[mpich-discuss] Error message with MPICH2-1.0.8
Pfeiffer, Sharon pfeiffers at aecl.ca
Mon Dec 5 11:03:44 CST 2011
UNRESTRICTED | ILLIMITÉ
Yes, I noticed that Brian.
Thanks for pointing me into that direction.
Sharon (46654)
From: mpich-discuss-bounces at mcs.anl.gov [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Andrus, Brian Contractor
Sent: December 5, 2011 11:47 AM AECL
Subject: Re: [mpich-discuss] Error message with MPICH2-1.0.8
Sharon,
That particular error message is because of a missing home directory. If the node(s) you run on DO have the home directory, there will be no error.
If that node does not have /home/pfeiffes/ but DOES have an existing home directory (as I would expect), it would still run.
What you may need to verify is that the $HOME directory for the accounts are the same for each node and exist.
Brian Andrus
ITACS/Research Computing
Naval Postgraduate School
Monterey, California
voice: 831-656-6238
From: mpich-discuss-bounces at mcs.anl.gov [mailto:mpich-discuss-bounces at mcs.anl.gov] On Behalf Of Pfeiffer, Sharon
Sent: Monday, December 05, 2011 6:15 AM
(1)   UNRESTRICTED | ILLIMITÉ
(2)
(3)     You are right, I logged on to the two nodes that it was having problems with and did not find my home directory.
(4)    I'm trying to understand MPI and have one more question, if I statically assign the job to run on that node "ccs511", I do not get the error message.
Could you tell me why this is the case?
Thanks.
Sharon (46654)
Sent: December 2, 2011 4:36 PM AECL
Sharon,
I suspect your home directory does not exist on one of the nodes.
Log onto the nodes and verify that.
Brian Andrus
voice: 831-656-6238
Sent: Friday, December 02, 2011 12:41 PM
Subject: [mpich-discuss] Error message with MPICH2-1.0.8
We are getting the following error message whenever a job is submitted to our compute cluster.
I have provided information below, however, if you require any further information, please email me.
Thank you.
Sharon Pfeiffer
________________________________________________________________________________________________
Computational Reactor Physics Branch - AECL Nuclear Laboratories, Ontario, K0J 1J0 - (613) 584-8811 ext. 46654
Version: MPICH2-1.0.8
OS: Red Hat Linux (64-bit)
System : Linux cluster
Error message:
touch: cannot touch `/home/pfeiffes/.mpd.conf': No such file or directory
Cannot create MPD configuration file. Exiting ...
Job  /cluster/lsf8.0/8.0/linux2.6-glibc2.3-x86_64/bin/mpich2_wrapper /ASD-RH-64/AECL/CODES/MCNP5/bin/Linux/mcnp5V1.40.1mpich2-1.0.8.Intel.64bits.Nov042009.mpi name=fname xsdir=e70c.xsd eol
TID   HOST_NAME   COMMAND_LINE            STATUS            TERMINATION_TIME
00001 ccs512                       Undefined
00002 ccs512                       Undefined
00003 ccs512                       Undefined
00004 ccs512                       Undefined
00005 ccs511                       Undefined
00006 ccs511                       Undefined
00007 ccs511                       Undefined
00008 ccs511                       Undefined
00009 ccs511                       Undefined
00010 ccs511                       Undefined
00011 ccs511                       Undefined
00012 ccs511                       Undefined
00013 ccs511                       Undefined
00014 ccs511                       Undefined
00015 ccs511                       Undefined
00016 ccs511                       Undefined
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20111205/18271e4f/attachment-0001.htm>
