[mpich-discuss] How can we generate source files corresponding to f77 binding
Anthony Chan chan at mcs.anl.gov
Fri Jul 15 13:53:32 CDT 2011
Depends on how small the subset of F77 MPI you want to support, it may be
easier to simply copy the *f.c files instead of using buildiface. Also,
IMHO, one of the trickiest part of f77 binding is the MPI fortran constants
(like MPI_STATUS_IGNORE) which are defined at the end of mpif.h.in.  If the
subset of MPI you plan to support do not use those, it will save you
some headache.
A.Chan
----- Original Message -----
> I am trying to understand the binding procedure and adapt it to my
> implementation research on a subset of MPI.
> Clara
> On Fri, Jul 15, 2011 at 1:52 PM, Rajeev Thakur <thakur at mcs.anl.gov>
> wrote:
> > It is created automatically during configure. What exactly are you
> > trying
> > to do? Why do you need to create it separately by hand?
> > Rajeev
> > On Jul 15, 2011, at 12:50 PM, clara wrote:
> > > Thanks.
> > > Can anyone tell me how to generate mpif.h from mpif.h.in? There
> > > are
> > some symbolic constants in mpif.h.in generated by buildiface, for
> > example,
> > "MPI_F77_LONG" in "PARAMETER (MPI_LONG=@MPI_F77_LONG@)". And these
> > symbolic constants are converted into constants in mpif.h.
> > > - Clara
> > > On Fri, Jul 15, 2011 at 10:28 AM, William Gropp
> > > <wgropp at illinois.edu>
> > wrote:
> > > The file maint/updatefiles shows how buildiface is run to generate
> > > the
> > Fortran interfaces. There are options to buildiface to generate
> > variations
> > on the interfaces; though it is not yet in the distribution, I'm
> > working on
> > a version to handle the case where Fortran INTEGERs are different in
> > size
> > than C ints (which some applications still want).
> > > Bill
> > > On 7/14/11 1:03 PM, clara wrote:
> > >> All source code associated with f77 binding are generated by
> > src/binding/f77/buildiface with mpi.h as input, aren't them?
> > >> Clara
> > >> On Thu, Jul 14, 2011 at 1:52 PM, clara <clarazhang at gmail.com>
> > >> wrote:
> > >> There is a comment "This file created by buildiface" in
> > src/binding/f77/mpif.h. Can anyone tell me how to generate the
> > related files
> > for f77 binding?
> > >> Thanks.
> > >> - Clara
> > >> _______________________________________________
> > >> mpich-discuss mailing list
> > >> mpich-discuss at mcs.anl.gov
> > >> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
