[mpich-discuss] Fatal error in MPI_Init
Jayesh Krishna jayesh at mcs.anl.gov
Mon Jan 31 15:30:44 CST 2011
 Good to know MPICH2 is working for you now.
 Typically Infiniband adapters allow you to run TCP/IP apps above IB (They support TCP/IP sockets). Looking at the error message that you got it looked like the particular Infiniband adapter did not provide a service provider for TCP/IP apps. Anyway, good to know it is working for you now.
 The next release of MPICH2 will include a channel (nd) that supports IB (mpiexec -n 2 -channel nemesis:nd mympipgm.exe would work). You might want to try that out.
Jayesh
----- Original Message -----
To: jayesh at mcs.anl.gov
Sent: Monday, January 31, 2011 3:12:20 PM
Subject: RE: [mpich-discuss] Fatal error in MPI_Init
Jayesh:
I appreciate your quick response!
Finally I could run the "HelloWorld" program!
The problem was that I was not running smpd.exe in the 2nd PC.
Maybe MPICH2 libraries supports the "Mellanox" InfiniBand adapters I have on both PCs.
Now, I can run: mpiexec -hosts 126.1.20.168 126.1.20.169 HelloWorld.exe
and it functions!!!
I don't know how, but it functions!
Gustavo Uribe
> Date: Mon, 31 Jan 2011 09:33:47 -0600
> From: jayesh at mcs.anl.gov
> To: gustfuribe at hotmail.com
> CC: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] Fatal error in MPI_Init
> Hi,
> >> Can you provide a custom build for me? how much would it cost? or would it be free ?
> MPICH2 is open-source and available at no cost (free). I can provide a custom build for you, however we recommend all users to use stable releases for production environments. Also, the version that I provide you will be an experimental support for Network Direct (performance tuning is in the works... and I haven't had a chance to run it on a large system to weed out all the bugs.).
> I would recommend buying "Using MPI" (http://www.mcs.anl.gov/research/projects/mpi/usingmpi/) or any other introductory book on getting started with MPI. There is also a lot of material on MPI if you google for it.
> I will provide you a custom build in a couple of days.
> Regards,
> Jayesh
> From: "Gustavo Uribe" <gustfuribe at hotmail.com>
> Sent: Sunday, January 30, 2011 5:26:47 PM
> Jayesh:
> thanks for your quick response !
> I'm a little complicated with time , I need it soon .
> I'm just getting started with MPI, and InfiniBand networks . That's why I wanted to ask if you can send me a manual or tutorial where I can learn a little more about it .
> Thanks,
> Gustavo Uribe
> > Date: Fri, 28 Jan 2011 15:59:22 -0600
> > To: mpich-discuss at mcs.anl.gov
> > CC: gustfuribe at hotmail.com
> > Hi,
> > It looks like the adapter (driver) does not allow creating TCP/IP sockets (There is no service provided for TCP/IP).
> > The next version of MPICH2 on Windows will have a Network Direct module that should allow you to run your application over Infiniband. I don't know when the next version will be out (~ 1-2 months), if you need it sooner please let me know and I can provide a custom build for you.
> > (PS: Currently MPICH2 on Windows has support for only plain TCP/IP sockets. It does not support Winsock direct or Network Direct.)
> > Regards,
> > Jayesh
> > Sent: Friday, January 28, 2011 10:52:41 AM
> > Subject: [mpich-discuss] Fatal error in MPI_Init
> > Hello everybody!
> > I'm newbie with MPI, so I think I need your help!
> > I want to tell you what is my problem:
> > I have 2 computers connected with Infiniband adapters. On both PCs I'm running Windows XP, and I have installed the correspondent drivers. Then I configured the subnet, and it's possible for me to ping one PC with the other.
> > After that, I installed MPICH2 (for Windows).
> > I want to run a simple "Hello World" program (programmed in C), but in the moment when I want to run the program using MPIEXEC, I obtain the following message:
> > Fatal error in MPI_Init: Other MPI error, error stack:
> > MPIR_Init_thread<388>..........:
> > MPID_Init<315>.................: channel initialization failed
> > MPDIDI_CH3_Init<38>............:
> > MPID_nem_init<234>.............:
> > MPID_nem_newtcp_module_init<90>:
> > MPID_nem_newtcp_module_init<89>: unable to create a socket. No se puede cargar o inicializar el proveedor de servicios solicitado.
> > <errno 10106>
> > Am I doing something wrong?
> > Please! Help me! I'm newbie with MPI.
> > Thanks!
> > Gustavo
> > >From Bariloche (Argentina)
> > _______________________________________________
> > mpich-discuss mailing list
> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
