[mpich-discuss] initialization issue in strided_get_indexed
sreeram potluri potluri at cse.ohio-state.edu
Mon Dec 12 15:47:13 CST 2011
Jim,
My understanding of the test is that only a part of the loc_buf is
overwritten by the MPI_Get operation (8*256 rather than 8*1024).
Now the test also tries to validate the rest of the loc_buf which is not
affected by the MPI_Get operation. This check can fail or pass based on the
original value of the loc_buf, which is never set.
Am I missing something basic?
Sreeram Potluri
On Mon, Dec 12, 2011 at 3:11 PM, Jim Dinan <dinan at mcs.anl.gov> wrote:
> Hi Sreeram,
> Setting the initial value of loc_buf shouldn't influence whether or not
> this test passes; the entire contents of loc_buf should be overwritten
> later by the call to MPI_Get.  As Dave pointed out, setting this to
> 1.0+rank also weakens the test when run on one process since loc_buf will
> already contain the correct data.  This is not the case when run on more
> processes since loc_buf should contain 1.0+((rank+1)%nproc)).
> This test has been in the MPICH test suite for several months and hasn't
> given us any trouble.  Any chance that it's exercising a bug on your end?
> Best,
>  ~Jim.
> On 12/12/11 1:27 PM, Dave Goodell wrote:
>> Sreeram,
>> I'm not very familiar with this test, but this looks like an incorrect
>> change to me.  By setting the loc_buf (the origin "receive" buffer) to the
>> expected value in this way then you open up a testing coverage gap if
>> MPI_Get is replaced with a no-op function.
>> If anything, this test could probably be strengthened by adding the
>> following line in the same location that you recommend making your change:
>> ----8<----
>>         *(loc_buf + i) = -1.0;
>> ----8<----
>> This way you don't assume anything about the values already in the buffer
>> returned by MPI_Alloc_mem.
>> Perhaps Jim can comment, since he wrote the test originally.
>> -Dave
>> On Dec 12, 2011, at 6:53 AM CST, sreeram potluri wrote:
>>  Hi Team,
>>> We have seen a validation error with the strided_get_indexed test in our
>>> internal testing with MVAPICH2. This appears to be an initialization issue
>>> with the benchmark. The path below fixes it in one way. Please accept the
>>> change if appropriate.
>>> Index: mpi/rma/strided_get_indexed.c
>>> --- mpi/rma/strided_get_indexed.c       (revision 5064)
>>> +++ mpi/rma/strided_get_indexed.c       (working copy)
>>> @@ -48,8 +48,10 @@
>>>      if (rank == 0)
>>>          if (verbose) printf("MPI RMA Strided Get Test:\n");
>>> -    for (i = 0; i<  XDIM*YDIM; i++)
>>> +    for (i = 0; i<  XDIM*YDIM; i++) {
>>>          *(win_buf + i) = 1.0 + rank;
>>> +        *(loc_buf + i) = 1.0 + rank;
>>>      MPI_Win_create(win_buf, bufsize, 1, MPI_INFO_NULL,
>>> MPI_COMM_WORLD,&buf_win);
>>> Regards
>>> Sreeram Potluri
>>> ______________________________**_________________
>>> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
>>> To manage subscription options or unsubscribe:
>>> https://lists.mcs.anl.gov/**mailman/listinfo/mpich-discuss<https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss>
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20111212/f834cf63/attachment.htm>
