[mpich-discuss] MPI_REDUCE and complex numbers
Darius Buntinas buntinas at mcs.anl.gov
Fri Aug 19 10:02:55 CDT 2011
There isn't a max buffer size (aside from the running out of memory, but you'd get an error for that).  Can you send us a short sample program that demonstrates this?  How many  processes are you using?
-d
On Aug 18, 2011, at 11:04 PM, Brian Dushaw wrote:
> I recently ran across what may be a bug in MPI_REDUCE using the latest version of mpich2-1.4., (although I can't be sure...)
> I have fortran 90 code that calculates a complex array of size
> about 400X6000.  Each row of the array is calculated independently,
> so I apportion subsets of rows across a small cluster for calculating.
> On each node, the rows not calculated are just filled with zeros.
> when all done, I called:
> call MPI_REDUCE(psif,psiff,itemp,MPI_DOUBLE_COMPLEX,MPI_SUM,0,MPI_COMM_WORLD,ierr)
> which just adds up all the arrays from each node, giving me the final
> filled up array complex psiff on the master node (myid=0). itemp is size
> ncol*nrow of psiff (or about 400*6000).
> This worked fine for smaller sized arrays, but for the larger size
> of 400X6000 (which doesn't seem all that large to me), I would just get
> almost all zeros in the psiff array.
> I wondered if the array size was so large as to overflow a maximum buffer
> size for MPI_REDUCE.
> In any case, I rewrote the above to send back real and imaginary parts
> separately, calling instead:
> call MPI_REDUCE(rpsif,rpsiff,itemp,MPI_DOUBLE_PRECISION,MPI_SUM,0,MPI_COMM_WORLD,ierr)
> call MPI_REDUCE(ipsif,ipsiff,itemp,MPI_DOUBLE_PRECISION,MPI_SUM,0,MPI_COMM_WORLD,ierr)
> And this seems to work fine.
> Does anybody have any comments or wise words to enlighten this situation?
> The code takes quite a while to run, so it is slow to debug.  I suppose I could write a small test case to check more simply whether this is a bug
> or not.  Does MPI_REDUCE have a maximum buffer size that one should worry about?
> Thanks -
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
