[mpich-discuss] Error message with MPICH2-1.0.8
Darius Buntinas buntinas at mcs.anl.gov
Fri Dec 2 15:27:38 CST 2011
MPICH2 1.0.8 is very old, if possible, you should update to the latest version.  There's a package available for Red Hat, so you should be able to get it through the yum package manager.  Note that the mpd process manager is no longer supported and has been replaced by hydra (see http://wiki.mcs.anl.gov/mpich2/index.php/Using_the_Hydra_Process_Manager ).
If you can't upgrade, then make sure that your home directory has an ".mpd.conf" file that is readable/writable only to you.  See step 9 of the quick start on page 5 of the installation guide: http://www.mcs.anl.gov/research/projects/mpich2/documentation/files/mpich2-1.2.1-installguide.pdf
However, looking at the error message (but without knowing anything about the script you're using), I suspect that the script might be doing this for you, in which case check that the script is able to access the directory.
-d
On Dec 2, 2011, at 2:40 PM, Pfeiffer, Sharon wrote:
> UNRESTRICTED | ILLIMITÉ
> We are getting the following error message whenever a job is submitted to our compute cluster.
> I have provided information below, however, if you require any further information, please email me.
> Thank you.
> Sharon Pfeiffer
> ________________________________________________________________________________________________
> Computational Reactor Physics Branch - AECL Nuclear Laboratories, Ontario, K0J 1J0 - (613) 584-8811 ext. 46654
> Version: MPICH2-1.0.8
> OS: Red Hat Linux (64-bit)
> System : Linux cluster
> Error message:
> touch: cannot touch `/home/pfeiffes/.mpd.conf': No such file or directory
> Cannot create MPD configuration file. Exiting ...
> Job  /cluster/lsf8.0/8.0/linux2.6-glibc2.3-x86_64/bin/mpich2_wrapper /ASD-RH-64/AECL/CODES/MCNP5/bin/Linux/mcnp5V1.40.1mpich2-1.0.8.Intel.64bits.Nov042009.mpi name=fname xsdir=e70c.xsd eol
> TID   HOST_NAME   COMMAND_LINE            STATUS            TERMINATION_TIME
> 00001 ccs512                       Undefined
> 00002 ccs512                       Undefined
> 00003 ccs512                       Undefined
> 00004 ccs512                       Undefined
> 00005 ccs511                       Undefined
> 00006 ccs511                       Undefined
> 00007 ccs511                       Undefined
> 00008 ccs511                       Undefined
> 00009 ccs511                       Undefined
> 00010 ccs511                       Undefined
> 00011 ccs511                       Undefined
> 00012 ccs511                       Undefined
> 00013 ccs511                       Undefined
> 00014 ccs511                       Undefined
> 00015 ccs511                       Undefined
> 00016 ccs511                       Undefined
> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
