[mpich-discuss] undefined symbol: MPIR_Thread
Gus Correa gus at ldeo.columbia.edu
Mon Feb 7 15:14:29 CST 2011
Anthony Chan wrote:
> What mechanism does CCSM use to launch the various climate models, e.g. POP ?
>> It seems that mpi_comm_spawn is not used.
>> I have tried with the nm and find command, changing the suffixes, but
>> there are no results....
>> On 02/07/2011 06:34 PM, Anthony Chan wrote:
>>> find<path_to_ccsm> -name \*.f -exec grep -Hi MPI_Comm_spawn {} \;
>> FWO Post-doctoral Research Fellow
>> Department of Earth& Environmental Sciences
>> Physical and Regional Geography Research Group
>> Regional climate studies
>> Celestijnenlaan 200E
>> 3001 Heverlee (Leuven)
>> BELGIUM
>> Tel: + 32 16 326424
>> Fax: + 32 16 322980
>> http://geo.kuleuven.be/aow/
>> www.kuleuven.be/geography
Hi Anthony, Matthias
Anthony:
It is now SPMD, a sigle executable (cesm.exe).
(Older versions were MPMD.)
Matthias:
Did you do 'ldd cesm.exe'?
What is the output?
Maybe I missed it, I saw only your 'ldd mpiexec' posted here.
I wonder if the use of NetCDF4 could be the problem,
via a dependency on HDF5 libraries,
and perhaps a dependency on an yet unnamed version of MPI,
if parallel IO was enabled there.
Did you try cesm with Netcdf3?
Works for me.
My two cents,
Gus Correa
