[mpich-discuss] How can we generate source files corresponding to f77 binding
clara clarazhang at gmail.com
Fri Jul 15 13:15:10 CDT 2011
I got it. It is in winconfigure.wsf, isn't it?
On Fri, Jul 15, 2011 at 2:12 PM, clara <clarazhang at gmail.com> wrote:
> I have to support F77 either. So I need to know how MPICH2 converts
> mpif.h.in into mpif.h. In my opinion, there is some piece of code in
> charge of transforming all symbolic constants into integers. Can you tell me
> where is it if you know? Thanks.
> Clara
> On Fri, Jul 15, 2011 at 2:07 PM, Rajeev Thakur <thakur at mcs.anl.gov> wrote:
>> Can you work with just the C bindings then?
>> Rajeev
>> On Jul 15, 2011, at 12:59 PM, clara wrote:
>> > I am trying to understand the binding procedure and adapt it to my
>> implementation research on  a subset of MPI.
>> > Clara
>> > On Fri, Jul 15, 2011 at 1:52 PM, Rajeev Thakur <thakur at mcs.anl.gov>
>> wrote:
>> > It is created automatically during configure. What exactly are you
>> trying to do? Why do you need to create it separately by hand?
>> > Rajeev
>> > On Jul 15, 2011, at 12:50 PM, clara wrote:
>> > > Thanks.
>> > > Can anyone tell me how to generate mpif.h from mpif.h.in?  There are
>> some symbolic constants in mpif.h.in generated by buildiface, for
>> example, "MPI_F77_LONG" in "PARAMETER (MPI_LONG=@MPI_F77_LONG@)". And
>> these symbolic constants are converted into constants in  mpif.h.
>> > > - Clara
>> > > On Fri, Jul 15, 2011 at 10:28 AM, William Gropp <wgropp at illinois.edu>
>> wrote:
>> > > The file maint/updatefiles shows how buildiface is run to generate the
>> Fortran interfaces.  There are options to buildiface to generate variations
>> on the interfaces; though it is not yet in the distribution, I'm working on
>> a version to handle the case where Fortran INTEGERs are different in size
>> than C ints (which some applications still want).
>> > > Bill
>> > > On 7/14/11 1:03 PM, clara wrote:
>> > >> All source code associated with f77 binding are generated by
>> src/binding/f77/buildiface with mpi.h as input, aren't them?
>> > >> Clara
>> > >> On Thu, Jul 14, 2011 at 1:52 PM, clara <clarazhang at gmail.com> wrote:
>> > >> There is a comment "This file created by buildiface" in
>> src/binding/f77/mpif.h. Can anyone tell me how to generate the related files
>> for f77 binding?
>> > >> Thanks.
>> > >> - Clara
>> > >> _______________________________________________
>> > >> mpich-discuss mailing list
>> > >> mpich-discuss at mcs.anl.gov
>> > >> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110715/b7259629/attachment.htm>
