[mpich-discuss] Error when compiling with mpif90
Anthony Chan chan at mcs.anl.gov
Mon Feb 14 11:35:55 CST 2011
I personally never heard anyone complaining mpif90+gfortran on Mac,
but it does not mean much. This seems to be a compiler/mac issue,
you may want to post your question on gnu's or mac's relevant emailing
lists.
A.Chan
----- Original Message -----
> Hi,
> Thanks, the offending compile option was -mcmodel=large. When I remove
> it or
> replace large with medium, my code compiles, links, and runs. I do
> need this
> option though for larger simulations. Has anyone had problems with
> this
> option creating errors before with mpif90 and gfortran?
> Brandt
> > Message: 2
> > Date: Mon, 14 Feb 2011 00:25:30 -0600 (CST)
> > From: Anthony Chan <chan at mcs.anl.gov>
> > Subject: Re: [mpich-discuss] Error when compiling with mpif90
> > To: mpich-discuss at mcs.anl.gov
> > Message-ID:
> >        <1740950378.50947.1297664730569.JavaMail.root at zimbra.anl.gov>
> > Content-Type: text/plain; charset=utf-8
> > Everything makes sense now.
> > > $ mpif90 -fdefault-real-8 -O3 -fdollar-ok -fmax-errors=6
> > > -fconvert=big-endian -frecord-marker=4 -cpp -mcmodel=large -DMPI
> > > -I/usr/local/mpich2/include -L/usr/local/mpich2/lib -c bla.f
> > With mpif90, you don't need
> > "-I/usr/local/mpich2/include -L/usr/local/mpich2/lib"
> > which will be taken care of by mpif90.
> > > I hope everything's clear now, and thank you for your help,
> > Have you tried to compile your code on linux with mpich2 built by
> > gcc+gfortran ? I would try to eliminate flags in "-fdefault-real-8
> > -O3 -fdollar-ok -fmax-errors=6 -fconvert=big-endian
> > -frecord-marker=4
> > -cpp -mcmodel=large" one by one to see which causes the error...
> > A.Chan
> mpich-discuss mailing list
