[mpich-discuss] Strange MPI_Recv error
Jayesh Krishna jayesh at mcs.anl.gov
Fri Feb 11 07:34:13 CST 2011
 Can you send us a test program (source code) that fails ?
Jayesh
----- Original Message -----
Sent: Friday, February 11, 2011 12:14:49 AM
Subject: Re: [mpich-discuss] Strange MPI_Recv error
PS:
When the code error is reported at iteration n, if I restart the program at iteration n-1, then everything goes fine for several iteration rounds. Then, the error occurs again.
On Fri, Feb 11, 2011 at 12:59 AM, Xiao Li < shinelee.thewise at gmail.com > wrote:
I use a small MPI program and get the following error.
Fatal error in MPI_Recv: Other MPI error, error stack:
MPI_Recv(186)........................: MPI_Recv(buf=0012FA20, count=1, MPI_INT,
src=MPI_ANY_SOURCE, tag=5, MPI_COMM_WORLD, status=0012FA80) failed
MPIDI_CH3I_Progress(335).............:
MPID_nem_mpich2_blocking_recv(906)...:
MPID_nem_newtcp_module_poll(37)......:
MPID_nem_newtcp_module_connpoll(2655):
gen_read_fail_handler(1145)..........: read from socket failed - The specified network name is no longer available.
The code framework is something like this below.
if rank == 0
for iter=1 to N
MPI_Recv any
get proc rank from status
MPI_Send proc
end
else
for iter=1 to N
MPI_Send to 0
MPI_Recv from 0
do some computation here
end
I do check my code carefully. And I even rewrite the core computation code in a series way. Then I get no error. Even more strange is that the code will crash at different for loop iteration. I suspect the MPI can not work in my network environment. The network is composed by four Windows XP machines with 100/mbps Ethernet network. Would you help me on this issue?
cheers
Xiao
mpich-discuss mailing list
