[mpich-discuss] Fwd: About using mpi on windows
Ruizi Li ruizli at umail.iu.edu
Fri Jul 8 12:32:01 CDT 2011
---------- Forwarded message ----------
Date: Fri, Jul 8, 2011 at 1:30 PM
Subject: Re: [mpich-discuss] About using mpi on windows
To: Jayesh Krishna <jayesh at mcs.anl.gov>
Thank you for your reply! Well actually I added the path to mpiexec in
Control Panel, and it doesn't work. Windows still cannot recognize
mpiexec.exe. I am wondering if there are any dependencies to install and run
MPICH2? Thanks!
Regards
Ruizi
On Fri, Jul 8, 2011 at 11:57 AM, Jayesh Krishna <jayesh at mcs.anl.gov> wrote:
> Hi,
>  It looks like you haven't added path to mpiexec (c:\Program
> Files\MPICH2\bin) to your PATH (Control Panel --> System --> Advanced -->
> Environment Variables). Or you can specify the complete path to mpiexec
> (C:\Program Files\MPICH2\bin\mpiexec -n 2 hostname).
> Regards,
> Jayesh
> From: "Ruizi Li" <ruizli at umail.iu.edu>
> To: mpich-discuss at mcs.anl.gov
> Sent: Wednesday, July 6, 2011 9:38:24 AM
> Subject: [mpich-discuss] About using mpi on windows
> Hi there,
> I recently installed MPICH2 for windows 64bit machine, and I tried to
> compile the "mcstas" program which uses some language based on C, with mpi,
> running on multiple cores of the machine, but the compilation failed, and it
> showed this error:
> 'mpiexec.exe' is not recognized as an internal or external command,
> operable program or batch file.
> Press any key to continue . . .
> Is it because MPCH2 is not installed properly on the machine? Or I need to
> set some environment variables? I could not figure out how to deal with
> this. So many thanks!
> Ruizi
> mpich-discuss mailing list
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110708/00341014/attachment.htm>
