[mpich-discuss] Fatal error in MPI_Init
Jayesh Krishna jayesh at mcs.anl.gov
Tue Feb 8 15:13:59 CST 2011
 You can create a text file (e.g., mf.txt) containing the ip addresses of the two PCs and pass it to mpiexec (Assuming you have your MPI programs in c:\temp on the Windows machine and /home/gustavo/temp on the Centos machine use the following command to execute your job, mpiexec -n 2 -machinefile mf.txt -path c:\temp;/home/gustavo/temp mympipgm.exe).
 You can find more details in the "Windows developer's guide" (http://www.mcs.anl.gov/research/projects/mpich2/documentation/index.php?s=docs) and the "User's guide".
Jayesh
----- Original Message -----
To: jayesh at mcs.anl.gov
Sent: Tuesday, February 8, 2011 11:48:31 AM
Subject: FW: [mpich-discuss] Fatal error in MPI_Init
Hi Jayesh:
Could You give me an example of how must I write the file to use with mpiexec -machinefile?
Remember that I have 2 PCs:
PC1 (Windows XP) --> 126.1.20.168 (this will be the master)
PC2 (Centos 5.5) --> 126.1.20.169
Gustavo Uribe
Subject: RE: [mpich-discuss] Fatal error in MPI_Init
Date: Thu, 3 Feb 2011 17:00:50 -0300
Hi Jayesh:
apologize for my english and my ignorance with Linux.
But I have not idea of what are you telling me: how must I execute the command "./configure --with-pm=smpd"?
I wrote that command in the console, and the result was: "No existe el fichero o el directorio" (the file or directory doesn't exist).
Must I enter into a directory?
Gustavo Uribe
> Date: Thu, 3 Feb 2011 09:47:35 -0600
> From: jayesh at mcs.anl.gov
> To: gustfuribe at hotmail.com
> CC: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] Fatal error in MPI_Init
> Hi,
> You can run your MPI jobs across Windows and Linux machines. However you need to make sure that the machines are homogeneous (The same architecture - or more precisely follow the same data model).
> The only process manager available on Windows is SMPD. The default process manager available with MPICH2 on Unix is Hydra.
> Try reconfiguring MPICH2 on Unix with the SMPD process manager (./configure ... --with-pm=smpd ...) and let us know if it works for you.
> (PS: Please also make sure that you have Windows and Linux binaries available on the respective nodes.)
> Regards,
> Jayesh
> From: "Gustavo Uribe" <gustfuribe at hotmail.com>
> Sent: Wednesday, February 2, 2011 3:01:21 PM
> Hello Jayesh:
> now I'm trying to connect PC1 and PC2 with differents Operating Systems.
> PC1: Windows XP
> PC2: Centos 5.5
> Is it possible?
> At this moment I have configured the IPs:
> PC1 (Windows) --> 126.1.20.168
> PC2 (Centos) --> 126.1.20.169
> I can PING the machines, so both PCs are connected.
> But I can't use the command "mpiexec -hosts 2 126.1.20.168 126.1.20.169 helloworld.exe"
> I get the following message:
> abort: Unable to connect to '126.1.20.169:8676'
> sock error: Error = -1
> What is the problem?
> Will I need to use the new version of MPICH?
> Thanks,
> Gustavo
> > Date: Mon, 31 Jan 2011 15:30:44 -0600
> > Hi,
> > Good to know MPICH2 is working for you now.
> > Typically Infiniband adapters allow you to run TCP/IP apps above IB (They support TCP/IP sockets). Looking at the error message that you got it looked like the particular Infiniband adapter did not provide a service provider for TCP/IP apps. Anyway, good to know it is working for you now.
> > The next release of MPICH2 will include a channel (nd) that supports IB (mpiexec -n 2 -channel nemesis:nd mympipgm.exe would work). You might want to try that out.
> > Regards,
> > Jayesh
> > Sent: Monday, January 31, 2011 3:12:20 PM
> > Jayesh:
> > I appreciate your quick response!
> > Finally I could run the "HelloWorld" program!
> > The problem was that I was not running smpd.exe in the 2nd PC.
> > Maybe MPICH2 libraries supports the "Mellanox" InfiniBand adapters I have on both PCs.
> > Now, I can run: mpiexec -hosts 126.1.20.168 126.1.20.169 HelloWorld.exe
> > and it functions!!!
> > I don't know how, but it functions!
> > Thanks,
> > Gustavo Uribe
> > > Date: Mon, 31 Jan 2011 09:33:47 -0600
> > > Hi,
> > > >> Can you provide a custom build for me? how much would it cost? or would it be free ?
> > > MPICH2 is open-source and available at no cost (free). I can provide a custom build for you, however we recommend all users to use stable releases for production environments. Also, the version that I provide you will be an experimental support for Network Direct (performance tuning is in the works... and I haven't had a chance to run it on a large system to weed out all the bugs.).
> > > I would recommend buying "Using MPI" (http://www.mcs.anl.gov/research/projects/mpi/usingmpi/) or any other introductory book on getting started with MPI. There is also a lot of material on MPI if you google for it.
> > > I will provide you a custom build in a couple of days.
> > > Regards,
> > > Jayesh
> > > Sent: Sunday, January 30, 2011 5:26:47 PM
> > > Jayesh:
> > > thanks for your quick response !
> > > I'm a little complicated with time , I need it soon .
> > > I'm just getting started with MPI, and InfiniBand networks . That's why I wanted to ask if you can send me a manual or tutorial where I can learn a little more about it .
> > > Thanks,
> > > Gustavo Uribe
> > > > Date: Fri, 28 Jan 2011 15:59:22 -0600
> > > > To: mpich-discuss at mcs.anl.gov
> > > > CC: gustfuribe at hotmail.com
> > > > Hi,
> > > > It looks like the adapter (driver) does not allow creating TCP/IP sockets (There is no service provided for TCP/IP).
> > > > The next version of MPICH2 on Windows will have a Network Direct module that should allow you to run your application over Infiniband. I don't know when the next version will be out (~ 1-2 months), if you need it sooner please let me know and I can provide a custom build for you.
> > > > (PS: Currently MPICH2 on Windows has support for only plain TCP/IP sockets. It does not support Winsock direct or Network Direct.)
> > > > Regards,
> > > > Jayesh
> > > > Sent: Friday, January 28, 2011 10:52:41 AM
> > > > Subject: [mpich-discuss] Fatal error in MPI_Init
> > > > Hello everybody!
> > > > I'm newbie with MPI, so I think I need your help!
> > > > I want to tell you what is my problem:
> > > > I have 2 computers connected with Infiniband adapters. On both PCs I'm running Windows XP, and I have installed the correspondent drivers. Then I configured the subnet, and it's possible for me to ping one PC with the other.
> > > > After that, I installed MPICH2 (for Windows).
> > > > I want to run a simple "Hello World" program (programmed in C), but in the moment when I want to run the program using MPIEXEC, I obtain the following message:
> > > > Fatal error in MPI_Init: Other MPI error, error stack:
> > > > MPIR_Init_thread<388>..........:
> > > > MPID_Init<315>.................: channel initialization failed
> > > > MPDIDI_CH3_Init<38>............:
> > > > MPID_nem_init<234>.............:
> > > > MPID_nem_newtcp_module_init<90>:
> > > > MPID_nem_newtcp_module_init<89>: unable to create a socket. No se puede cargar o inicializar el proveedor de servicios solicitado.
> > > > <errno 10106>
> > > > Am I doing something wrong?
> > > > Please! Help me! I'm newbie with MPI.
> > > > Thanks!
> > > > Gustavo
> > > > >From Bariloche (Argentina)
> > > > _______________________________________________
> > > > mpich-discuss mailing list
> > > > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
