[mpich-discuss] make error with enable-error-checking
Jain, Rohit Rohit_Jain at mentor.com
Mon Feb 28 21:46:13 CST 2011
 1. Let us know which version of gcc (or whatever C compiler) you are
using.
Using built-in specs.
Target: i686-pc-linux-gnu
Configured with: ../configure --disable-nls --enable-languages=c,c++
--host=i686-pc-linux-gnu --target=i686-pc-linux-gnu
--build=i686-pc-linux-gnu --with-gnu-as
--with-as=/binutils-2.19.1-linux/bin/as --with-gnu-ld
--with-ld=/binutils-2.19.1-linux/bin/ld
Thread model: posix
gcc version 4.3.3 (GCC)
 2. Try to build hwloc separately on your system. You can do:
 % cd src/pm/hydra/tools/bind/hwloc/hwloc
 % ./configure && make
It builds fine.
Rohit
