/c/Program Files/NTRU Cryptosystems/NTRU TCG Software Stack/bin:/cygdrive/c/Program Files (x86)/Intel/Services/IPT:/cygdrive/c/Program Files/Dell/Dell Data Protection/Access/Advanced/Wave/Gemalto/Access Client/v5:/cygdrive/c/Program Files (x86)/Windows Live/Shared:/cygdrive/c/Program Files (x86)/Common Files/Roxio Shared/DLLShared:/cygdrive/c/Program Files (x86)/Common Files/Roxio Shared/OEM/DLLShared:/cygdrive/c/Program Files (x86)/Common Files/Roxio Shared/OEM/DLLShared:/cygdrive/c/Program Files (x86)/Common Files/Roxio Shared/OEM/12.0/DLLShared:/cygdrive/c/Program Files (x86)/Roxio/OEM/AudioCore' 'PSModulePath=C:\Windows\system32\WindowsPowerShell\v1.0\Modules\' 'FP_NO_HOST_CHECK=NO' 'PWD=/home/kdungan/ImageMaster/src' 'SYSTEMDRIVE=C:' 'PROCESSOR_ARCHITEW6432=AMD64' 'LANG=C.UTF-8' 'USERPROFILE=C:\Users\kdungan' 'PS1=\[\e]0;\w\a\]\n\[\e[32m\]\u@\h \[\e[33m\]\w\[\e[0m\]\n\$ ' 'LOGONSERVER=\\KDUNGAN-PC' 'CommonProgramW6432=C:\Program Files\Common Files' 'PROCESSOR_ARCHITECTURE=x86' 'LOCALAPPDATA=C:\Users\kdungan\AppData\Local' '!C:=C:\cygwin\bin' 'CXX=g++-4' 'ProgramData=C:\ProgramData' 'SHLVL=1' 'HOME=/home/kdungan' 'PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC' 'HOMEDRIVE=C:' 'PROMPT=$P$G' 'COMSPEC=C:\Windows\system32\cmd.exe' 'TMP=/tmp' 'SYSTEMROOT=C:\Windows' 'PRINTER=Send To OneNote 2010' 'PROCESSOR_REVISION=2a07' 'INFOPATH=/usr/local/info:/usr/share/info:/usr/info:' 'PROGRAMFILES=C:\Program Files (x86)' 'CC=gcc-4' 'NUMBER_OF_PROCESSORS=8' 'SESSIONNAME=Console' 'COMPUTERNAME=KDUNGAN-PC' '_=/home/kdungan/mpich2-install/bin/mpirun' --global-user-env 0 --global-system-env 1 'GFORTRAN_UNBUFFERED_PRECONNECTED=y' --proxy-core-count 1 --exec --exec-appnum 0 --exec-proc-count 1 --exec-local-env 0 --exec-wdir /home/kdungan/ImageMaster/src --exec-args 1 test
Segmentation fault (core dumped)
Kerry E. Dungan, Ph.D.
Senior Staff Scientist
High-Performance Technologies, Inc.
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110730/b1dfee1b/attachment.htm>
