[mpich-discuss] compilation problem with mpich2-1.4
Jean-Michel Beuken Jean-Michel.beuken at uclouvain.be
Sat Jul 9 01:40:28 CDT 2011
Hello,
same source version of my package ( fortran 90 ), same compiler ( gcc 4.6.1 )  , same OS ( SL 6.0  x86_64 )
same recipe to compile mpich2  ( 1.3.2p1 and 1.4 ) :
CC=gcc \
FC=gfortran \
F77=gfortran \
./configure --prefix=/usr/local/mpich2-1.X.Y_gcc461  --enable-fc --enable-f77 \
                   --disable-cxx --without-mpe --with-pm=gforker \
                   --with-device=ch3:nemesis --enable-romio
everything working with mpich2 1.3.2p2
but problem during compilation of my program with 1.4 :
make[3]: Entering directory `/home/buildbot/WorkSpace/6.9.1-private/src/12_hide_mpi'
/usr/local/mpich2_open64/bin/mpif90 -m64 -align64 -DHAVE_CONFIG_H -I. -I../.. -I../../src/incs -I../../src/incs   -freeform -module /home/buildbot/WorkSpace/6.9.1-private/src/mods -O2 -march=opteron -msse2 -m64 -align64  -extend-source  -c -o m_xmpi.o m_xmpi.F90
  use defs_basis,   only : i4b, i8b, sp, dp, spc, dpc, std_out, std_out_default, tmp_unit, fnlen
openf95-855 openf90: ERROR M_XMPI, File = m_xmpi.F90, Line = 32, Column = 8
   The compiler has detected errors in module "M_XMPI".  No module information file will be created for this module.
  call MPI_Type_hvector(ny,1,stride_x,column_type,new_type,mpi_err)
openf95-1307 openf90: ERROR XMPIO_CREATE_FSUBARRAY_2D, File = m_xmpi.F90, Line = 2038, Column = 29
   The kind (4) of this actual argument does not match that of its associated dummy argument (8).
What is the problem ?
bug ?
thanks
jmb
