[mpich-discuss] 64 bit application
Jayesh Krishna jayesh at mcs.anl.gov
Tue Dec 6 11:16:34 CST 2011
 Glad to know it worked for you.
Jayesh
----- Original Message -----
From: "Marko Topalovic" <topalovic1981 at gmail.com>
To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
Sent: Tuesday, December 6, 2011 9:13:05 AM
Subject: Re: [mpich-discuss] 64 bit application
thanks,
it was 32 bit version
now fpi example works with 64 bit libraries and 64 bit MPICH
now the hard part is to make all parts of our FEM solver work with these libraries
thanks once again
Marko Topalovic
On Mon, Dec 5, 2011 at 7:10 PM, Jayesh Krishna < jayesh at mcs.anl.gov > wrote:
Are you linking with the 64-bit libraries ?
If you would like to compile 64-bit applications you need to install 64-bit version of MPICH2 and link your code with the libraries provided (Currently we don't provide 64-bit libs with 32-bit version of MPICH2 and vice versa. Due to limited dev bandwidth I am not sure if we might end up providing that in the near future.).
Jayesh
From: "Marko Topalovic" < topalovic1981 at gmail.com >
Sent: Friday, December 2, 2011 9:03:20 AM
Subject: [mpich-discuss] 64 bit application
greetings
i am using windows7 64 bit and visual studio 2008
when i compile fpi from examples as Win32 application it works fine
when i change configuration to x64 it fails to compile giving me 20 errors
Error 1 error LNK2019: unresolved external symbol MPI_INIT referenced in function MAIN__ fpi.obj
this is linking problem but every setting in configuration is the same as for the Win32 application
so what should i do make this simple example work on x64 configuration
best regards,
Marko Topalovic
mpich-discuss mailing list mpich-discuss at mcs.anl.gov
To manage subscription options or unsubscribe:
