[mpich-discuss] MPICH2 On Windows 64 bit and Mingw-w64 compilers
Arun Murthy arun.murthy at fluidyn.com
Tue Jan 11 07:23:33 CST 2011
Hi Jayesh
Yes, I linked icpi.o with mpi.lib. Happy to hear that Mingw64 support
will be available this month. I can wait for a couple of weeks for the
next release. In the meantime, if you want me to test the pre-release
version, I would be happy to do that.
Thanks for your help.
Best regards
Arun
On 11-01-2011 17:10, Jayesh Krishna wrote:
> Hi,
>   Are you trying to link your code with mpi.lib ? Mingw compilers may not be playing nice with the windows libraries. AFAICT we added support for mingw 64-bit compilers (*.a libraries compatible with mingw 64-bit compilers) after 1.3.1 was released. It should be available in the next release, 1.3.2, due this month.
> (PS: If you need it sooner than that let me know and I can get you a custom build for development purposes)
> Regards,
> Jayesh
> From: "Arun Murthy"<arun.murthy at fluidyn.com>
> To: "Jayesh Krishna"<jayesh at mcs.anl.gov>
> Cc: mpich-discuss at mcs.anl.gov
> Sent: Tuesday, January 11, 2011 2:12:01 AM
> Subject: Re: [mpich-discuss] MPICH2 On Windows 64 bit and Mingw-w64 compilers
> Hi Jayesh
> I opened CMD with "Run as administrator" and did the following:
> C:\tmp>"C:\Program Files\MPICH2\bin"\mpiexec.exe -n 2 -localroot c:\tmp\icpi.exe
> Job terminated with following error message:
> Error posting writev, A request to send or receive data was disallowed because the socket had already been shut down in that direction with a previous shutdown call.(10058)
> unable to post a write for the next command,
> sock error: Error = 10058
> unable to post a write of the closed_request command to the parent context.
> unable to close the stdin context.
> state machine failed.
> C:\tmp>"C:\Program Files\MPICH2\bin"\mpiexec.exe -n 2 -localroot -exitcodes c:\tmp\icpi.exe
> rank: node: exit code
> 0: Arun-PC: -1073741819
> 1: Arun-PC: -1073741819
> C:\tmp>"C:\Program Files\MPICH2\bin"\smpd -status
> smpd running on Arun-PC
> Best Regards
> Arun
> On 10-01-2011 22:08, Jayesh Krishna wrote:
> Hi,
>   Can you try running the job from an administrator command prompt (Note that opening a command prompt from an administrator account does not give you an admin command prompt. Right-click on the command prompt icon and select "Run as administrator" to get an admin command prompt) and see if it works ?
>   Can you also check the status of the MPICH2 process manager (Type "smpd -status" at the command prompt)?
> Regards,
> Jayesh
> From: Arun Murthy<arun.murthy at fluidyn.com>  To: Jayesh Krishna<jayesh at mcs.anl.gov>  Cc: mpich-discuss at mcs.anl.gov Sent: Mon, 10 Jan 2011 01:33:41 -0600 (CST)
> Hi Jayesh
> I tried that. It did not help. Here is the response:
> C:\tmp>"C:\Program Files\MPICH2\bin"\mpiexec.exe -n 2 -localroot icpi.exe
> Unable to open the HKEY_LOCAL_MACHINE\SOFTWARE\MPICH\SMPD\process\6308
> registry key, error 5, Access is denied.
> Unable to open the HKEY_LOCAL_MACHINE\SOFTWARE\MPICH\SMPD\process\808
> registry k ey, error 5, Access is denied.
> When I killed the job by<CTRL>  C, the following messages appeared:
> mpiexec aborting job...
> received suspend command for a pmi context that doesn't exist: unmatched
> id = 1
> job aborted:
> rank: node: exit code[: error message]
> 0: Arun-PC: -1073741819: mpiexec aborting job
> Terminate batch job (Y/N)? y
> When I tried the same thing on the pre-built "cpi.exe", I get the same
> messages that I got with "icpi.exe", but it still works:
> C:\tmp>"C:\Program Files\MPICH2\bin"\mpiexec.exe -n 2 -localroot cpi
> Unable to open the HKEY_LOCAL_MACHINE\SOFTWARE\MPICH\SMPD\process\4544
> Unable to open the HKEY_LOCAL_MACHINE\SOFTWARE\MPICH\SMPD\process\7288
> Enter the number of intervals: (0 quits) 9
> pi is approximately 3.1426214565576127, Error is 0.0010288029678196
> wall clock time = 0.000077
> When I killed this job by<CTRL>  C, the following messages appeared:
> SuspendThread failed with error 5 for process
> 0:33FB034C-A281-4d45-9189-9DDCDC33C941:'cpi'
> unable to suspend process.
> unable to read the cmd header on the pmi context, Error = -1.
> Error posting readv, An existing connection was forcibly closed by the
> remote host.(10054)
> 1:33FB034C-A281-4d45-9189-9DDCDC33C941:'cpi'
> remote host.(10054)
> received kill command for a pmi context that doesn't exist: unmatched id = 0
> job aborted:
> 0: Arun-PC: 123: process 0 exited without calling finalize
> 1: Arun-PC: 123: process 1 exited without calling finalize
> Does it have anything to do with an incorrect node (-1073741819) on
> which mpiexec is trying to launch the processes? Thanks for your help.
> Best Regards
> Arun
> On 07-01-2011 22:11, Jayesh Krishna wrote:
> Hi,
>    Can you try running your program with the "-localroot" option and let us know if it works for you (mpiexec -n 2 -localroot icpi.exe)?
> Regards,
> Jayesh
> From: "Arun Murthy"<arun.murthy at fluidyn.com>  To: mpich-discuss at mcs.anl.gov Sent: Friday, January 7, 2011 12:56:17 AM
> Subject: [mpich-discuss] MPICH2 On Windows 64 bit and Mingw-w64 compilers
> Hi
> I am trying to use MPICH2 on Windows 7 64bit (installed from
> mpich2-1.3.1-win-x86-64.msi) along with Mingw-w64 compiler suite
> (mingw-w64-1.0-bin_i686-mingw_20101129).
> I tried to compile-link the example "icpi.c" using following command:
> C:\MinGW\mingw-w64-1.0-bin_i686-mingw_20101129\bin\x86_64-w64-mingw32-gcc.exe
> -I"C:\Program Files\MPICH2\include" icpi.c -L"C:\Program
> Files\MPICH2\lib" -lmpi -o icpi.exe
> I could get the executable, but it doesn't run with any number of
> processors. When run with mpiexec, it aborts without any message. I
> could run the pre-built "cpi.exe" with any number of CPU's. I don't have
> MS Visual Studio on my machine. Can anyone help?
> By the way, the 32-bit version of MPICH1 (1.2.5 SDK.gcc) works well with
> Mingw-w32 compiler suite.
> Thanks
> Arun
> mpich-discuss mailing list mpich-discuss at mcs.anl.gov https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
