[mpich-discuss] Using __float128 with MPI_Accumulate()?
Sun Dec 25 17:33:14 CST 2011
GCC 4.6 introduced support for quad precision using the __float128 type.
Since __float128 is not part of the MPI standard, PETSc defines new real
and complex MPI_Datatypes for __float128 and we define our own MPI_SUM,
MPI_MAX, etc. This works fine for "normal" reductions, but it's a problem
with MPI_Accumulate() because the standard does not allow user-defined
reduce operations.
Is there any way to work around this limitation other than to not use
MPI_Accumulate() in any context that might some day be asked to work with
__float128?
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20111225/ea1f4f4f/attachment.htm>
