[mpich-discuss] hydra_nameserver
Bernard Secher - SFME/LGLS bernard.secher at cea.fr
Mon Jul 11 03:46:07 CDT 2011
I have in some cases, the following error message when I unpublish a
service name:
[mpiexec at is209011] HYD_pmcd_pmi_unpublish
(/data/tmplgls/secher/mpich2-1.4.x-r8755-src/src/pm/hydra/pm/pmiserv/pmiserv_pmi.c:227):
assert (!closed) failed
[mpiexec at is209011] fn_unpublish_name
(/data/tmplgls/secher/mpich2-1.4.x-r8755-src/src/pm/hydra/pm/pmiserv/pmiserv_pmi_v1.c:639):
error unpublishing service
[mpiexec at is209011] handle_pmi_cmd
(/data/tmplgls/secher/mpich2-1.4.x-r8755-src/src/pm/hydra/pm/pmiserv/pmiserv_cb.c:44):
PMI handler returned error
[mpiexec at is209011] control_cb
(/data/tmplgls/secher/mpich2-1.4.x-r8755-src/src/pm/hydra/pm/pmiserv/pmiserv_cb.c:289):
unable to process PMI command
[mpiexec at is209011] HYDT_dmxu_poll_wait_for_event
(/data/tmplgls/secher/mpich2-1.4.x-r8755-src/src/pm/hydra/tools/demux/demux_poll.c:77):
callback returned
error status
[mpiexec at is209011] HYD_pmci_wait_for_completion
(/data/tmplgls/secher/mpich2-1.4.x-r8755-src/src/pm/hydra/pm/pmiserv/pmiserv_pmci.c:179):
error waiting for
 event
[mpiexec at is209011] main
(/data/tmplgls/secher/mpich2-1.4.x-r8755-src/src/pm/hydra/ui/mpich/mpiexec.c:397):
process manager error waiting for completion
Have you any idea about the problem ?
Bernard
Pavan Balaji a écrit :
> On 07/07/2011 04:48 AM, Bernard Secher - SFME/LGLS wrote:
>> OK, I have configured again mpich.
>> I have now another problem. When I try to lookup a service name which is
>> not published, the MPI_Lookup_name() routine return a MPI_SUCCESS, and
>> not raise an error.
> Thanks for the report. That was a bug in MPICH2. I've just committed
> in a fix in r8750. Can you try the latest nightly snapshot (>= r8750)
> to see if it works for you? It should be available in a few minutes.
> http://www.mcs.anl.gov/research/projects/mpich2/downloads/tarballs/nightly/1.4.x/
>  -- Pavan
       _\\|//_
      (' 0 0 ')
____ooO  (_) Ooo______________________________________________________
 Bernard Sécher  DEN/DM2S/SFME/LGLS    mailto : bsecher at cea.fr
 CEA Saclay, Bât 454, Pièce 114        Phone  : 33 (0)1 69 08 73 78
 91191 Gif-sur-Yvette Cedex, France    Fax    : 33 (0)1 69 08 10 87
------------Oooo---------------------------------------------------
       oooO (   )
        \ ( (_/
         \_)
Ce message électronique et tous les fichiers attachés qu'il contient
sont confidentiels et destinés exclusivement à l'usage de la personne
à laquelle ils sont adressés. Si vous avez reçu ce message par erreur,
merci d'en avertir immédiatement son émetteur et de ne pas en conserver
de copie.
This e-mail and any files transmitted with it are confidential and
intended solely for the use of the individual to whom they are addressed.
If you have received this e-mail in error please inform the sender
immediately, without keeping any copy thereof.
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110711/27c24df4/attachment.htm>
