[mpich-discuss] Fatal error in PMPI_Comm_rank
Hong-Jun Kim hongjun at mcs.anl.gov
Fri Feb 25 10:18:18 CST 2011
Thanks for your reply.
However, I am using "mpicxx" to build my program and it is coming from the right place as in the following build command line.
/home/hongjun/lib/mpich2-1.3.2p1/bin/mpicxx -pipe -Wall -g -o
test_parallelmesh test_parallelmesh-test_parallelmesh.o -L/home/hongjun/lib/CGM/lib -L/home/hongjun/lib/OpenCASCADE6.3.0/lib -L/home/hongjun/lib/mpich2-1.3.2p1/lib -L/usr/lib/gc c/x86_64-redhat-linux/4.1.2 -L/usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../.. /lib64 -L/lib/../lib64 -L/usr/lib/../lib64
Actually, this program worked for me before, so I have no idea why this problem is coming now.
Hong-Jun Kim
Post-doc researcher
MCS, Argonne National Laboratory
9700 S. Cass Ave. B240/R2147
Argonne, IL 60439
630-252-4791
----- Original Message -----
> From: "Darius Buntinas" <buntinas at mcs.anl.gov>
> To: mpich-discuss at mcs.anl.gov
> Sent: Thursday, February 24, 2011 9:11:16 PM
> Subject: Re: [mpich-discuss] Fatal error in PMPI_Comm_rank
> It looks like you might have compiled using an mpi.h of another MPI
> implementation. Make sure you use the compiler wrappers (e.g., mpicc)
> instead of using gcc directly. This will make sure that the correct
> header files are used. Also, you should check to make sure the mpicc
> you're using is from the correct MPI implementation too (i.e., "which
> mpicc").
> -d
> On Feb 24, 2011, at 7:29 PM, Hong-Jun Kim wrote:
> > Hello,
> > I compiled my program with "mpich2-1.3.2p1" without any problems as
> > at the end of this e-mail.
> > But, if I execute it, I have some errors I can not understand as
> > follows.
> > Could any body give me any advice about this problem?
> > Thanks.
> > [hongjun at login01 algs]$ ./test_parallelmesh
> > Fatal error in PMPI_Comm_rank: Invalid communicator, error stack:
> > PMPI_Comm_rank(109): MPI_Comm_rank(comm=0x0, rank=0x7fffde36da34)
> > failed
> > PMPI_Comm_rank(66).: Invalid communicator
> > [hongjun at login01 algs]$ mpiexec -l -n 2 ./test_parallelmesh
> > 0: Fatal error in PMPI_Comm_rank: Invalid communicator, error stack:
> > 0: PMPI_Comm_rank(109): MPI_Comm_rank(comm=0x0, rank=0x7fffee4e1464)
> > failed
> > 0: PMPI_Comm_rank(66).: Invalid communicator
> > 1: Fatal error in PMPI_Comm_rank: Invalid communicator, error stack:
> > 1: PMPI_Comm_rank(109): MPI_Comm_rank(comm=0x0, rank=0x7fff6055a9c4)
> > failed
> > 1: PMPI_Comm_rank(66).: Invalid communicator
> > rank 1 in job 98 login01.cosmea.mcs.anl.gov_58699 caused collective
> > abort of
> > all ranks
> >  exit status of rank 1: return code 1
> > test_parallelmesh
> > -L/home/hongj
> > -L/usr/lib/gc
> > ../../src/.libs/libMeshKit.a -L/home/
> > hongjun/lib/Lasso/lib -L/home/hongjun/lib/MOAB/lib
> > -L/home/hongjun/lib/camal.5.1
> > .0-Linux64/lib/Linux64 ../../camal/.libs/libMKcamal.a
> > -lCMLEdgeMesher -lCMLTet -
> > lCMLSweep -lCMLDelTri -lCMLTri -lCMLSurfMapper -lCMLPave -lCMLSizer
> > -lc -lgcc_s
> > -lmpichcxx -lmpich -lrt -lstdc++
> > /home/hongjun/lib/mpich2-1.3.2p1/lib/libopa.so
> > -lpthread /home/hongjun/lib/mpich2-1.3.2p1/lib/libmpl.so -ldl
> > /home/hongjun/lib/
> > Lasso/lib/libiRel.a /home/hongjun/lib/CGM/lib/libiGeom.a
> > lib/libiMesh.a /home/hongjun/lib/MOAB/lib/libMOAB.a
> > bcgm.a /home/hongjun/lib/OpenCASCADE6.3.0/lib/libTKSTL.so
> > CASCADE6.3.0/lib/libTKSTEP.so -lm -Wl,--rpath
> > -Wl,/home/hongjun/lib/mpich2-1.3.2p1/lib -Wl,--rpath -Wl,/home/h
> > ongjun/lib/OpenCASCADE6.3.0/lib -Wl,--rpath
> > /lib -Wl,--rpath -Wl,/home/hongjun/lib/OpenCASCADE6.3.0/lib
> > Hong-Jun Kim
> > Post-doc researcher
> > Argonne, IL 60439
> > 630-252-4791
> > _______________________________________________
> > mpich-discuss mailing list
> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
