[mpich-discuss] Fatal error in PMPI_Reduce: Other MPI error, error stac
T.R. Sanderson trs38 at cam.ac.uk
Tue Feb 22 07:53:31 CST 2011
Just noticed something rather odd - if I specify a port range using
export MPICH_PORT_RANGE=50001:59999
the process just hangs after saying:
[1] Process 1 of 2 is on node2
[0] Process 0 of 2 is on node1
And both processes continue to use 100% CPU until I kill the program. Does
that explain anything? If I don't specify ports it gives the same message
given before.
Best
Theo
On Feb 22 2011, Pavan Balaji wrote:
>Here's an entry on the FAQ that describes this:
> http://wiki.mcs.anl.gov/mpich2/index.php/Frequently_Asked_Questions#Q:_My_MPI_program_aborts_with_an_error_saying_it_cannot_communicate_with_other_processes
>  -- Pavan
>On 02/21/2011 06:03 PM, T.R. Sanderson wrote:
>> Hello, I've been testing my MPICH2 installation with cpi and am having
>> some issues. Cpi runs fine on either computer. If I add two nodes to my
>> hosts file I receive the error below, if I only have one node in the
>> host file it runs happily even if executed via MPI.
>> I would be very grateful for any advice, if you would like the verbose
>> output just let me know.
>> Many thanks,
>> Theo
>> trs38 at node0:~$ mpiexec.hydra -l -n 2 /root/mpich2-1.3.2/examples/cpi
>> [1] Process 1 of 2 is on node2 [0] Process 0 of 2 is on node1 [0] Fatal
>> error in PMPI_Reduce: Other MPI error, error stack: [0]
>> PMPI_Reduce(1322)...............: MPI_Reduce(sbuf=0x7fffbfe9d028,
>> rbuf=0x7fffbfe9d020, count=1, MPI_DOUBLE, MPI_SUM, root=0,
>> MPI_COMM_WORLD) failed [0] MPIR_Reduce_impl(1139)..........: [0]
>> MPIR_Reduce_intra(947)..........: [0] MPIR_Reduce_binomial(176).......:
>> [0] MPIDI_CH3U_Recvq_FDU_or_AEP(380): Communication error with rank 1
>> [mpiexec at node0] ONE OF THE PROCESSES TERMINATED BADLY: CLEANING UP
>> [proxy:0:1 at node2] HYD_pmcd_pmip_control_cmd_cb
>> (./pm/pmiserv/pmip_cb.c:868): assert (!closed) failed [proxy:0:1 at node2]
>> HYDT_dmxu_poll_wait_for_event (./tools/demux/demux_poll.c:77): callback
>> returned error status [proxy:0:1 at node2] main (./pm/pmiserv/pmip.c:208):
>> demux engine error waiting for event APPLICATION TERMINATED WITH THE
>> EXIT STRING: Hangup (signal 1)
>> mpich-discuss mailing list
>> mpich-discuss at mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
