[mpich-discuss] mpich2-1.4 installation error
Anthony Chan chan at mcs.anl.gov
Mon Jul 18 17:10:10 CDT 2011
You m.txt contains these warning messages:
make[4]: Warning: File `../../../../lib/libmpich.a' has modification time 3.4e+03 s in the future
make[4]: warning:  Clock skew detected.  Your build may be incomplete.
It is likely your network filesystem's clock isn't sync'ed properly,
try build everything in a local file system.
A.Chan
----- Original Message -----
> That's an odd error during the compile. Just try running make again.
> system_hints.c:188: fatal error: error closing /tmp/ccJiOc0J.s:
> Interrupted system call
> compilation terminated.
> On Jul 18, 2011, at 4:25 PM, Ruhollah Moussavi Baygi wrote:
> > Hi there
> > I have only ordinary user privileges and so trying to install MPICH2
> > in my home directory. there was a problem and couldn't figure it
> > out.
> > here are my c.txt, m.txt, and config.log files.
> > thank you for your help.
> > PS by the way, our cluster is such that my directory is shared
> > between all nodes and thus all nodes have equally access.
> > Best,
> > <c.txt><config.log><m.txt>_______________________________________________
> > mpich-discuss mailing list
> > mpich-discuss at mcs.anl.gov
> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
