[mpich-discuss] Problem using mpi_type_create_f90_integer
Dave Goodell goodell at mcs.anl.gov
Fri Dec 16 17:40:41 CST 2011
Hi Thomas,
Will you send us a copy of the "src/binding/f90/mpif90model.h" file from your build directory?  That should help us figure out what's happening with "WITH_BUG1".
As for "WITH_BUG2", this looks like a bug in your test program.  You are using the literal array "(/ 1, 1 /)" as your array_of_displacements argument to MPI_Type_create_struct.  In my hazy understanding of Fortran, the type of this literal defaults to an INTEGER array.  It should be an array of type INTEGER(kind=MPI_ADDRESS_KIND).  When I made this change I was able to entirely eliminate the Valgrind warnings that had been coming out of the program.
-Dave
On Dec 14, 2011, at 7:33 AM CST, Thomas Jahns wrote:
> Hello,
> I'm having some problems when using mpi_type_create_f90_integer, where, for 8
> byte integers (i.e. requesting 18 decimal places), I get an immediate error for
> and for 4 byte integers I get a later segmentation-fault when committing a
> struct type containing the result of mpi_type_create_f90_integer, both bugs
> happen with the current Intel Fortran compiler 12.1.0 20110811 and NAG Fortran
> Compiler Release 5.2(747) (with gcc 4.6.1 host compiler for the NAG).
> The below example exhibits both problem when run after compilation with defining
> either WITH_BUG1 or WITH_BUG2.
> In the case of WITH_BUG1 I get:
> $  ~/opt/mpich2-1.4.1p1-nag52-x64-linux/bin/mpif90 -fpp -DWITH_BUG1 bug.f90
> NAG Fortran Compiler Release 5.2(747)
> Extension: /home/tjahns/opt/mpich2-1.4.1p1-nag52-x64-linux/include/mpif.h, line
> 479: Byte count on numeric data type
>           detected at *@8
> 492: Byte count on numeric data type
>           detected at *@8
> 493: Byte count on numeric data type
>           detected at *@8
> Warning: bug.f90, line 44: Unused external reference MPI_WTICK
>         detected at TEST_F90INT@<end-of-statement>
> Warning: bug.f90, line 44: Unused external reference PMPI_WTICK
> Warning: bug.f90, line 44: Unused external reference PMPI_WTIME
> Warning: bug.f90, line 44: Unused external reference MPI_WTIME
> [NAG Fortran Compiler normal termination, 7 warnings]
> $ ./a.out
> Fatal error in MPI_Type_create_f90_integer: Other MPI error, error stack:
> MPI_Type_create_f90_integer(117):  MPI_Type_create_f90_int (range=14) failed
> MPI_Type_create_f90_integer(97).:  No integer type with 14 digits of range is
> avaiable
> The second bug manifests itself in a segmentation fault I've traced to dlp being
> invalid in MPID_Segment_init.
> $ ~/opt/mpich2-1.4.1p1-nag52-x64-linux/bin/mpif90 -fpp -DWITH_BUG2 bug.f90
>           detected at *@8
>           detected at *@8
>           detected at *@8
> $ gdb ./a.out
> GNU gdb (GDB) 7.0.1-debian
> Copyright (C) 2009 Free Software Foundation, Inc.
> License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
> This is free software: you are free to change and redistribute it.
> There is NO WARRANTY, to the extent permitted by law.  Type "show copying"
> and "show warranty" for details.
> This GDB was configured as "x86_64-linux-gnu".
> For bug reporting instructions, please see:
> <http://www.gnu.org/software/gdb/bugs/>...
> Reading symbols from
> /home/tjahns/bug-reporting/mpich2-mpi_type_create_f90_integer_problem/a.out...done.
> (gdb)  r
> Starting program:
> [Thread debugging using libthread_db enabled]
> Program received signal SIGSEGV, Segmentation fault.
> MPID_Segment_init (buf=0x0, count=<value optimized out>, handle=-1946157051,
>    segp=0x703da0, flag=<value optimized out>)
>    at
> ../../../../../../mpich2-1.4.1p1/src/mpid/common/datatype/dataloop/segment.c:173
> 173	    DLOOP_Stackelm_load(elmp, dlp, 0);
> (gdb) bt
> #0  MPID_Segment_init (buf=0x0, count=<value optimized out>,
>    handle=-1946157051, segp=0x703da0, flag=<value optimized out>)
>    at
> #1  0x000000000045e5ed in DLOOP_Dataloop_create_flattened_struct (count=2,
>    blklens=0x703d7c, disps=0x703d88, oldtypes=0x703d70, dlp_p=0x6d63b0,
>    dlsz_p=0x6d63b8, dldepth_p=0x6d63bc, flag=0)
>    at
> ../../../../../../mpich2-1.4.1p1/src/mpid/common/datatype/dataloop/dataloop_create_struct.c:581
> #2  MPID_Dataloop_create_struct (count=2, blklens=0x703d7c, disps=0x703d88,
>    oldtypes=0x703d70, dlp_p=0x6d63b0, dlsz_p=0x6d63b8, dldepth_p=0x6d63bc,
>    flag=0)
>    at
> ../../../../../../mpich2-1.4.1p1/src/mpid/common/datatype/dataloop/dataloop_create_struct.c:244
> #3  0x000000000045b91b in MPID_Dataloop_create (type=-1946157050,
>    dlp_p=0x6d63b0, dlsz_p=0x6d63b8, dldepth_p=0x6d63bc, flag=0)
>    at
> ../../../../../../mpich2-1.4.1p1/src/mpid/common/datatype/dataloop/dataloop_create.c:279
> #4  0x0000000000416b72 in MPID_Type_commit (datatype_p=0x7fffffffc5e4)
>    at ../../../../../mpich2-1.4.1p1/src/mpid/common/datatype/mpid_type_commit.c:43
> #5  0x000000000040dd7a in MPIR_Type_commit_impl (
>    datatype=<value optimized out>)
>    at ../../../../mpich2-1.4.1p1/src/mpi/datatype/type_commit.c:43
> #6  0x000000000040df4b in PMPI_Type_commit (datatype=0x7fffffffc5e4)
>    at ../../../../mpich2-1.4.1p1/src/mpi/datatype/type_commit.c:114
> #7  0x000000000040d849 in pmpi_type_commit_ (v1=<value optimized out>,
>    ierr=0x7fffffffc5e8)
>    at ../../../../mpich2-1.4.1p1/src/binding/f77/type_commitf.c:190
> #8  0x000000000040d609 in main (argc=1, argv=0x7fffffffc6d8) at bug.f90:24
> (gdb)
> If any extra information might be useful, I'll be happy to provide.
> Regards,
> Thomas
> Thomas Jahns
> DKRZ GmbH, Department: Application software
> Deutsches Klimarechenzentrum
> Bundesstraße 45a
> D-20146 Hamburg
> Phone: +49-40-460094-151
> Fax: +49-40-460094-270
> Email: Thomas Jahns <jahns at dkrz.de>
> <mpich2-1.4.1p1-nag52.log.bz2><bug.f90>_______________________________________________
> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
