[mpich-discuss] Fatal error in PMPI_Comm_rank
Rajeev Thakur thakur at mcs.anl.gov
Fri Feb 25 10:30:52 CST 2011
Try running the cpi example from the MPICH2 examples directory then.
Make sure that any other parallel libraries linked to your code are also being compiled with the same mpicxx.
Rajeev
On Feb 25, 2011, at 10:28 AM, Hong-Jun Kim wrote:
> I have the same errors with full path of "mpiexec" and even from serial running as follows.
> [hongjun at login01 algs]$ /home/hongjun/lib/mpich2-1.3.2p1/bin/mpiexec -l -n 2 ./test_parallelmesh
> 0: Fatal error in PMPI_Comm_rank: Invalid communicator, error stack:
> 0: PMPI_Comm_rank(109): MPI_Comm_rank(comm=0x0, rank=0x7fff9f927344) failed
> 0: PMPI_Comm_rank(66).: Invalid communicator
> 1: Fatal error in PMPI_Comm_rank: Invalid communicator, error stack:
> 1: PMPI_Comm_rank(109): MPI_Comm_rank(comm=0x0, rank=0x7fffb17b5e74) failed
> 1: PMPI_Comm_rank(66).: Invalid communicator
> rank 0 in job 99  login01.cosmea.mcs.anl.gov_58699   caused collective abort of all ranks
>  exit status of rank 0: return code 1
> [hongjun at login01 algs]$ ./test_parallelmesh
> PMPI_Comm_rank(109): MPI_Comm_rank(comm=0x0, rank=0x7fff418044d4) failed
> Hong-Jun Kim
> Post-doc researcher
> MCS, Argonne National Laboratory
> 9700 S. Cass Ave. B240/R2147
> Argonne, IL 60439
> 630-252-4791
> hongjun at mcs.anl.gov
>> From: "Rajeev Thakur" <thakur at mcs.anl.gov>
>> To: mpich-discuss at mcs.anl.gov
>> Sent: Friday, February 25, 2011 10:20:15 AM
>> Subject: Re: [mpich-discuss] Fatal error in PMPI_Comm_rank
>> Make sure your mpiexec is also from the same place; i.e. look in the
>> test_parallelmesh script and give the full path if necessary.
>> On Feb 25, 2011, at 10:18 AM, Hong-Jun Kim wrote:
>>> Thanks for your reply.
>>> However, I am using "mpicxx" to build my program and it is coming
>>> from the right place as in the following build command line.
>>> /home/hongjun/lib/mpich2-1.3.2p1/bin/mpicxx -pipe -Wall -g -o
>>> test_parallelmesh test_parallelmesh-test_parallelmesh.o
>>> -L/home/hongjun/lib/CGM/lib -L/home/hongjun/lib/OpenCASCADE6.3.0/lib
>>> -L/home/hongjun/lib/mpich2-1.3.2p1/lib -L/usr/lib/gc
>>> c/x86_64-redhat-linux/4.1.2
>>> -L/usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../.. /lib64
>>> -L/lib/../lib64 -L/usr/lib/../lib64
>>> Actually, this program worked for me before, so I have no idea why
>>> this problem is coming now.
>>> Hong-Jun Kim
>>> Post-doc researcher
>>> Argonne, IL 60439
>>> 630-252-4791
>>>> From: "Darius Buntinas" <buntinas at mcs.anl.gov>
>>>> Sent: Thursday, February 24, 2011 9:11:16 PM
>>>> It looks like you might have compiled using an mpi.h of another MPI
>>>> implementation. Make sure you use the compiler wrappers (e.g.,
>>>> mpicc)
>>>> instead of using gcc directly. This will make sure that the correct
>>>> header files are used. Also, you should check to make sure the
>>>> mpicc
>>>> you're using is from the correct MPI implementation too (i.e.,
>>>> "which
>>>> mpicc").
>>>> -d
>>>> On Feb 24, 2011, at 7:29 PM, Hong-Jun Kim wrote:
>>>>> Hello,
>>>>> I compiled my program with "mpich2-1.3.2p1" without any problems
>>>>> as
>>>>> at the end of this e-mail.
>>>>> But, if I execute it, I have some errors I can not understand as
>>>>> follows.
>>>>> Could any body give me any advice about this problem?
>>>>> Thanks.
>>>>> PMPI_Comm_rank(109): MPI_Comm_rank(comm=0x0, rank=0x7fffde36da34)
>>>>> failed
>>>>> [hongjun at login01 algs]$ mpiexec -l -n 2 ./test_parallelmesh
>>>>> stack:
>>>>> rank=0x7fffee4e1464)
>>>>> failed
>>>>> stack:
>>>>> rank=0x7fff6055a9c4)
>>>>> failed
>>>>> rank 1 in job 98 login01.cosmea.mcs.anl.gov_58699 caused
>>>>> collective
>>>>> abort of
>>>>> all ranks
>>>>> exit status of rank 1: return code 1
>>>>> test_parallelmesh
>>>>> test_parallelmesh-test_parallelmesh.o -L/home/hongjun/lib/CGM/lib
>>>>> -L/home/hongj
>>>>> un/lib/OpenCASCADE6.3.0/lib -L/home/hongjun/lib/mpich2-1.3.2p1/lib
>>>>> -L/usr/lib/gc
>>>>> /lib64 -L/lib/../lib64 -L/usr/lib/../lib64
>>>>> ../../src/.libs/libMeshKit.a -L/home/
>>>>> hongjun/lib/Lasso/lib -L/home/hongjun/lib/MOAB/lib
>>>>> -L/home/hongjun/lib/camal.5.1
>>>>> .0-Linux64/lib/Linux64 ../../camal/.libs/libMKcamal.a
>>>>> -lCMLEdgeMesher -lCMLTet -
>>>>> lCMLSweep -lCMLDelTri -lCMLTri -lCMLSurfMapper -lCMLPave
>>>>> -lCMLSizer
>>>>> -lc -lgcc_s
>>>>> -lmpichcxx -lmpich -lrt -lstdc++
>>>>> /home/hongjun/lib/mpich2-1.3.2p1/lib/libopa.so
>>>>> -lpthread /home/hongjun/lib/mpich2-1.3.2p1/lib/libmpl.so -ldl
>>>>> /home/hongjun/lib/
>>>>> Lasso/lib/libiRel.a /home/hongjun/lib/CGM/lib/libiGeom.a
>>>>> lib/libiMesh.a /home/hongjun/lib/MOAB/lib/libMOAB.a
>>>>> bcgm.a /home/hongjun/lib/OpenCASCADE6.3.0/lib/libTKSTL.so
>>>>> CASCADE6.3.0/lib/libTKSTEP.so -lm -Wl,--rpath
>>>>> -Wl,/home/hongjun/lib/mpich2-1.3.2p1/lib -Wl,--rpath -Wl,/home/h
>>>>> ongjun/lib/OpenCASCADE6.3.0/lib -Wl,--rpath
>>>>> /lib -Wl,--rpath -Wl,/home/hongjun/lib/OpenCASCADE6.3.0/lib
>>>>> Hong-Jun Kim
>>>>> Post-doc researcher
>>>>> Argonne, IL 60439
>>>>> 630-252-4791
>>>>> _______________________________________________
>>>>> mpich-discuss mailing list
>>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
