[mpich-discuss] Fwd: compiling parallel programms with ifort
mohamed ali eng1182 at gmail.com
Wed Apr 27 13:38:09 CDT 2011
Hi Anthony
it gave me this message:
The Open MPI wrapper compiler was unable to find the specified compiler
gfortran in your PATH.
Note that this compiler was either specified at configure time or in
one of several possible environment variables.
can i change any variable of mpif90 to appoint to ifort rather than
gfortran?
On Wed, Apr 27, 2011 at 8:33 PM, Anthony Chan <chan at mcs.anl.gov> wrote:
> You should use mpif90 to compile and link your f90 program.
> mpif90 will take care of include path and linking of various
> MPICH2 internal libraries...
> > Dear there
> > I have installed MPICH2-1.3.2p1 on ubuntu and the installation was
> > ended and
> > tested successfully, When i try to compile a parallel program with
> > ifort,
> > it gives me error. i use this command for compiling:
> > ifort heat_mpi.f90 hi.out -o
> > the errors that appear are as follows:
> > /tmp/ifortYgvRCy.o: In function `MAIN__':
> > heat_mpi.f90:(.text+0x1f8): undefined reference to `mpi_init_'
> > heat_mpi.f90:(.text+0x214): undefined reference to `mpi_comm_rank_'
> > heat_mpi.f90:(.text+0x230): undefined reference to `mpi_comm_size_'
> > heat_mpi.f90:(.text+0x255): undefined reference to `mpi_wtime_'
> > heat_mpi.f90:(.text+0x1166): undefined reference to `mpi_send_'
> > heat_mpi.f90:(.text+0x11ce): undefined reference to `mpi_recv_'
> > heat_mpi.f90:(.text+0x1236): undefined reference to `mpi_send_'
> > heat_mpi.f90:(.text+0x1294): undefined reference to `mpi_recv_'
> > heat_mpi.f90:(.text+0x149f): undefined reference to `mpi_wtime_'
> > heat_mpi.f90:(.text+0x1590): undefined reference to `mpi_finalize_'
> > /tmp/ifortYgvRCy.o: In function `update_':
> > heat_mpi.f90:(.text+0x27f9): undefined reference to `mpi_send_'
> > heat_mpi.f90:(.text+0x2858): undefined reference to `mpi_recv_'
> > heat_mpi.f90:(.text+0x28b7): undefined reference to `mpi_send_'
> > heat_mpi.f90:(.text+0x2911): undefined reference to `mpi_r
> > i have included the mpif.h file in the same directory and i added the
> > paths
> > of mpich2/include and mpich2/lib to the PATH variable. should i change
> > some
> > thing in my command? or do some thing to define the mpich2 to ifort. I
> > had
> > the ifort installed befor mpich2.
> > thanks,
> > Ali.
> > _______________________________________________
> > mpich-discuss mailing list
> > mpich-discuss at mcs.anl.gov
> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110427/3be6a979/attachment-0001.htm>
