[mpich-discuss] A runtime warning message with version 1.4.1p1
CB cbalways at gmail.com
Tue Dec 20 10:39:20 CST 2011
I build the MPICH2 package on a VM running Fedora Core 11 and installed on
a cluster of Dell servers running the same OS.
Both VM and Dell servers have the same verions of the libxml2 library.
Do you need any other informaiton?
- Chansup
On Tue, Dec 20, 2011 at 11:21 AM, Darius Buntinas <buntinas at mcs.anl.gov>wrote:
> I'm not sure.  There might be something wrong with your libxml2 library.
>  What kind of machine are you using?
> -d
> On Dec 20, 2011, at 9:58 AM, CB wrote:
> > When I run an example hello program on a node with two MPI processes, it
> generates some warnings about no version information although the program
> ran successfully.
> > I am wondering how to suppress the warning message?
> > $ mpirun -np 2  -machinefile ./hostsfile ./hello-mpich2-c.exe
> > /usr/local/MPI/mpich2/bin/hydra_pmi_proxy: /usr/lib64/libxml2.so.2: no
> version information available (required by
> /usr/local/MPI/mpich2/bin/hydra_pmi_proxy)
> > Processor 0 on compute-0-0 out of 2
> > Processor 1 on compute-0-2 out of 2
> > Here is my build information:
> > $ mpirun -info
> > HYDRA build details:
> >     Version:                                 1.4.1p1
> >     Release Date:                            Thu Sep  1 13:53:02 CDT 2011
> >     CC:                              gcc
> >     CXX:                             c++
> >     F77:                             gfortran
> >     F90:                             f95
> >     Configure options:
> '--prefix=/usr/local/MPI/mpich2-1.4.1p1' '--enable-shared'
> '--enable-checking=release' '--disable-option-checking' 'CC=gcc' 'CFLAGS=
> -O2' 'LDFLAGS= ' 'LIBS=-lrt -lpthread ' 'CPPFLAGS=
> -I/home/x/Documents/MPICH2/mpich2-1.4.1p1/src/mpl/include
> -I/home/x/Documents/MPICH2/mpich2-1.4.1p1/src/openpa/src
> -I/home/x/Documents/MPICH2/mpich2-1.4.1p1/src/mpid/ch3/include
> -I/home/x/Documents/MPICH2/mpich2-1.4.1p1/src/mpid/common/datatype
> -I/home/x/Documents/MPICH2/mpich2-1.4.1p1/src/mpid/common/locks
> -I/home/x/Documents/MPICH2/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/include
>  ls/nemesis/include
> -I/home/x/Documents/MPICH2/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/include
> -I/home/x/Documents/MPICH2/mpich2-1.4.1p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor
> -I/home/x/Documents/MPICH2/mpich2-1.4.1p1/src/util/wrappers
> -I/home/x/Documents/MPICH2/mpich2-1.4.1p1/src/util/wrappers'
> >     Process Manager:                         pmi
> >     Launchers available:                      ssh rsh fork slurm ll lsf
> sge manual persist
> >     Topology libraries available:              hwloc plpa
> >     Resource management kernels available:    user slurm ll lsf sge pbs
> >     Checkpointing libraries available:
> >     Demux engines available:                  poll select
> > Thanks,
> > - Chansup
> > _______________________________________________
> > mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
> > To manage subscription options or unsubscribe:
> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20111220/78d54cc3/attachment.htm>
