[mpich-discuss] Problems with Barriers on MPICH2-1.3.2p1 on Windows XP and Windows Server 2008
Li Zuwei lzuwei at dso.org.sg
Sun Feb 27 19:18:27 CST 2011
Hi Jayesh,
Firewalls are disabled on the machines. The machines are actually running on VMware ESX3.5 in a intel xeon server. They are physically housed together but logically separated by vmware. No problems with pinging the servers.
Zuwei
-----Original Message-----
From: Jayesh Krishna [mailto:jayesh at mcs.anl.gov]
Sent: Fri 2/25/2011 10:09 PM
To: Li Zuwei
Cc: mpich-discuss at mcs.anl.gov
Subject: Re: [mpich-discuss] Problems with Barriers on MPICH2-1.3.2p1 on Windows	XP and Windows Server 2008
 This could be a firewall issue. Did you turn off Windows firewall on both the machines ?
jayesh
----- Original Message -----
To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
Sent: Thursday, February 24, 2011 8:45:54 PM
Subject: RE: [mpich-discuss] Problems with Barriers on MPICH2-1.3.2p1 on Windows	XP and Windows Server 2008
Thanks for the response, a similar problem occurred for cpi.exe, this time round it lies in MPI_Bcast, with same network errors. What puzzles me is the fact that I could run the program remotely on the other nodes through the
>mpiexec -host remote_node -n 4 cpi.exe
On a program that uses purely Send and Recv commands, I didn't have problems running on multiple nodes using the machinefile.
In the case of network error, are there any settings that I have to take note for windows? Such as DCOM settings, remote access etc. The users for the nodes are all administrators, so I presume there won't be any problems with remote file access and launch of programs.
Zuwei
From: Jayesh Krishna [ mailto:jayesh at mcs.anl.gov ]
Sent: Fri 2/25/2011 12:59 AM
Cc: Li Zuwei
>From the error message it looks like a network connectivity issue (not related to MPI_Barrier()). Can you send us a test program that fails ?
Can you run cpi.exe (c:\program files\MPICH2\examples\cpi.exe) across the nodes ?
Jayesh
Sent: Thursday, February 24, 2011 2:00:53 AM
Subject: [mpich-discuss] Problems with Barriers on MPICH2-1.3.2p1 on Windows XP and Windows Server 2008
Hi users,
I have some issues with MPI_Barrier() on the MPICH2-1.3.2p1 build on Windows.
On a single node, the operation works flawlessly, however when the program is scheduled to run on multiple nodes I get the following errors.
mf.txt
node0:1
node1:1
>mpiexec -machinefile mf.txt -n 2 mpi_test.exe
Fatal error in PMPI_Barrier: Other MPI error, error stack:
PMPI_Barrier(425)...........................: MPI_Barrier(MPI_COMM_WORLD) failed
MPIR_Barrier_impl(331)......................: Failure during collective
MPIR_Barrier_impl(313)......................:
MPIR_Barrier_intra(83)......................:
MPIC_Sendrecv(192)..........................:
MPIC_Wait(540)..............................:
MPIDI_CH3I_Progress(353)....................:
MPID_nem_mpich2_blocking_recv(905)..........:
MPID_nem_newtcp_module_poll(37).............:
MPID_nem_newtcp_module_connpoll(2655).......:
gen_cnting_fail_handler(1738)...............: connect failed - the network location connot be reached. For information about network troubleshooting, see Windows Help.
(errno 1231)
job aborted:
rank: node: exit code[: error message]
0: node0: 123
1: node1: 1: process 1 exited without calling finalize
Additional Notes:
When running against code without any MPI_Barrier calls, no problems with were encountered (ie: on multiple nodes send and recv). Based on that I presume my settings were correct and the problem might lie in the barrier implementation on windows.
Any help to identify the problem here would be great.
Zuwei
mpich-discuss mailing list
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110228/c6e0ec5c/attachment.htm>
