[mpich-discuss] Error while connecting to host
Manjunatha manjunathas at nous.soft.net
Fri Feb 11 07:52:41 CST 2011
HI Jayesh,
My window system is a dual processor and hence I am trying to run MPI on both the processor.
I did it successfully few months back. Now it is causing the problem... I have not changed the system configuration till then.. so I confused with what is wrong with this now..
I have used following command to run;
mpiexec    -hosts 1 localhost 1 -noprompt myprog.exe
c:\worker  -hosts 1 localhost 1 -noprompt myprog.exe
1st line command is to execute on a manger node
2nd line command is to execute on a worker node
saved both the commands in a text file then read it.
Best regards,
Manju
-----Original Message-----
From: Jayesh Krishna [mailto:jayesh at mcs.anl.gov]
Sent: Friday, February 11, 2011 7:01 PM
Cc: Manjunatha Shivaiah
Subject: Re: [mpich-discuss] Error while connecting to host
 What do you mean by a single system with two nodes ? Is it a Windows cluster with two nodes ? How are you running your program (Copy-paste the mpiexec command and the output in your next email)?
Jayesh
----- Original Message -----
Sent: Friday, February 11, 2011 7:02:15 AM
Firewall disabled… but still the problem is same..
I am running MPI on windows XP
Best regards,
Manju
From: mpich-discuss-bounces at mcs.anl.gov [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Mandar Gurav
Sent: Friday, February 11, 2011 5:59 PM
Seems that problem with firewall / SELinux...
Try using
Firewall - Disabled...
SELinux - Disabled...
I hope this will help you....
---Mandar Gurav
On Fri, Feb 11, 2011 at 5:24 PM, Manjunatha < manjunathas at nous.soft.net > wrote:
I am getting following error messages when I try to execute my program using MPI, on single system with 2 nodes.
[01:1064]..ERROR:Error while connecting to host, No connection could be made because the target machine actively refused it. (10061)
[01:5920]..ERROR:Error while connecting to host, No connection could be made because the target machine actively refused it. (10061)
Any help to solve this error is highly appreciated.
Best regards,
Manju
NOUS INFOSYSTEMS DISCLAIMER :
This e-mail transmission may contain confidential or legally privileged information that is intended only for the individual(s) or entity(ies) named in the e-mail address. If you are not the intended recipient, please reply to the postmaster at nous.soft.net , so that arrangements can be made for proper delivery, and then please delete all copies and attachments. Any disclosure, copying, distribution, or reliance upon the contents of this e-mail, by any other than the intended recipients, is strictly prohibited.
mpich-discuss mailing list
Mandar Gurav
http://www.mandargurav.org
This e-mail transmission may contain confidential or legally privileged information that is intended only for the individual(s) or entity(ies) named in the e-mail address. If you are not the intended recipient, please reply to the postmaster at nous.soft.net, so that arrangements can be made for proper delivery, and then please delete all copies and attachments. Any disclosure, copying, distribution, or reliance upon the contents of this e-mail, by any other than the intended recipients, is strictly prohibited.
