[mpich-discuss] MPI_Send Error
Mandar Gurav mandarwce at gmail.com
Wed Feb 2 06:20:54 CST 2011
Program is also fine... Working correctly at my end!
----Mandar Gurav
On Wed, Feb 2, 2011 at 5:47 PM, Mandar Gurav <mandarwce at gmail.com> wrote:
> Try to execute the program using
> "mpiexec  -n 2 ./test.x" only
> or can you tell what is there in your "hosts" (Described in command
> "mpiexec -f *hosts* -n 2 ./test.x*"*) file
> ----Mandar Gurav
> On Wed, Feb 2, 2011 at 4:38 PM, Deniz DAL <dendal25 at yahoo.com> wrote:
>>  Hello everyone,
>> I created a small linux cluster with 4 compute nodes yesterday. I
>> installed Fedora 14 OS to all machine and mpich2 v1.3.2 on the server node.
>> But i have a serious problem. I can not even make a simple send and receive
>> program work. below is the steps that i follow. You will see the error at
>> the end. I can not run point to point and collective communication routines
>> of mpi. I am suspecting that the problem might have sthg to do with the
>> hydra. Any help is appreciated.
>> Deniz.
>> *[ddal at admin mpi_uygulamalar]$ cat hosts
>> admin
>> cn01
>> cn02
>> cn03
>> [ddal at admin mpi_uygulamalar]$ cat 01_Send_Receive_One_Message.cpp
>> #include "mpi.h"
>> #include <iostream>
>> using namespace std;*
>> *#define TAG 25*
>> *int main(int argc, char* argv[])
>>  int myRank,
>>          size;*
>> * char processorName[50];
>>  int nameLength;*
>> * int a;//size of the send buffer
>>  int b;*
>> * MPI_Status status;*
>> * /* Initialize MPI */
>>  MPI_Init(&argc, &argv);*
>> * /* Determine the size of the group */
>>  MPI_Comm_size(MPI_COMM_WORLD,&size);*
>> * /* Determine the rank of the calling process */
>>  MPI_Comm_rank(MPI_COMM_WORLD,&myRank);*
>> * MPI_Get_processor_name(processorName, &nameLength);*
>> * if(size != 2 )
>>   cout<<"Number of CPUs must be 2 !\n";
>>   MPI_Abort(MPI_COMM_WORLD, 99);
>> * if(myRank == 0)/* Master Sends a Message */
>>   a=25;*
>> *  MPI_Send(&a, 1, MPI_INT, 1, TAG, MPI_COMM_WORLD);
>>   printf("%s Sent Variable a Successfully\n",processorName);
>>  else /* Process 1 Receives the Message */
>>   MPI_Recv(&b, 1, MPI_INT, 0, TAG, MPI_COMM_WORLD, &status );
>>   printf("%s Received Variable a Successfully over b\n",processorName);
>>   printf("b=%d\n",b);
>> * /* Terminate the MPI */
>>  MPI_Finalize();*
>> * return 0;
>> }[ddal at admin mpi_uygulamalar]$ mpicxx 01_Send_Receive_One_Message.cpp -o
>> test.x
>> [ddal at admin mpi_uygulamalar]$ mpiexec -f hosts -n 2 ./test.x
>> Fatal error in MPI_Send: Other MPI error, error stack:
>> MPI_Send(173)..............: MPI_Send(buf=0xbf928900, count=1, MPI_INT,
>> dest=1, tag=25, MPI_COMM_WORLD) failed
>> MPID_nem_tcp_connpoll(1811): Communication error with rank 1:
>> [mpiexec at admin] ONE OF THE PROCESSES TERMINATED BADLY: CLEANING UP
>> [proxy:0:1 at cn01] HYD_pmcd_pmip_control_cmd_cb
>> (./pm/pmiserv/pmip_cb.c:868): assert (!closed) failed
>> [proxy:0:1 at cn01] HYDT_dmxu_poll_wait_for_event
>> (./tools/demux/demux_poll.c:77): callback returned error status
>> [proxy:0:1 at cn01] main (./pm/pmiserv/pmip.c:208): demux engine error
>> waiting for event
>> APPLICATION TERMINATED WITH THE EXIT STRING: Hangup (signal 1)
>> [ddal at admin mpi_uygulamalar]$ *
>> mpich-discuss mailing list
>> mpich-discuss at mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
> |||| Mandar Gurav ||||
|||| Mandar Gurav ||||
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110202/ac6f35ed/attachment.htm>
