[mpich-discuss] MPICH2-1.4 make error
Anthony Chan chan at mcs.anl.gov
Mon Jul 11 16:32:58 CDT 2011
Glad to hear that you could install mpich2.
A.Chan
----- Original Message -----
> Dear Anthony,
> Many thanks for your prompt reply.
> Yes you were right....I set some environmental variables before start
> of
> configuration...where I set FC, F77 and F90 to gfortran.
> Now I have reconfigured and used only FC to gfortran environment. The
> configuration does not give me F90/F90FLAGS error and I could further
> make
> and make install the code.
> Thanks and regards. nilima
> On Sun, Jul 10, 2011 at 2:01 AM, Anthony Chan <chan at mcs.anl.gov>
> wrote:
> > The last line in your c.txt contains this:
> > configure: error: F90 and F90FLAGS are replaced by FC and FCFLAGS
> > respectively in this configure, please unset F90/F90FLAGS and set
> > FC/FCFLAGS
> > instead and rerun configure again.
> > So mpich2 configure failed because of you have either F90 or
> > F90FLAGS (or
> > both)
> > set in your environment during configure. Unset them and try again.
> > (It is likely that you set these variables in your shell startup
> > file)
> > BTW, the config.log you sent isn't the top-level one, it is from
> > mpich2-1.4/src/openpa
> > so I cannot tell which exact F90* you set.
> > A.Chan
> > > Dear users,
> > > I have been trying to install MPICH2 library using gfortran (4.1.2
> > > version).
> > > Everything works fine while configuration, however when I try to
> > > make
> > > the
> > > code, it gives following error:
> > > make: *** No targets specified and no makefile found. Stop.
> > > Further it is to be noted that *no* Makefile was actually formed
> > > after
> > > the
> > > configuration step.
> > > I have attached the c.txt and config.log file for your reference.
> > > It would be great if somebody could throw some light on this
> > > error!
> > > Thanks and Regards,
> > > nilima
> > > _______________________________________________
> > > mpich-discuss mailing list
> > > mpich-discuss at mcs.anl.gov
> > > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
