[mpich-discuss] Could not determine a way to link a Fortran test program!
Chris M. Ober ober at Princeton.EDU
Wed Jul 6 14:13:41 CDT 2011
I am running into a very irritating problem compiling mpich to use the intel fortran and c/c++ compilers. It always errors out in the ./configure phase
I've ran the following commands:
source /sayre/intel/11.1/bin/iccvars.sh intel64
source /sayre/intel/11.1/bin/ifortvars.sh intel64
./configure --prefix=/sayre --enable-f77 --enable-fc --enable-cxx --enable-mpe CC=/sayre/bin/icc CXX=/sayre/bin/icpc FC=/sayre/bin/ifort F77=/sayre/bin/ifort |& tee configure.log
with ifort and icc located at /sayre/intel/11.1/bin/intel64/  (I made a symlink to /sayre/bin to make things easier for me. This is intended to be a shared repository for commonly used software.
It fails with:
config.status: creating src/opa_config.h - prefix OPA for src/config.h defines
config.status: src/opa_config.h is unchanged
configure: ===== done with src/openpa configure =====
sourcing /sayre/temp/mpich2-1.4/src/pm/hydra/mpich2prereq
checking whether the compiler defines __func__... yes
checking whether the compiler defines __FUNC__... no
checking whether the compiler sets __FUNCTION__... yes
checking whether C compiler accepts option -O2... yes
checking whether C compiler option -O2 works with an invalid prototype program... yes
checking whether routines compiled with -O2 can be linked with ones compiled without -O2... yes
checking for type of weak symbol alias support... pragma weak
checking whether __attribute__ ((weak)) allowed... yes
checking whether __attribute__ ((weak_import)) allowed... yes
checking whether __attribute__((weak,alias(...))) allowed... no
checking for multiple weak symbol support... yes
checking whether we are using the GNU Fortran 77 compiler... no
checking whether /sayre/bin/ifort accepts -g... yes
checking whether Fortran 77 compiler accepts option -O2... no
checking how to get verbose linking output from /sayre/bin/ifort... -v
checking for Fortran 77 libraries of /sayre/bin/ifort...  -L/sayre/intel/11.1/lib/intel64 -L/sayre/intel/11.1/ipp/em64t/lib -L/sayre/intel/11.1/mkl/lib/em64t -L/sayre/intel/11.1/tbb/em64t/cc4.1.0_libc2.4_kernel2.6.16.21/lib -L/lib -L/usr/lib/gcc/x86_64-redhat-linux/4.6.0 -L/usr/lib/gcc/x86_64-redhat-linux/4.6.0/../../../../lib64 -L/lib/../lib64 -L/usr/lib/../lib64 -L/usr/lib/gcc/x86_64-redhat-linux/4.6.0/../../.. -L/lib64 -L/usr/lib64 -L/usr/lib -lifport -lifcore -limf -lsvml -lm -lipgo -lirc -lpthread -lirc_s -ldl
checking whether /sayre/bin/ifort accepts the FLIBS found by autoconf... no
checking for valid entries in FLIBS...
checking whether /sayre/bin/icc links with FLIBS found by autoconf... yes
checking whether Fortran 77 and C objects are compatible... no
checking for file... file
checking for linker for Fortran main program... configure: error: Could not determine a way to link a Fortran test program!
Any idea what this is caused by, or how to fix it?
Thank you,
Chris
Type: text/x-log
Desc: configure.log
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110706/1a023a83/attachment.bin>
