[mpich-discuss] Mpich2 1.5a2
Torquil Macdonald Sørensen torquil at gmail.com
Wed Dec 21 06:53:05 CST 2011
Hi there!
A few questions about MPICH 1.5a2:
1) Have the manpages disappeared?
2) It seems that the PDF file user.pdf is not installed into
/usr/share/doc/mpich2 anymore? Same for files in www/. Were they previously
installed automatically into /usr/share/doc/mpich2 ?
3) If I remember correctly, in previous versions, there were bin/, lib/ and
include/ which contained all the necessary files to compile and run the
test-suite prior to "make install", by going to test/mpi, and running
./configure --with-mpi=../../ and so on.
This doesn't seem to work the same way anymore, since compiled library files now
seem to be spread out in different hidden .libs/ directories after "make"
finishes. It now seems necessary to set a lot of environment variables
(LD_LIBRARY_PATH and CPPFLAGS with different added .libs/ subdirectories) when
one is about to run the ./configure in test/mpi.
Perhaps the test-suite is now intended to be run after "make install".
Thanks, and best regards
Torquil M. Sørensen
