[mpich-discuss] 32-bit 64-bit at the same time with mpi: question
Valerio Martorelli v.martorelli at ids-spa.it
Fri Feb 25 03:06:49 CST 2011
Hi, I've tested the following configurations:
1)compiled as 64-bit : The application starts but while a send/receive
operation it stops. Maybe for the different mpi version
2)compiled as 32-bit: on both systems: it works
Thanks a lot
Il 24/02/2011 17.50, Jayesh Krishna ha scritto:
> Hi,
>   MPICH2 does not currently support heterogeneous systems (you cannot run an MPI job with a mix of 32-bit and 64-bit programs). Please compile myapp as a 32-bit exe on the 64-bit machine and let us know if it works for you.
> Regards,
> Jayesh
> From: "Oleg Gamov"<gamov at kipt.kharkov.ua>
> To: mpich-discuss at mcs.anl.gov
> Sent: Thursday, February 24, 2011 7:50:32 AM
> Subject: Re: [mpich-discuss] 32-bit 64-bit at the same time with mpi:	question
> Hi Valerio,
> I suppose you must have the same MPICH versions for both the PCs. Consequently, the applications must be 32-bit only.
> Best ,
> Oleg
> From: mpich-discuss-bounces at mcs.anl.gov [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Valerio Martorelli
> Sent: Thursday, February 24, 2011 12:59 PM
> Subject: [mpich-discuss] 32-bit 64-bit at the same time with mpi: question
> Hi guys.
> I have a question regarding this situation.
> I have two machines, PC32 and PC64.
> PC32 is a machine with a 32-bit OS installed , whereas PC64 has a 64-bit OS.
> My script is
> mpiexec -hosts 2 PC32 PC64 myapp.exe
> myapp.exe is the my application compiled for 32-bit on the first machine and for 64 bit on the second one.
> Is it possible to launch correctly the application? Or on the second machine the application must be compiled for 32-bit as well.
> Thanks,
> Valerio
> mpich-discuss mailing list
*_Valerio Martorelli_*
*Computational EM and Antenna Design Lab
System Analyst*
*IDS **Ingegneria Dei Sistemi S.p.A -
*URL:___<<<__http://www.idscompany.it/__>>>_
Rome Branch Office:Via Flaminia, 1068 - 00189 Roma - Italy
***Phone*: (+39) 06 33 217 404 *
****e-mail: v.martorelli at ids-spa.it <mailto:p.rossi at ids-spa.it>*
*Capitale Sociale 7.500.000 Euro i.v. – C.C.I.A.A. Pisa, R.E.A. n° 77042
- C.F. 00672210507 – P. IVA (VAT) IT 00672210507**
**Share Capital 7.500.000 euro fully paid – registered at the Pisa
Chamber of Commerce,**R.E.A. n. 77042  –
Tax number and VAT code (IT) 0067221050*
*/This email and any attachments are confidential and is intended only
for the use of the intended //addressee/////*
*/thereof. If you are not the intended addressee, please be aware that
any use, //disclosure//, distribution and/or /*
*/copying of this communication, either whole or partial, //is//strictly
prohibited. If you receive this communication /*
*/in error, please notify the sender immediately and delete it from your
computer.///*
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110225/325fd011/attachment-0001.htm>
