[mpich-discuss] p4_error: interrupt SIGx:4
Darius Buntinas buntinas at mcs.anl.gov
Fri Dec 16 10:32:58 CST 2011
The fact that you're getting the p4 errors despite the fact that you installed MPICH2 means that the MPICH1 complier wrappers (e.g., mpicc) were still being used when you recompiled your application.  Make sure you use the full path to the MPICH2 compiler wrappers when you recompile your application.  Also, make sure you're using the full path to mpiexec.
-d
On Dec 16, 2011, at 7:26 AM, aiswarya.pawar at gmail.com wrote:
> Sorry for not responding. Actually I even tried the mpich2-1.4.1 still I get this error.
> And system admin is out of station so couldn't get him through. And trying to fix the problem myself.
> Sent from my BlackBerry® on Reliance Mobile, India's No. 1 Network. Go for it!
> -----Original Message-----
> From: Jeff Hammond <jhammond at alcf.anl.gov>
> Sender: mpich-discuss-bounces at mcs.anl.gov
> Date: Fri, 16 Dec 2011 06:47:07
> To: <mpich-discuss at mcs.anl.gov>
> Reply-To: mpich-discuss at mcs.anl.gov
> Subject: Re: [mpich-discuss] p4_error: interrupt SIGx:4
> Dave already answered this question when he said that this problem
> involves MPICH1, which is no longer supported.  You also failed to
> respond to either of my suggested actions to verify independently that
> the application and MPI were running correctly.
> You will need to install MPICH2 or pursue another support option, such
> as your system vendor.
> Best,
> Jeff
> On Fri, Dec 16, 2011 at 4:59 AM, aiswarya pawar
> <aiswarya.pawar at gmail.com> wrote:
>> Hi users,
>> Does anyone knows whats this error about and how do i fix it?
>> Please help.
>> Thanks,
>> Aiswarya
>> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
>> To manage subscription options or unsubscribe:
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
> Jeff Hammond
> Argonne Leadership Computing Facility
> University of Chicago Computation Institute
> jhammond at alcf.anl.gov / (630) 252-5381
> http://www.linkedin.com/in/jeffhammond
> https://wiki-old.alcf.anl.gov/index.php/User:Jhammond
