[mpich-discuss] Regarding ROMIO package installation with MPICH2 and LAM-MPI
Pascal Deveze Pascal.Deveze at bull.net
Mon Feb 21 09:04:45 CST 2011
Why do you specify -cc=mpicc -fc=mpif90 ?
I mean you have to specify compilers, not MPI compilers.
Pascal
shraddha a écrit :
> Dear Sir,
>             I have tried to install ROMIO with MPICH2 with following
> configure command.
> *romio-1.2.5.1]$ ./configure
> --prefix=/home/shraddha/MPICH2/gnu/romio-1.2.5.1 -mpi=mpich
> -file_system=ufs+nfs -mpiincdir=/share/apps/mpich2/gnu/include
> -mpibindir=/share/apps/mpich2/gnu/bin -cc=mpicc -fc=mpif90 2>&1 | tee
> LOG-config-3*
> *Successful configuration, but make giving error*
> *Make Error:*
> mpicc -O -DFORTRANUNDERSCORE -DHAVE_ROMIOCONF_H
> -I/share/apps/mpich2/gnu/include
> -I/home/kmathur/MPICH2/gnu/romio-1.2.5.1/mpi-io -I../include
> -I/home/kmathur/MPICH2/gnu/romio-1.2.5.1/mpi-io/../adio/include
> -I../adio/include -c iread.c
> iread.c: In function 'PMPI_File_iread':
> iread.c:132: warning: passing argument 7 of
> 'fh->fns->ADIOI_xxx_IreadContig' from incompatible pointer type
> iread.c:138: warning: assignment makes integer from pointer without a cast
> iread.c:139: error: invalid type argument of '->'
> iread.c:140: error: invalid type argument of '->'
> iread.c:141: error: invalid type argument of '->'
> iread.c:142: error: invalid type argument of '->'
> iread.c:143: error: invalid type argument of '->'
> iread.c:162: warning: passing argument 7 of
> 'fh->fns->ADIOI_xxx_IreadStrided' from incompatible pointer type
> make[2]: *** [iread.o] Error 1
> make[2]: Leaving directory `/home/kmathur/MPICH2/gnu/romio-1.2.5.1/mpi-io'
> Make failed in directory mpi-io
> make[1]: *** [mpiolib] Error 1
> make[1]: Leaving directory `/home/kmathur/MPICH2/gnu/romio-1.2.5.1'
> make: *** [mpio] Error 2
> I am trying to configure ROMIO with lam-mpi but getting error at
> configure stage:
> *romio-1.2.5.1]$ ./configure*
> --prefix=/share/apps/ROMIO/LAMMPI/gnu/gnu-412 -mpi=lam_mpi
> -mpiincdir=/share/apps/LAM-MPI/gnu/gnu-412/include
> -mpilib=/share/apps/LAM-MPI/gnu/gnu-412/lib/libmpi.a -cc=mpicc -fc=mpif90
> checking if a simple MPI program compiles and links...
> *# Unable to compile a simple MPI program
> *# Use the -mpi, -mpiincdir, and -mpilib options to configure to
> specify the
> *# MPI implementation, the include path for mpi.h, and the MPI library
> to link
> Can you please tell me the proper way to install ROMIO with both
> MPICH2 and LAM-MPI??
> How can I create libmpio.a ?? which will be useful to compile MPI-IO
> programs.
> Your help would be greatly appreciable for me.
> Regards,
> Shraddha Desai
> This message has been scanned for viruses and
> dangerous content by *MailScanner* <http://www.mailscanner.info/>, and is
> believed to be clean.
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110221/8dcb411d/attachment.htm>
