[mpich-discuss] How to config mpiexec use rsh as default bootstrap?
Limin Gu lgu at penguincomputing.com
Fri Feb 18 15:52:05 CST 2011
Thanks Pavan!
I would like to have the r7942 fix, but it failed to patch
src/pm/hydra/tools/bootstrap/src/bsci_init.c.in, I looked at the rej file,
the code changed since 1.3.2 release, without understanding what it is
doing, I am unable to manually fix it.
I tried to replace that file with new file, but I got segmemtation fault.
Is there a way I can get a patch based on v1.3.2?
Thanks again!
Limin
On Fri, Feb 18, 2011 at 3:44 PM, Pavan Balaji <balaji at mcs.anl.gov> wrote:
> On 02/18/2011 02:19 PM, Limin Gu wrote:
>> I replaced hydra directory with the latest hydra code, this worked. But
>> the diff with 1.3.2 is pretty big, will you have a new release soon?
> We are working on the 1.3.3 release, planned for mid-April. But if you need
> the specific patches to fix the problems you are seeing, they are below:
> https://trac.mcs.anl.gov/projects/mpich2/changeset/7942/mpich2/trunk/src/pm/hydra
> https://trac.mcs.anl.gov/projects/mpich2/changeset/7887/mpich2/trunk/src/pm/hydra
>  -- Pavan
> Pavan Balaji
> http://www.mcs.anl.gov/~balaji
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110218/8924bc03/attachment.htm>
