[mpich-discuss] MPICH2 On Windows 64 bit and Mingw-w64 compilers
Jayesh Krishna jayesh at mcs.anl.gov
Tue Feb 22 10:57:35 CST 2011
 It is possible that mingw gcc version 4.4.3 is old (64-bit was in the nascent stage) and does not support 64-bit libs generated from Windows libraries. I test libmpi.a using mingw gcc version 4.6.0 .
Jayesh
----- Original Message -----
To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
Cc: mpich-discuss at mcs.anl.gov
Sent: Tuesday, February 22, 2011 9:31:21 AM
Subject: Re: [mpich-discuss] MPICH2 On Windows 64 bit and Mingw-w64 compilers
Hi Jayesh
I am linking with libmpi.a. I am able to run the code after compiling it
with V4.5.3.
With Best Regards
Arun
On 22-02-2011 20:55, Jayesh Krishna wrote:
> Hi,
>   Are you linking using libmpi.a or mpi.lib ? Are you able to run your code after compiling it with V4.5.3 ?
> Regards,
> Jayesh
> From: "Arun Murthy"<arun.murthy at fluidyn.com>
> To: mpich-discuss at mcs.anl.gov
> Sent: Tuesday, February 22, 2011 7:05:51 AM
> Hi
> I downloaded the MPICH2-1.3.2p1 Windows EM64T/AMD64 (binary) onto my Windows-XP 64bit machine. I tried to use it with two GNU compilers: V4.4.3 and V.4.5.3. Basically, I tried to link the icpi.c example into an executable. With GCC V4.4.3, I get undefined symbols, while with V4.5.3, it works well. Does it mean that, if I want to use GCC V4.4.3, I need to rebuild MPICH2 from the source using the V4.4.3 compiler?
> The output details of my trials are below.
> Thanks for your help.
> With Best Regards
> Arun
> D:\tmp>"C:\Program Files\mingw_443\64bit\bin\gcc.exe" --ver
> Built by Equation Solution<http://www.Equation.com>  .
> Using built-in specs.
> Target: x86_64-pc-mingw32
> Configured with: ../gcc-4.4.3-mingw/configure --host=x86_64-pc-mingw32 --build=x86_64-unknown-linux-gnu --target=x86_64-pc-mingw32 --prefix=/home/gfortran/gcc-home/binary/mingw32/native/x86_64/gcc/4.4.3 --with-gmp=/home/gfortran/gcc-home/binary/mingw32/native/x86_64/gmp --with-mpfr=/home/gfortran/gcc-home/binary/mingw32/native/x86_64/mpfr --with-mpc=/home/gfortran/gcc-home/binary/mingw32/native/x86_64/mpc --with-sysroot=/home/gfortran/gcc-home/binary/mingw32/cross/x86_64/gcc/4.4.3 --with-gcc --with-gnu-ld --with-gnu-as --disable-shared --disable-nls --disable-tls --enable-libgomp --enable-languages=c,fortran,c++ --enable-threads=win32 --disable-win32-registry
> Thread model: win32
> gcc version 4.4.3 (GCC)
> D:\tmp>"C:\Program Files\mingw_443\64bit\bin\gcc.exe" -I"C:\Program Files\MPICH2\include" icpi.c -L"C:\Program Files\MPICH2"\lib -lmpi -o icpi.exe
> C:\DOCUME~1\ns\LOCALS~1\Temp\ccg2hczk.o:icpi.c:(.text+0x76): undefined reference to `MPI_Init'
> C:\DOCUME~1\ns\LOCALS~1\Temp\ccg2hczk.o:icpi.c:(.text+0x87): undefined reference to `MPI_Comm_size'
> C:\DOCUME~1\ns\LOCALS~1\Temp\ccg2hczk.o:icpi.c:(.text+0x98): undefined reference to `MPI_Comm_rank'
> C:\DOCUME~1\ns\LOCALS~1\Temp\ccg2hczk.o:icpi.c:(.text+0xab): undefined reference to `MPI_Get_processor_name'
> C:\DOCUME~1\ns\LOCALS~1\Temp\ccg2hczk.o:icpi.c:(.text+0x142): undefined reference to `MPI_Wtime'
> C:\DOCUME~1\ns\LOCALS~1\Temp\ccg2hczk.o:icpi.c:(.text+0x16c): undefined reference to `MPI_Bcast'
> C:\DOCUME~1\ns\LOCALS~1\Temp\ccg2hczk.o:icpi.c:(.text+0x237): undefined reference to `MPI_Reduce'
> C:\DOCUME~1\ns\LOCALS~1\Temp\ccg2hczk.o:icpi.c:(.text+0x2b4): undefined reference to `MPI_Wtime'
> C:\DOCUME~1\ns\LOCALS~1\Temp\ccg2hczk.o:icpi.c:(.text+0x31b): undefined reference to `MPI_Finalize'
> collect2: ld returned 1 exit status
> D:\tmp>"C:\Program Files\mingw-w64\bin\x86_64-w64-mingw32-gcc.exe" --ver
> COLLECT_GCC=C:\Program Files\mingw-w64\bin\x86_64-w64-mingw32-gcc.exe
> COLLECT_LTO_WRAPPER=c:/program files/mingw-w64/bin/../libexec/gcc/x86_64-w64-min
> gw32/4.5.3/lto-wrapper.exe
> Target: x86_64-w64-mingw32
> Configured with: ../../../build/gcc/src/configure --target=x86_64-w64-mingw32 --prefix=/c/buildbot/mingw-w64/mingw32/mingw-x86-x86_64/build/build/root --with-sysroot=/c/buildbot/mingw-w64/mingw32/mingw-x86-x86_64/build/build/root --enable-languages=all,obj-c++ --enable-fully-dynamic-string --disable-multilib
> Thread model: win32
> gcc version 4.5.3 20110207 (prerelease) (GCC)
> D:\tmp>"C:\Program Files\mingw-w64\bin\x86_64-w64-mingw32-gcc.exe" -I"C:\Program Files\MPICH2\include" icpi.c -L"C:\Program Files\MPICH2"\lib -lmpi -lfmpich2g -
> o icpi.exe
> SUCCESS
> D:\tmp>
> On 11-01-2011 18:53, Arun Murthy wrote:
> Hi Jayesh
> Yes, I linked icpi.o with mpi.lib. Happy to hear that Mingw64 support will be available this month. I can wait for a couple of weeks for the next release. In the meantime, if you want me to test the pre-release version, I would be happy to do that.
> Best regards
> Arun
> On 11-01-2011 17:10, Jayesh Krishna wrote:
> Hi,
> Are you trying to link your code with mpi.lib ? Mingw compilers may not be playing nice with the windows libraries. AFAICT we added support for mingw 64-bit compilers (*.a libraries compatible with mingw 64-bit compilers) after 1.3.1 was released. It should be available in the next release, 1.3.2, due this month.
> (PS: If you need it sooner than that let me know and I can get you a custom build for development purposes)
> Regards,
> Jayesh
> To: "Jayesh Krishna"<jayesh at mcs.anl.gov>
> Sent: Tuesday, January 11, 2011 2:12:01 AM
> Hi Jayesh
> I opened CMD with "Run as administrator" and did the following:
> C:\tmp>"C:\Program Files\MPICH2\bin"\mpiexec.exe -n 2 -localroot c:\tmp\icpi.exe
> Job terminated with following error message:
> Error posting writev, A request to send or receive data was disallowed because the socket had already been shut down in that direction with a previous shutdown call.(10058)
> unable to post a write for the next command,
> sock error: Error = 10058
> unable to post a write of the closed_request command to the parent context.
> unable to close the stdin context.
> state machine failed.
> C:\tmp>"C:\Program Files\MPICH2\bin"\mpiexec.exe -n 2 -localroot -exitcodes c:\tmp\icpi.exe
> rank: node: exit code
> 0: Arun-PC: -1073741819
> 1: Arun-PC: -1073741819
> C:\tmp>"C:\Program Files\MPICH2\bin"\smpd -status
> smpd running on Arun-PC
> Best Regards
> Arun
> On 10-01-2011 22:08, Jayesh Krishna wrote:
> Hi,
> Can you try running the job from an administrator command prompt (Note that opening a command prompt from an administrator account does not give you an admin command prompt. Right-click on the command prompt icon and select "Run as administrator" to get an admin command prompt) and see if it works ?
> Can you also check the status of the MPICH2 process manager (Type "smpd -status" at the command prompt)?
> Regards,
> Jayesh
> From: Arun Murthy<arun.murthy at fluidyn.com>  To: Jayesh Krishna<jayesh at mcs.anl.gov>  Cc: mpich-discuss at mcs.anl.gov Sent: Mon, 10 Jan 2011 01:33:41 -0600 (CST)
> Hi Jayesh
> I tried that. It did not help. Here is the response:
> C:\tmp>"C:\Program Files\MPICH2\bin"\mpiexec.exe -n 2 -localroot icpi.exe
> Unable to open the HKEY_LOCAL_MACHINE\SOFTWARE\MPICH\SMPD\process\6308
> registry key, error 5, Access is denied.
> Unable to open the HKEY_LOCAL_MACHINE\SOFTWARE\MPICH\SMPD\process\808
> registry k ey, error 5, Access is denied.
> When I killed the job by<CTRL>  C, the following messages appeared:
> mpiexec aborting job...
> received suspend command for a pmi context that doesn't exist: unmatched
> id = 1
> job aborted:
> rank: node: exit code[: error message]
> 0: Arun-PC: -1073741819: mpiexec aborting job
> Terminate batch job (Y/N)? y
> When I tried the same thing on the pre-built "cpi.exe", I get the same
> messages that I got with "icpi.exe", but it still works:
> C:\tmp>"C:\Program Files\MPICH2\bin"\mpiexec.exe -n 2 -localroot cpi
> Unable to open the HKEY_LOCAL_MACHINE\SOFTWARE\MPICH\SMPD\process\4544
> Unable to open the HKEY_LOCAL_MACHINE\SOFTWARE\MPICH\SMPD\process\7288
> Enter the number of intervals: (0 quits) 9
> pi is approximately 3.1426214565576127, Error is 0.0010288029678196
> wall clock time = 0.000077
> When I killed this job by<CTRL>  C, the following messages appeared:
> SuspendThread failed with error 5 for process
> 0:33FB034C-A281-4d45-9189-9DDCDC33C941:'cpi'
> unable to suspend process.
> unable to read the cmd header on the pmi context, Error = -1.
> Error posting readv, An existing connection was forcibly closed by the
> remote host.(10054)
> 1:33FB034C-A281-4d45-9189-9DDCDC33C941:'cpi'
> remote host.(10054)
> received kill command for a pmi context that doesn't exist: unmatched id = 0
> job aborted:
> 0: Arun-PC: 123: process 0 exited without calling finalize
> 1: Arun-PC: 123: process 1 exited without calling finalize
> Does it have anything to do with an incorrect node (-1073741819) on
> which mpiexec is trying to launch the processes? Thanks for your help.
> Best Regards
> Arun
> On 07-01-2011 22:11, Jayesh Krishna wrote:
> Hi,
> Can you try running your program with the "-localroot" option and let us know if it works for you (mpiexec -n 2 -localroot icpi.exe)?
> Regards,
> Jayesh
> From: "Arun Murthy"<arun.murthy at fluidyn.com>  To: mpich-discuss at mcs.anl.gov Sent: Friday, January 7, 2011 12:56:17 AM
> Subject: [mpich-discuss] MPICH2 On Windows 64 bit and Mingw-w64 compilers
> Hi
> I am trying to use MPICH2 on Windows 7 64bit (installed from
> mpich2-1.3.1-win-x86-64.msi) along with Mingw-w64 compiler suite
> (mingw-w64-1.0-bin_i686-mingw_20101129).
> I tried to compile-link the example "icpi.c" using following command:
> C:\MinGW\mingw-w64-1.0-bin_i686-mingw_20101129\bin\x86_64-w64-mingw32-gcc.exe
> Files\MPICH2\lib" -lmpi -o icpi.exe
> I could get the executable, but it doesn't run with any number of
> processors. When run with mpiexec, it aborts without any message. I
> could run the pre-built "cpi.exe" with any number of CPU's. I don't have
> MS Visual Studio on my machine. Can anyone help?
> By the way, the 32-bit version of MPICH1 (1.2.5 SDK.gcc) works well with
> Mingw-w32 compiler suite.
> Thanks
> Arun
> mpich-discuss mailing list mpich-discuss at mcs.anl.gov https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
