[mpich-discuss] Problem with spawning child with same executable name
Pavan Balaji balaji at mcs.anl.gov
Sat Feb 12 10:05:01 CST 2011
I dug into the code and looked into this. I agree this is a problem and
needs to be fixed, but it requires ripping out a lot of the code, and
modifying the internal algorithm used significantly.
This is not a quick fix, so I created a ticket for it:
https://trac.mcs.anl.gov/projects/mpich2/ticket/1434
Please add yourself to the CC list if you are interested.
Thanks for reporting the issue.
  -- Pavan
On 02/10/2011 08:41 PM, Yauheni Zelenko wrote:
> Hi, Pavan!
> I added some debugging output with timestamps.
> New set of children spawned after previous set of children call MPI_Finalize. However all processes exited only after mater terminated.
> I definitely could lead to more resource usage in supposed program usage since children still some amount of system resources.
> Also I'm not sure that at this stage Hydra will have enough information to launch new child processes on freed hosts.
> Eugene.
> From: Pavan Balaji [balaji at mcs.anl.gov]
> Sent: Wednesday, February 09, 2011 2:31 PM
> To: Yauheni Zelenko
> Cc: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] Problem with spawning child with same executable name
> So the first set of spawned processes have terminated before the next set is started, is it?
> Pavan Balaji @ iPhone
> (Big fingers. Small email.)
> On Feb 9, 2011, at 2:20 PM, Yauheni Zelenko<zelenko at cadence.com>  wrote:
>> But there is still living process on host1. I think accounting fact this will be more correct Hydra behaviour.
>> Eugene.
>> Sent: Wednesday, February 09, 2011 2:11 PM
>> To: mpich-discuss at mcs.anl.gov
>> Cc: Yauheni Zelenko
>> On 02/09/2011 04:06 PM, Yauheni Zelenko wrote:
>>> Then I run program with Hydra: mpiexec -host "host1:2,host2:2"
>>> Master process is run on host1. At first spawn 1 child was run on
>>> host1 and 2 on host2, but on consequent spawns, 2 children was on
>>> host1 and 1 on host2.
>>> I think such resources allocation may create balancing problems and
>>> Hydra should not spawn children processes on hosts still in use.
>> That sound correct to me. Hydra looks at the host list as:
>> host1, host1, host2, host2, ..., [wrap around].
>> The master process is launched on the first "host1". When you spawn
>> three processes the first time, it launches them on "host1", "host2",
>> and "host2". When you spawn three processes the second time, it launches
>> them on "host1", "host1", "host2". The next spawn of three processes
>> will be "host2", "host1", "host1", etc.
>>   -- Pavan
>> Pavan Balaji
>> http://www.mcs.anl.gov/~balaji
>> mpich-discuss mailing list
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
Pavan Balaji
