[mpich-discuss] mpi/openmp hybrid seg fault
Anthony Chan chan at mcs.anl.gov
Thu Dec 22 16:32:14 CST 2011
Did you make sure both system and OpenMP runtime
stack sizes are set on all the nodes (not just
the head node) ?
----- Original Message -----
> I tried setting both KMP_STACKSIZE and OMP_STACKSIZE to very large
> values
> (4G then 8G) but still got the same seg fault.
> I tried to compile with gfortran to verify but there are a lot of
> "kind"
> variables that I believe are pinned to ifort (kmp_size_t_kind for
> example).
> When compiling with "-heap-arrays" I still received the same error.
> Just a debugging question, if the stacksize was the problem, would
> that also
> show up when running only on one node (which currently works as long
> as it's
> the same node as where mpiexec is executed from)? Any other ideas?
> Stacksize is already unlimited:
> galloway at tebow:~/Flow3D/hybrid-test$ ulimit -a
> core file size (blocks, -c) 0
> data seg size (kbytes, -d) unlimited
> scheduling priority (-e) 0
> file size (blocks, -f) unlimited
> pending signals (-i) 193087
> max locked memory (kbytes, -l) unlimited
> max memory size (kbytes, -m) unlimited
> open files (-n) 1024
> pipe size (512 bytes, -p) 8
> POSIX message queues (bytes, -q) 819200
> real-time priority (-r) 0
> stack size (kbytes, -s) unlimited
> cpu time (seconds, -t) unlimited
> max user processes (-u) 193087
> virtual memory (kbytes, -v) unlimited
> file locks (-x) unlimited
> -----Original Message-----
> From: mpich-discuss-bounces at mcs.anl.gov
> [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Jeff Hammond
> Sent: Thursday, December 22, 2011 6:26 AM
> To: Anthony Chan; mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] mpi/openmp hybrid seg fault
> The portable equivalent of KMP_STACKSIZE is OMP_STACKSIZE. We have
> found on
> Blue Gene/P that when values of this parameter are too small,
> segfaults
> occur without an obvious indication that this is the problem. I assume
> this
> is not a platform-specific problem.
> The Intel Fortran compiler puts all static arrays on the stack by
> default.
> You can change this. See
> http://software.intel.com/en-us/articles/intel-fortran-compiler-increased-st
> ack-usage-of-80-or-higher-compilers-causes-segmentation-fault/
> for details, but I recommend you use "-heap-arrays". GNU Fortran
> (gfortran) does not have this problem, so recompiling with it is a
> fast way
> to determine if stack allocation - independent of OpenMP - is the
> problem.
> Jeff
> On Thu, Dec 22, 2011 at 1:22 AM, Anthony Chan <chan at mcs.anl.gov>
> >> The fact that I need this to work for the much larger problem is
> >> why
> >> simply changing static arrays to dynamic equivalents is not a
> >> viable
> >> solution unfortunately.
> > I didn't check your program, but based on your description of
> > problem,
> > you may want to increase the stack size of your threaded program.
> > Try setting "ulimit -s" and "KMP_STACKSIZE" to what your program's
> > need. See ifort's manpage on KMP_STACKSIZE's definition.
> > A.Chan
> > _______________________________________________
> > mpich-discuss mailing list mpich-discuss at mcs.anl.gov To manage
> > subscription options or unsubscribe:
> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
> Jeff Hammond
> Argonne Leadership Computing Facility
> University of Chicago Computation Institute jhammond at alcf.anl.gov /
> (630)
> 252-5381 http://www.linkedin.com/in/jeffhammond
> https://wiki-old.alcf.anl.gov/index.php/User:Jhammond
> To manage subscription options or unsubscribe:
