[mpich-discuss] mpich2-1.3.2 cygwin build error.
Sunil Thomas sgthomas27 at gmail.com
Wed Apr 27 01:38:16 CDT 2011
Hi!
  My mpich2-1.3.2 cygwin build is failing (configure seems to complete
successfully
and I have done a make clean as instructed in the docs).
*make[4]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/binding/f90'
make[4]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/binding/f90'
  FC
/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/binding/f90/mpi.f90
make[4]: *** [mpi.lo] Error 1
make[3]: *** [all-redirect] Error 1
make[3]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/binding/f90'
make[2]: *** [all-redirect] Error 1
make[2]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/binding'
make[1]: *** [all-redirect] Error 2
make[1]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src'
make: *** [all-redirect] Error 2*
    I am testing this on 32 bit Windows 7. Attached is the c.txt and m.txt
files. I am
configuring this using:
configure --prefix=<path/to>install --enable-fast=O2 --enable-shared |& tee
c.txt
make VERBOSE=1 2>&1 | tee m.txt
  Any help to resolve this error is appreciated!
--Sunil.
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110426/ee7823e7/attachment-0001.htm>
Configuring MPICH2 version 1.3.2p1 with  '--prefix=/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1-install' '--enable-fast=O2' '--enable-shared'
Running on system: CYGWIN_NT-6.1 SGT-LENOVO-U330 1.7.9(0.237/5/3) 2011-03-29 10:10 i686 Cygwin
checking for gcc... gcc
checking for C compiler default output file name... a.exe
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables... .exe
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking how to run the C preprocessor... gcc -E
checking build system type... i686-pc-cygwin
checking host system type... i686-pc-cygwin
checking for grep that handles long lines and -e... /usr/bin/grep
checking for fgrep... /usr/bin/grep -F
Creating shared libraries using GNU under CYGWIN
Executing mpich2prereq in /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3 with
Executing mpich2prereq in /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis
configure: ===== configuring src/mpl =====
configure: executing: /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/configure  '--prefix=/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1-install' '--enable-fast=O2' '--enable-shared' --disable-option-checking
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /usr/bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking for a sed that does not truncate output... /usr/bin/sed
checking for egrep... /usr/bin/grep -E
checking for ld used by gcc... /usr/i686-pc-cygwin/bin/ld.exe
checking if the linker (/usr/i686-pc-cygwin/bin/ld.exe) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface... BSD nm
checking whether ln -s works... yes
checking the maximum length of command line arguments... 8192
checking whether the shell understands some XSI constructs... yes
checking whether the shell understands "+="... yes
checking for /usr/i686-pc-cygwin/bin/ld.exe option to reload object files... -r
checking for objdump... objdump
checking how to recognize dependent libraries... file_magic ^x86 archive import|^x86 DLL
checking for ar... ar
checking for strip... strip
checking for ranlib... ranlib
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for dlfcn.h... yes
checking for objdir... .libs
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -DDLL_EXPORT -DPIC
checking if gcc PIC flag -DDLL_EXPORT -DPIC works... yes
checking if gcc static flag -static works... no
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker (/usr/i686-pc-cygwin/bin/ld.exe) supports shared libraries... yes
checking whether -lc should be explicitly linked in... yes
checking dynamic linker characteristics... Win32 ld.exe
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
checking whether we are using the GNU C compiler... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking for gcc option to accept ISO C89... (cached) none needed
checking dependency style of gcc... (cached) gcc3
checking for an ANSI C-conforming const... yes
checking for C/C++ restrict keyword... __restrict
checking for variable argument list macro functionality... yes
checking stdio.h usability... yes
checking stdio.h presence... yes
checking for stdio.h... yes
checking for stdlib.h... (cached) yes
checking for string.h... (cached) yes
checking stdarg.h usability... yes
checking stdarg.h presence... yes
checking for stdarg.h... yes
checking ctype.h usability... yes
checking ctype.h presence... yes
checking for ctype.h... yes
checking for inttypes.h... (cached) yes
checking for stdint.h... (cached) yes
checking valgrind.h usability... no
checking valgrind.h presence... no
checking for valgrind.h... no
checking memcheck.h usability... no
checking memcheck.h presence... no
checking for memcheck.h... no
checking valgrind/valgrind.h usability... no
checking valgrind/valgrind.h presence... no
checking for valgrind/valgrind.h... no
checking valgrind/memcheck.h usability... no
checking valgrind/memcheck.h presence... no
checking for valgrind/memcheck.h... no
checking helgrind.h usability... no
checking helgrind.h presence... no
checking for helgrind.h... no
checking valgrind/helgrind.h usability... no
checking valgrind/helgrind.h presence... no
checking for valgrind/helgrind.h... no
checking drd.h usability... no
checking drd.h presence... no
checking for drd.h... no
checking valgrind/drd.h usability... no
checking valgrind/drd.h presence... no
checking for valgrind/drd.h... no
checking whether the valgrind headers are broken or too old... yes
checking for strdup... yes
checking whether strdup needs a declaration... no
checking for snprintf... yes
checking whether snprintf needs a declaration... no
checking for strncmp... yes
checking whether strncmp needs a declaration... no
checking for putenv... yes
checking whether putenv needs a declaration... no
checking whether __attribute__ allowed... yes
checking whether __attribute__((format)) allowed... yes
configure: creating ./config.status
config.status: creating Makefile
config.status: creating localdefs
config.status: creating include/config.h
config.status: include/config.h is unchanged
config.status: executing depfiles commands
config.status: executing libtool commands
config.status: executing include/mplconfig.h commands
config.status: creating include/mplconfig.h - prefix MPL for include/config.h defines
config.status: include/mplconfig.h is unchanged
configure: ===== done with src/mpl configure =====
configure: ===== configuring src/openpa =====
configure: executing: /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/configure --with-atomic-primitives=auto_allow_emulation '--prefix=/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1-install' '--enable-fast=O2' '--enable-shared' --disable-option-checking
checking for gcc... (cached) gcc
checking whether to enable assertions... yes
checking pthread.h usability... yes
checking pthread.h presence... yes
checking for pthread.h... yes
checking atomic.h usability... no
checking atomic.h presence... no
checking for atomic.h... no
checking intrin.h usability... no
checking intrin.h presence... no
checking for intrin.h... no
checking stddef.h usability... yes
checking stddef.h presence... yes
checking for stddef.h... yes
checking for inline... inline
checking for pthread_create in -lpthread... yes
checking for pthread_yield... yes
checking if 100 threads can be run at once... yes
checking size of void *... 4
checking size of int... 4
checking if compiler rejects bogus asm statements... yes
checking for support for gcc x86/x86_64 primitives... yes
checking for support for gcc x86 primitives for pre-Pentium 4... yes
checking for support for gcc ia64 primitives... no
checking for support for gcc PowerPC atomics... no
checking for support for gcc SiCortex atomics... no
checking for support for gcc atomic intrinsics... yes
checking for support for Windows NT atomic intrinsics... no
checking for support for Sun atomic operations library... no
checking whether to enable strict fairness checks... no
config.status: creating src/Makefile
config.status: creating test/Makefile
config.status: creating openpa.pc
config.status: creating src/config.h
config.status: src/config.h is unchanged
config.status: executing src/opa_config.h commands
config.status: creating src/opa_config.h - prefix OPA for src/config.h defines
config.status: src/opa_config.h is unchanged
configure: ===== done with src/openpa configure =====
sourcing /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/pm/hydra/mpich2prereq
checking whether the compiler defines __func__... yes
checking whether the compiler defines __FUNC__... no
checking whether the compiler sets __FUNCTION__... yes
checking whether C compiler accepts option -O2... yes
checking whether routines compiled with -O2 can be linked with ones compiled without -O2... yes
checking for type of weak symbol alias support... pragma weak does not work outside of a file
no
checking whether __attribute__ ((weak)) allowed... yes
checking whether __attribute__ ((weak_import)) allowed... yes
checking whether __attribute__((weak,alias(...))) allowed... no
checking for ifort... no
checking for pgf77... no
checking for af77... no
checking for xlf... no
checking for frt... no
checking for cf77... no
checking for fort77... no
checking for fl32... no
checking for fort... no
checking for ifc... no
checking for efc... no
checking for ftn... no
checking for gfortran... gfortran
checking whether we are using the GNU Fortran 77 compiler... yes
checking whether gfortran accepts -g... yes
checking whether Fortran 77 compiler accepts option -O2... yes
checking how to get verbose linking output from gfortran... -v
checking for Fortran 77 libraries of gfortran...  -L/usr/lib/gcc/i686-pc-cygwin/4.3.4 -L/usr/lib/gcc/i686-pc-cygwin/4.3.4/../../.. -lgfortranbegin -lgfortran -lcygwin -luser32 -lkernel32 -ladvapi32 -lshell32
checking whether gfortran accepts the FLIBS found by autoconf... yes
checking whether C can link with  -L/usr/lib/gcc/i686-pc-cygwin/4.3.4 -L/usr/lib/gcc/i686-pc-cygwin/4.3.4/../../.. -lgfortranbegin -lgfortran -lcygwin -luser32 -lkernel32 -ladvapi32 -lshell32... yes
checking for linker for Fortran main programs... Use Fortran to link programs
checking whether Fortran 77 and C objects are compatible... yes
checking for Fortran 77 name mangling... lower underscore
checking what libraries are needed to link Fortran programs with C routines that use stdio... none
checking whether Fortran init will work with C... yes
checking for pgf90... no
checking for pathf90... no
checking for pathf95... no
checking for xlf90... no
checking for xlf95... no
checking for f90... no
checking for epcf90... no
checking for f95... no
checking for lf95... no
checking whether we are using the GNU Fortran compiler... yes
checking for extension for Fortran 90 programs... f90
checking whether the Fortran 90 compiler (gfortran    ) works... yes
checking whether the Fortran 90 compiler (gfortran    ) is a cross-compiler... no
checking whether Fortran 90 compiler works with Fortran 77 compiler... yes
checking whether Fortran accepts ! for comments... yes
checking for include directory flag for Fortran... -I
checking for Fortran 77 flag for library directories... -L
checking for which Fortran libraries are needed to link C with Fortran... none
checking whether Fortran 77 compiler processes .F files with C preprocessor... yes
checking whether we are using the GNU Fortran compiler... (cached) yes
checking whether gfortran accepts -g... (cached) yes
checking for Fortran 90 module extension... mod
checking for Fortran 90 module include flag... -I
checking whether Fortran 90 compiler accepts option -O2... yes
checking whether Fortran 90 compiler processes .F90 files with C preprocessor... yes
checking what libraries are needed to link Fortran90 programs with C routines that use stdio... none
checking for Fortran 90 compiler vendor... gnu
checking for how to build shared libraries for Fortran 90... configure: WARNING: Unable to determine how to link Fortran 90 compiler with shared libraries
checking for c++... c++
checking whether we are using the GNU C++ compiler... yes
checking whether c++ accepts -g... yes
checking whether the C++ compiler c++ can build an executable... yes
checking whether C++ compiler works with string... yes
checking whether the compiler supports exceptions... yes
checking whether the compiler recognizes bool as a built-in type... yes
checking whether the compiler implements namespaces... yes
checking whether <iostream> available... yes
checking whether the compiler implements the namespace std... yes
checking whether <math> available... no
checking for GNU g++ version... 4 . 3
checking whether C++ compiler accepts option -O2... yes
checking for perl... /usr/bin/perl
checking for killall... killall
checking whether install works... yes
checking whether install breaks libraries... no
checking whether mkdir -p works... yes
checking for make... make
checking whether clock skew breaks make... no
checking whether make supports include... yes
checking whether make allows comments in actions... yes
checking for virtual path format... VPATH
checking whether make sets CFLAGS... yes
checking for bash... /usr/bin/bash
checking whether /usr/bin/bash supports arrays... yes
checking for doctext... false
checking for location of doctext style files... unavailable
checking for working volatile... yes
checking whether byte ordering is bigendian... no
checking whether C compiler allows unaligned doubles... yes
checking whether gcc supports __func__... yes
Using gcc to determine dependencies
checking whether long double is supported... yes
checking whether long long is supported... yes
checking for max C struct integer alignment... eight
checking for max C struct floating point alignment... four
checking for max C struct alignment of structs with doubles... eight
checking for max C struct floating point alignment with long doubles... four
configure: WARNING: Structures containing long doubles may be aligned differently from structures with floats or longs.  MPICH2 does not handle this case automatically and you should avoid assumed extents for structures containing float types.
checking if alignment of structs with doubles is based on position... no
checking if alignment of structs with long long ints is based on position... no
checking if double alignment breaks rules, find actual alignment... no
checking for alignment restrictions on pointers... int or better
checking size of char... 1
checking size of unsigned char... 1
checking size of short... 2
checking size of unsigned short... 2
checking size of unsigned int... 4
checking size of long... 4
checking size of unsigned long... 4
checking size of long long... 8
checking size of unsigned long long... 8
checking size of float... 4
checking size of double... 8
checking size of long double... 12
checking for ANSI C header files... no
checking size of wchar_t... 2
checking size of float_int... 8
checking size of double_int... 16
checking size of long_int... 8
checking size of short_int... 8
checking size of two_int... 8
checking size of long_double_int... 16
checking sys/bitypes.h usability... no
checking sys/bitypes.h presence... no
checking for sys/bitypes.h... no
checking inttypes.h usability... yes
checking inttypes.h presence... yes
checking stdint.h usability... yes
checking stdint.h presence... yes
checking for int8_t... yes
checking for int16_t... yes
checking for int32_t... yes
checking for int64_t... yes
checking for uint8_t... yes
checking for uint16_t... yes
checking for uint32_t... yes
checking for uint64_t... yes
checking stdbool.h usability... yes
checking stdbool.h presence... yes
checking for stdbool.h... yes
checking complex.h usability... yes
checking complex.h presence... yes
checking for complex.h... yes
checking size of _Bool... 1
checking size of float _Complex... 8
checking size of double _Complex... 16
checking size of long double _Complex... 24
checking for _Bool... yes
checking for float _Complex... yes
checking for double _Complex... yes
checking for long double _Complex... yes
checking for size of Fortran type integer... 4
checking for size of Fortran type real... 4
checking for size of Fortran type double precision... 8
checking whether integer*1 is supported... yes
checking whether integer*2 is supported... yes
checking whether integer*4 is supported... yes
checking whether integer*8 is supported... yes
checking whether integer*16 is supported... no
checking whether real*4 is supported... yes
checking whether real*8 is supported... yes
checking whether real*16 is supported... no
checking for C type matching Fortran integer... int
checking for size of MPI_Status... 20
checking for values of Fortran logicals... True is 1 and False is 0
checking for BSD/POSIX style global symbol lister... no
checking for multiple __attribute__((alias)) support... yes
checking the minimum alignment of Fortran common block of 1 integers... 4
checking the minimum alignment of Fortran common block of 5 integers... 4, too small! reset to 32
checking for Fortran 90 integer kind for 4-byte integers... 4
checking for Fortran 90 integer kind for 8-byte integers... 8
checking if real*8 is supported in Fortran 90... yes
checking size of bool... 1
checking how to run the C++ preprocessor... c++ -E
checking complex usability... yes
checking complex presence... yes
checking for complex... yes
checking size of Complex... 8
checking size of DoubleComplex... 16
checking size of LongDoubleComplex... 24
checking if char * pointers use byte addresses... yes
checking for alignment restrictions on ... no
checking for alignment restrictions on int32_t... no
checking size of MPIR_Bsend_data_t... 56
checking for gcc __asm__ and pentium cmpxchgl instruction... yes
checking for gcc __asm__ and AMD x86_64 cmpxchgq instruction... no
checking for gcc __asm__ and IA64 xchg4 instruction... no
checking for ANSI C header files... (cached) no
checking stdlib.h usability... yes
checking stdlib.h presence... yes
checking sys/types.h usability... yes
checking sys/types.h presence... yes
checking string.h usability... yes
checking string.h presence... yes
checking limits.h usability... yes
checking limits.h presence... yes
checking for limits.h... yes
checking for stddef.h... (cached) yes
checking errno.h usability... yes
checking errno.h presence... yes
checking for errno.h... yes
checking sys/socket.h usability... yes
checking sys/socket.h presence... yes
checking for sys/socket.h... yes
checking sys/time.h usability... yes
checking sys/time.h presence... yes
checking for sys/time.h... yes
checking unistd.h usability... yes
checking unistd.h presence... yes
checking endian.h usability... yes
checking endian.h presence... yes
checking for endian.h... yes
checking assert.h usability... yes
checking assert.h presence... yes
checking for assert.h... yes
checking sys/param.h usability... yes
checking sys/param.h presence... yes
checking for sys/param.h... yes
checking for sys/uio.h... yes
checking for size_t... yes
checking for setitimer... yes
checking for alarm... yes
checking for vsnprintf... yes
checking for vsprintf... yes
checking whether vsnprintf needs a declaration... no
checking for strerror... yes
checking for strncasecmp... yes
checking whether strerror_r is declared... yes
checking for strerror_r... yes
checking whether strerror_r returns char *... no
checking whether strerror_r needs a declaration... no
checking for qsort... yes
checking for va_copy... yes
checking for working alloca.h... yes
checking for alloca... yes
checking for mkstemp... yes
checking whether mkstemp needs a declaration... no
checking for fdopen... yes
checking whether fdopen needs a declaration... yes
checking for clock_gettime... yes
checking for clock_getres... yes
checking for gethrtime... no
checking for mach_absolute_time... no
checking for gettimeofday... yes
checking for library containing clock_gettime... none required
checking for library containing clock_getres... none required
checking whether struct timespec is defined in time.h... yes
checking for CLOCK_REALTIME defined in time.h... yes
sourcing /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/setup_device
RUNNING SETUP_DEVICE FOR THE CH3 DEVICE
sourcing /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/setup_channel
RUNNING SETUP_CHANNEL FOR THE NEMESIS CHANNEL
checking for pthread_key_create in -lpthread... yes
checking for pthread_key_create... yes
checking for pthread_cleanup_push... no
checking whether pthread_cleanup_push is available (may be a macro in pthread.h)... no
checking whether pthread.h defines PTHREAD_MUTEX_RECURSIVE_NP... no
checking whether pthread.h defines PTHREAD_MUTEX_RECURSIVE... yes
checking whether pthread.h defines PTHREAD_MUTEX_ERRORCHECK_NP... no
checking whether pthread.h defines PTHREAD_MUTEX_ERRORCHECK... yes
checking for thread local storage specifier... __thread
checking sched.h usability... yes
checking sched.h presence... yes
checking for sched.h... yes
checking for sched_yield... yes
checking for yield... no
checking for usleep... yes
checking for sleep... yes
checking for select... yes
checking for getpid... yes
checking for sched_setaffinity... no
checking for sched_getaffinity... no
checking for bindprocessor... no
checking for thread_policy_set... no
configure: ===== configuring src/mpid/ch3 =====
configure: executing: /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/configure  '--prefix=/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1-install' '--enable-fast=O2' '--enable-shared' --disable-option-checking
RUNNING CONFIGURE FOR CH3 DEVICE
checking for sys/types.h... (cached) yes
checking sys/uio.h usability... yes
checking sys/uio.h presence... yes
checking uuid/uuid.h usability... yes
checking uuid/uuid.h presence... yes
checking for uuid/uuid.h... yes
checking time.h usability... yes
checking time.h presence... yes
checking for time.h... yes
checking for unistd.h... (cached) yes
checking arpa/inet.h usability... yes
checking arpa/inet.h presence... yes
checking for arpa/inet.h... yes
checking for net/if.h... yes
checking for pid_t... yes
checking for inet_pton... yes
checking for gethostname... yes
checking whether gethostname needs a declaration... no
checking for CFUUIDCreate... no
checking for uuid_generate... no
checking for time... yes
checking whether CPP accepts variable length argument lists... yes
checking whether we can use struct ifconf... yes
configure: ===== configuring channels/nemesis =====
configure: executing: /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/configure  '--prefix=/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1-install' '--enable-fast=O2' '--enable-shared' '--disable-option-checking' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lpthread  ' 'CPPFLAGS= -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers' --disable-option-checking
RUNNING CONFIGURE FOR THE NEMESIS CHANNEL
checking netdb.h usability... yes
checking netdb.h presence... yes
checking for netdb.h... yes
checking sys/mman.h usability... yes
checking sys/mman.h presence... yes
checking for sys/mman.h... yes
checking sys/ioctl.h usability... yes
checking sys/ioctl.h presence... yes
checking for sys/ioctl.h... yes
checking sys/sockio.h usability... no
checking sys/sockio.h presence... no
checking for sys/sockio.h... no
checking sys/ipc.h usability... yes
checking sys/ipc.h presence... yes
checking for sys/ipc.h... yes
checking sys/shm.h usability... yes
checking sys/shm.h presence... yes
checking for sys/shm.h... yes
checking for netinet/in.h... yes
checking signal.h usability... yes
checking signal.h presence... yes
checking for signal.h... yes
checking for signal... yes
checking for rand... yes
checking for srand... yes
checking for OpenPA atomic primitive availability... yes
checking for mmap... yes
checking for munmap... yes
configure: Using a memory-mapped file for shared memory
checking whether struct hostent contains h_addr_list... yes
checking knem_io.h usability... no
checking knem_io.h presence... no
checking for knem_io.h... no
config.status: creating nemesis/Makefile
config.status: creating nemesis/src/Makefile
config.status: creating nemesis/utils/Makefile
config.status: creating nemesis/utils/replacements/Makefile
config.status: creating nemesis/utils/monitor/Makefile
config.status: creating nemesis/netmod/Makefile
config.status: creating nemesis/netmod/elan/Makefile
config.status: creating nemesis/netmod/gm/Makefile
config.status: creating nemesis/netmod/mx/Makefile
config.status: creating nemesis/netmod/tcp/Makefile
config.status: creating nemesis/netmod/psm/Makefile
config.status: creating nemesis/netmod/newmad/Makefile
config.status: creating nemesis/netmod/none/Makefile
config.status: creating nemesis/include/mpid_nem_net_module_defs.h
config.status: creating nemesis/src/mpid_nem_net_array.c
config.status: creating include/mpidi_ch3i_nemesis_conf.h
config.status: include/mpidi_ch3i_nemesis_conf.h is unchanged
configure: ===== done with channels/nemesis configure =====
config.status: creating util/Makefile
config.status: creating channels/Makefile
config.status: creating util/ftb/Makefile
config.status: creating include/mpid_thread.h
config.status: creating include/mpidi_ch3_conf.h
config.status: include/mpidi_ch3_conf.h is unchanged
config.status: executing default-1 commands
copying /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/../common/thread/mpid_thread_mpe.c to src/mpid_thread.c
configure: ===== done with src/mpid/ch3 configure =====
configure: ===== configuring src/mpi/romio =====
configure: executing: /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/romio/configure  '--prefix=/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1-install' '--enable-fast=O2' '--enable-shared' --disable-option-checking
Configuring with args --prefix=/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1-install --enable-fast=O2 --enable-shared --disable-option-checking
checking for architecture... i686
configure: WARNING: Unknown architecture ... proceeding anyway
ROMIO home directory is /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/romio
checking for memalign... yes
checking Fortran external names
Fortran externals have a trailing underscore and are lowercase
checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking for fcntl.h... yes
checking malloc.h usability... yes
checking malloc.h presence... yes
checking for malloc.h... yes
checking for u_char... yes
checking for u_short... yes
checking for u_int... yes
checking for u_long... yes
checking sys/attr.h usability... no
checking sys/attr.h presence... no
checking for sys/attr.h... no
checking for int large enough for pointers... yes
checking for Fortran 90 KIND parameter for 8-byte integers...            8
checking that we can use integer*8 to declare MPI_DISPLACMENT_CURRENT... yes
Overriding Array test for MPICH2
checking for weak symbol support... pragma weak
checking that weak symbols are visible to other files... no
no
checking whether struct flock compatible with MPI_Offset... yes
checking for pvfs2-config... notfound
checking configured file systems... testfs ufs nfs
configure: WARNING: File locks may not work with NFS.  See the Installation and
users manual for instructions on testing and if necessary fixing this
checking for library containing aio_write... no
checking for library containing pthread_create... none required
checking for library containing aio_write... (cached) no
checking if aio.h exists and can be compiled... no
checking if sys/aio.h exists and can be compiled... no
checking sys/vfs.h usability... yes
checking sys/vfs.h presence... yes
checking for sys/vfs.h... yes
checking sys/mount.h usability... yes
checking sys/mount.h presence... yes
checking for sys/mount.h... yes
checking sys/statvfs.h usability... yes
checking sys/statvfs.h presence... yes
checking for sys/statvfs.h... yes
checking whether struct statfs properly defined... yes
checking for f_fstypename member of statfs structure... no
checking for sys/stat.h... (cached) yes
checking for stat... yes
checking for st_fstype member of stat structure... no
checking for sys/statvfs.h... (cached) yes
checking for sys/vfs.h... (cached) yes
checking for statvfs... yes
checking for f_basetype member of statvfs structure... no
checking for large file defines... no
checking for lstat... yes
checking whether lstat needs a declaration... yes
checking for readlink... yes
checking whether readlink needs a declaration... no
checking for fsync... yes
checking whether fsync needs a declaration... no
checking for ftruncate... yes
checking whether ftruncate needs a declaration... no
checking for lseek64... no
checking for large file defines... none
setting SYSDEP_INC to
setting CC to gcc
setting F77 to gfortran
setting TEST_CC to /tmp/sgthomas/mpich2-1.3.2p1/bin/mpicc
setting TEST_F77 to /tmp/sgthomas/mpich2-1.3.2p1/bin/mpif77
setting CFLAGS to    -O2  -DFORTRANUNDERSCORE -DHAVE_ROMIOCONF_H
setting USER_CFLAGS to
setting USER_FFLAGS to
config.status: creating mpi-io/Makefile
config.status: creating mpi2-other/info/Makefile
config.status: creating mpi2-other/array/Makefile
config.status: creating adio/common/Makefile
config.status: creating test/misc.c
config.status: creating test/large_file.c
config.status: creating test/runtests
config.status: creating test-internal/Makefile
config.status: creating util/romioinstall
config.status: creating include/mpio.h
config.status: creating include/mpiof.h
config.status: creating adio/ad_nfs/Makefile
config.status: creating adio/ad_ufs/Makefile
config.status: creating adio/ad_bgl/Makefile
config.status: creating adio/ad_bglockless/Makefile
config.status: creating adio/ad_panfs/Makefile
config.status: creating adio/ad_xfs/Makefile
config.status: creating adio/ad_sfs/Makefile
config.status: creating adio/ad_pfs/Makefile
config.status: creating adio/ad_testfs/Makefile
config.status: creating adio/ad_pvfs/Makefile
config.status: creating adio/ad_pvfs2/Makefile
config.status: creating adio/ad_gridftp/Makefile
config.status: creating adio/ad_lustre/Makefile
config.status: creating adio/ad_zoidfs/Makefile
config.status: creating mpi-io/fortran/Makefile
config.status: creating mpi2-other/info/fortran/Makefile
config.status: creating mpi2-other/array/fortran/Makefile
config.status: creating test/fmisc.f
config.status: creating test/fcoll_test.f
config.status: creating test/pfcoll_test.f
config.status: creating test/fperf.f
config.status: creating mpi-io/glue/mpich2/Makefile
config.status: creating mpi-io/glue/mpich1/Makefile
config.status: creating mpi-io/glue/default/Makefile
config.status: creating common/dataloop/Makefile
config.status: creating adio/include/romioconf.h
configure: ===== done with src/mpi/romio configure =====
configure: ===== configuring src/pmi/simple =====
configure: executing: /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/pmi/simple/configure  '--prefix=/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1-install' '--enable-fast=O2' '--enable-shared' --disable-option-checking
RUNNING CONFIGURE FOR THE SIMPLE PMI
checking for strings.h... (cached) yes
checking for sys/socket.h... (cached) yes
checking netinet/in.h usability... yes
checking netinet/in.h presence... yes
checking netinet/tcp.h usability... yes
checking netinet/tcp.h presence... yes
checking for netinet/tcp.h... yes
checking sys/un.h usability... yes
checking sys/un.h presence... yes
checking for sys/un.h... yes
checking for library containing socket... none required
checking for library containing gethostbyname... none required
checking for socket... yes
checking for setsockopt... yes
checking for gethostbyname... yes
checking whether socklen_t is defined (in sys/socket.h if present)... yes
config.status: creating pmiconf.h
config.status: pmiconf.h is unchanged
configure: ===== done with src/pmi/simple configure =====
configure: ===== configuring src/pm/hydra =====
configure: executing: /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/pm/hydra/configure  '--prefix=/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1-install' '--enable-fast=O2' '--enable-shared' --disable-option-checking
checking for a thread-safe mkdir -p... mkdir -p
checking for doxygen... /usr/bin/doxygen
checking ifaddrs.h usability... yes
checking ifaddrs.h presence... yes
checking for ifaddrs.h... yes
checking poll.h usability... yes
checking poll.h presence... yes
checking for poll.h... yes
checking for netdb.h... (cached) yes
checking winsock2.h usability... no
checking winsock2.h presence... yes
configure: WARNING: winsock2.h: present but cannot be compiled
configure: WARNING: winsock2.h:     check for missing prerequisite headers?
configure: WARNING: winsock2.h: see the Autoconf documentation
configure: WARNING: winsock2.h:     section "Present But Cannot Be Compiled"
configure: WARNING: winsock2.h: proceeding with the preprocessor's result
configure: WARNING: winsock2.h: in the future, the compiler will take precedence
checking for winsock2.h... yes
checking windows.h usability... yes
checking windows.h presence... yes
checking for windows.h... yes
checking for socket in -lsocket... no
checking for gethostbyname in -lnsl... no
checking for sigaction... yes
checking for alloca... no
checking for unsetenv... yes
checking for strsignal... yes
checking for getifaddrs... yes
checking for fcntl... yes
checking for isatty... yes
checking for environ in unistd.h... yes
checking bootstrap server... none,ssh,rsh,fork,slurm,ll,lsf,sge,persist,pbs
checking process manager... pmiserv
checking user interface... mpich
checking desired process binding libraries... hwloc,plpa
configure: ===== configuring tools/bind/hwloc/hwloc =====
configure: executing: /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/pm/hydra/tools/bind/hwloc/hwloc/configure --enable-embedded-mode '--prefix=/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1-install' '--enable-fast=O2' '--enable-shared' '--disable-option-checking' 'CC=gcc' 'CFLAGS=   -O2 ' 'LDFLAGS=' 'LDFLAGS= ' 'LIBS=' 'LIBS=-lpthread  ' 'CPPFLAGS= -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers' --disable-option-checking
### Configuring hwloc distribution tarball
### Startup tests
checking target system type... i686-pc-cygwin
checking how to create a ustar tar archive... gnutar
checking for hwloc version... 1.1.1rc4-1
checking whether gcc and cc understand -c and -o together... yes
checking for pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
### Configuring hwloc core
checking hwloc building mode... embedded
configure: hwloc builddir: /tmp/sgthomas/mpich2-1.3.2p1/src/pm/hydra/tools/bind/hwloc/hwloc
configure: hwloc srcdir: /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/pm/hydra/tools/bind/hwloc/hwloc
configure: Detected VPATH build
checking if want hwloc maintainer support... disabled (embedded mode)
checking for hwloc directory prefix... (none)
checking for hwloc symbol prefix... hwloc_
checking for gcc option to accept ISO C99... -std=gnu99
checking minix/config.h usability... no
checking minix/config.h presence... no
checking for minix/config.h... no
checking whether it is safe to define __EXTENSIONS__... yes
checking which OS support to include... Windows
checking which CPU support to include... x86_32
checking for __attribute__... yes
checking for __attribute__(aligned)... yes
checking for __attribute__(always_inline)... yes
checking for __attribute__(cold)... yes
checking for __attribute__(const)... yes
checking for __attribute__(deprecated)... yes
checking for __attribute__(format)... no
checking for __attribute__(hot)... yes
checking for __attribute__(malloc)... yes
checking for __attribute__(may_alias)... yes
checking for __attribute__(no_instrument_function)... yes
checking for __attribute__(nonnull)... no
checking for __attribute__(noreturn)... yes
checking for __attribute__(packed)... yes
checking for __attribute__(pure)... yes
checking for __attribute__(sentinel)... no
checking for __attribute__(unused)... yes
checking for __attribute__(warn_unused_result)... yes
checking for __attribute__(weak_alias)... yes
checking whether to enable visibility... no (disabled)
checking for inline compatibility keyword... __inline__
checking whether function strncasecmp is declared... yes
checking for strftime... yes
checking for setlocale... yes
checking for KAFFINITY... no
checking for PROCESSOR_CACHE_TYPE... no
checking for CACHE_DESCRIPTOR... no
checking for LOGICAL_PROCESSOR_RELATIONSHIP... no
checking for RelationProcessorPackage... no
checking for SYSTEM_LOGICAL_PROCESSOR_INFORMATION... no
checking for GROUP_AFFINITY... no
checking for PROCESSOR_RELATIONSHIP... no
checking for NUMA_NODE_RELATIONSHIP... no
checking for CACHE_RELATIONSHIP... no
checking for PROCESSOR_GROUP_INFO... no
checking for GROUP_RELATIONSHIP... no
checking for SYSTEM_LOGICAL_PROCESSOR_INFORMATION_EX... no
checking for PSAPI_WORKING_SET_EX_BLOCK... no
checking for PSAPI_WORKING_SET_EX_INFORMATION... no
checking for main in -lgdi32... yes
checking sys/lgrp_user.h usability... no
checking sys/lgrp_user.h presence... no
checking for sys/lgrp_user.h... no
checking kstat.h usability... no
checking kstat.h presence... no
checking for kstat.h... no
checking whether _SC_NPROCESSORS_ONLN is declared... yes
checking whether _SC_NPROCESSORS_CONF is declared... yes
checking whether _SC_NPROC_ONLN is declared... no
checking whether _SC_NPROC_CONF is declared... no
checking whether _SC_LARGE_PAGESIZE is declared... no
checking mach/mach_host.h usability... no
checking mach/mach_host.h presence... no
checking for mach/mach_host.h... no
checking mach/mach_init.h usability... no
checking mach/mach_init.h presence... no
checking for mach/mach_init.h... no
checking for sys/sysctl.h... no
checking for sysctl... no
checking for sysctlbyname... no
checking whether function sched_setaffinity is declared... no
checking for working CPU_SET... no
checking for working CPU_SET_S... no
checking for working _syscall3... no
checking for KERRIGHED... no
checking for lib... no
checking for bash... /usr/bin/sh
checking for ffs... yes
checking whether function ffs is declared... yes
checking for ffsl... no
checking for fls... no
checking for flsl... no
checking for clz... no
checking for clzl... no
checking for openat... yes
checking for getpagesize... yes
checking for posix_memalign... yes
checking sys/utsname.h usability... yes
checking sys/utsname.h presence... yes
checking for sys/utsname.h... yes
checking for uname... yes
checking numaif.h usability... no
checking numaif.h presence... no
checking for numaif.h... no
checking pthread_np.h usability... no
checking pthread_np.h presence... no
checking for pthread_np.h... no
checking whether pthread_setaffinity_np is declared... no
checking whether pthread_getaffinity_np is declared... no
checking for sys/cpuset.h... no
checking for library containing pthread_getthrds_np... no
checking for XML... yes
checking for xmlNewDoc... yes
checking for final XML support... yes
checking for cpuid... yes
checking for X... libraries , headers
checking for as... as
checking for dlltool... dlltool
checking for objdump... (cached) objdump
checking whether to build static libraries... no
config.status: creating include/Makefile
config.status: creating include/private/config.h
config.status: include/private/config.h is unchanged
config.status: creating include/hwloc/config.h
config.status: include/hwloc/config.h is unchanged
configure: ===== done with tools/bind/hwloc/hwloc configure =====
configure: ===== configuring tools/bind/plpa/plpa =====
configure: executing: /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/pm/hydra/tools/bind/plpa/plpa/configure  '--prefix=/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1-install' '--enable-fast=O2' '--enable-shared' '--disable-option-checking' 'CC=gcc' 'CFLAGS=   -O2 ' 'LDFLAGS=' 'LDFLAGS= ' 'LIBS=' 'LIBS=-lpthread  ' 'CPPFLAGS= -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers' --disable-option-checking
checking for PLPA version... 1.3.2
checking whether to enable "picky" compiler mode... no (default)
checking for flex... flex
checking lex output file root... lex.yy
checking lex library... -lfl
checking whether yytext is a pointer... yes
checking for bison... bison -y
checking for syscall... no
configure: error: Cannot continue
configure: ===== done with tools/bind/plpa/plpa configure =====
checking available process binding libraries...
checking checkpointing library... none
checking demux engine... poll,select,port
checking for poll... yes
checking debugging support... none
checking error checking... yes
checking warnings... no
checking profiling... yes
checking libftb.h usability... no
checking libftb.h presence... no
checking for libftb.h... no
checking for FTB_Connect in -lftb... no
checking for strsignal... (cached) yes
checking whether strsignal needs a declaration... no
checking for sigaction... (cached) yes
checking for signal... (cached) yes
checking for sigset... yes
checking for struct sigaction and sa_handler... yes
config.status: creating tools/bootstrap/src/bsci_init.c
config.status: creating tools/bootstrap/include/bsci.h
config.status: creating hydra-doxygen.cfg
config.status: creating include/hydra_config.h
configure: ===== done with src/pm/hydra configure =====
configure: ===== configuring src/mpe2 =====
configure: executing: /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpe2/configure  '--prefix=/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1-install' '--enable-fast=O2' '--enable-shared' --disable-option-checking
Configuring MPE Profiling System with  '--prefix=/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1-install' '--enable-fast=O2' '--enable-shared' '--disable-option-checking' 'MPI_CC=/tmp/sgthomas/mpich2-1.3.2p1/bin/mpicc' 'MPI_F77=/tmp/sgthomas/mpich2-1.3.2p1/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lpthread  ' 'CPPFLAGS= -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers' 'F77=gfortran' 'FFLAGS=  -O2'
checking gnumake... yes using --no-print-directory
checking BSD 4.4 make... no - whew
checking OSF V3 make... no
This MPE build is part of the MPICH2 build
checking for leftover Makefiles in subpackages ...  "src/misc" "src/callstack" "src/logging" "src/wrappers" "src/graphics" "src/collchk" cleaned
checking whether MPI_CC has been set ... /tmp/sgthomas/mpich2-1.3.2p1/bin/mpicc
checking whether MPI_F77 has been set ... /tmp/sgthomas/mpich2-1.3.2p1/bin/mpif77
checking for Fortran 77 libraries of gfortran...  -L/usr/lib/gcc/i686-pc-cygwin/4.3.4 -L/usr/lib/gcc/i686-pc-cygwin/4.3.4/../../.. -lpthread -lgfortranbegin -lgfortran -lcygwin -luser32 -lkernel32 -ladvapi32 -lshell32
checking whether C can link with  -L/usr/lib/gcc/i686-pc-cygwin/4.3.4 -L/usr/lib/gcc/i686-pc-cygwin/4.3.4/../../.. -lpthread -lgfortranbegin -lgfortran -lcygwin -luser32 -lkernel32 -ladvapi32 -lshell32... yes
config.status: creating sbin/mpetestlink
config.status: creating sbin/mpetestexec
config.status: creating sbin/mpetestexeclog
config.status: creating sbin/mpeinstall
config.status: creating sbin/mpecheckinstall
config.status: WARNING:  '/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpe2/sbin/mpecheckinstall.in' seems to ignore the --datarootdir setting
config.status: creating sbin/mpecheckbuild
config.status: creating etc/mpe_help.conf
config.status: creating etc/mpe_f77env.conf
config.status: creating mpe_conf.h
config.status: mpe_conf.h is unchanged
=== configuring in src/misc (/tmp/sgthomas/mpich2-1.3.2p1/src/mpe2/src/misc)
configure: running /bin/sh /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpe2/src/misc/configure --disable-option-checking '--prefix=/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1-install'  '--enable-fast=O2' '--enable-shared' 'MPI_CC=/tmp/sgthomas/mpich2-1.3.2p1/bin/mpicc' 'MPI_F77=/tmp/sgthomas/mpich2-1.3.2p1/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lpthread  ' 'CPPFLAGS= -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers' 'F77=gfortran' 'FFLAGS=  -O2' --cache-file=/dev/null --srcdir=/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpe2/src/misc
Configuring MPE Miscellaneous Library with  '--disable-option-checking' '--prefix=/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1-install' '--enable-fast=O2' '--enable-shared' 'MPI_CC=/tmp/sgthomas/mpich2-1.3.2p1/bin/mpicc' 'MPI_F77=/tmp/sgthomas/mpich2-1.3.2p1/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lpthread  ' 'CPPFLAGS= -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers' 'F77=gfortran' 'FFLAGS=  -O2' '--cache-file=/dev/null' '--srcdir=/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpe2/src/misc'
checking for dbx... no
checking for gdb... /usr/bin/gdb
checking for sysinfo... no
checking sys/systeminfo.h usability... no
checking sys/systeminfo.h presence... no
checking for sys/systeminfo.h... no
checking for sighandler_t... yes
checking for kill... yes
checking whether kill needs a declaration... no
config.status: creating src/dbxerr.c
config.status: creating mpe_misc_conf.h
=== configuring in src/callstack (/tmp/sgthomas/mpich2-1.3.2p1/src/mpe2/src/callstack)
configure: running /bin/sh /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpe2/src/callstack/configure --disable-option-checking '--prefix=/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1-install'  '--enable-fast=O2' '--enable-shared' 'MPI_CC=/tmp/sgthomas/mpich2-1.3.2p1/bin/mpicc' 'MPI_F77=/tmp/sgthomas/mpich2-1.3.2p1/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lpthread  ' 'CPPFLAGS= -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers' 'F77=gfortran' 'FFLAGS=  -O2' --cache-file=/dev/null --srcdir=/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpe2/src/callstack
Configuring MPE CallStack Library with  '--disable-option-checking' '--prefix=/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1-install' '--enable-fast=O2' '--enable-shared' 'MPI_CC=/tmp/sgthomas/mpich2-1.3.2p1/bin/mpicc' 'MPI_F77=/tmp/sgthomas/mpich2-1.3.2p1/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lpthread  ' 'CPPFLAGS= -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers' 'F77=gfortran' 'FFLAGS=  -O2' '--cache-file=/dev/null' '--srcdir=/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpe2/src/callstack'
checking execinfo.h usability... no
checking execinfo.h presence... no
checking for execinfo.h... no
checking ucontext.h usability... no
checking ucontext.h presence... no
checking for ucontext.h... no
checking whether fdopen needs a declaration... no
config.status: creating include/mpe_callstack.h
config.status: creating etc/mpe_callstack_ldflags.conf
config.status: creating bin/bt2line
config.status: creating mpe_callstack_conf.h
=== configuring in src/logging (/tmp/sgthomas/mpich2-1.3.2p1/src/mpe2/src/logging)
configure: running /bin/sh /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpe2/src/logging/configure --disable-option-checking '--prefix=/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1-install'  '--enable-fast=O2' '--enable-shared' 'MPI_CC=/tmp/sgthomas/mpich2-1.3.2p1/bin/mpicc' 'MPI_F77=/tmp/sgthomas/mpich2-1.3.2p1/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lpthread  ' 'CPPFLAGS= -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers' 'F77=gfortran' 'FFLAGS=  -O2' --cache-file=/dev/null --srcdir=/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpe2/src/logging
Configuring MPE Logging Library and Tools with  '--disable-option-checking' '--prefix=/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1-install' '--enable-fast=O2' '--enable-shared' 'MPI_CC=/tmp/sgthomas/mpich2-1.3.2p1/bin/mpicc' 'MPI_F77=/tmp/sgthomas/mpich2-1.3.2p1/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lpthread  ' 'CPPFLAGS= -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers' 'F77=gfortran' 'FFLAGS=  -O2' '--cache-file=/dev/null' '--srcdir=/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpe2/src/logging'
checking for header that defines C99 integer types, intXX_t ... <stdint.h>
checking whether <inttypes.h> defines the PRIdXX macros ... yes
checking if <stdint.h> can be behind system headers ... yes
checking for address-sized integer ... CLOG_int32_t
checking for srand48... yes
checking whether srand48 needs a declaration... no
checking for lrand48... yes
checking whether lrand48 needs a declaration... no
checking for special C compiler options needed for large files... no
checking for _FILE_OFFSET_BITS value needed for large files... no
checking for O_LARGEFILE for open() ... no
checking for O_BINARY for open() ... yes
checking for pthread_mutex_lock in -lpthread... yes
config.status: creating include/clog_inttypes.h
config.status: creating include/mpi_null.h
config.status: creating include/mpe_log_thread.h
config.status: creating etc/mpe_log.conf
config.status: creating etc/mpe_nolog.conf
config.status: creating etc/mpe_log_postlib.conf
config.status: creating mpe_logging_conf.h
=== configuring in src/wrappers (/tmp/sgthomas/mpich2-1.3.2p1/src/mpe2/src/wrappers)
configure: running /bin/sh /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpe2/src/wrappers/configure --disable-option-checking '--prefix=/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1-install'  '--enable-fast=O2' '--enable-shared' 'MPI_CC=/tmp/sgthomas/mpich2-1.3.2p1/bin/mpicc' 'MPI_F77=/tmp/sgthomas/mpich2-1.3.2p1/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lpthread  ' 'CPPFLAGS= -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers' 'F77=gfortran' 'FFLAGS=  -O2' --cache-file=/dev/null --srcdir=/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpe2/src/wrappers
Configuring MPE Wrapper Libraries For MPI with  '--disable-option-checking' '--prefix=/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1-install' '--enable-fast=O2' '--enable-shared' 'MPI_CC=/tmp/sgthomas/mpich2-1.3.2p1/bin/mpicc' 'MPI_F77=/tmp/sgthomas/mpich2-1.3.2p1/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lpthread  ' 'CPPFLAGS= -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers' 'F77=gfortran' 'FFLAGS=  -O2' '--cache-file=/dev/null' '--srcdir=/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpe2/src/wrappers'
checking for gcc... gcc
checking for C compiler default output file name... a.exe
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables... .exe
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for ar... ar
checking for ranlib... ranlib
checking how to run the C preprocessor... gcc -E
checking for grep that handles long lines and -e... /usr/bin/grep
checking for egrep... /usr/bin/grep -E
checking for ANSI C header files... yes
checking for an ANSI C-conforming const... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking stdio.h usability... yes
checking stdio.h presence... yes
checking for stdio.h... yes
checking for stdlib.h... (cached) yes
checking for string.h... (cached) yes
checking stdarg.h usability... yes
checking stdarg.h presence... yes
checking for stdarg.h... yes
checking for stdarg is correct... yes
checking if compiler accepts prototypes ... yes
checking build system type... i686-pc-cygwin
checking host system type... i686-pc-cygwin
checking for safe PMPI invocations ... no
checking for the value of MPI_STATUS_SIZE ... 5
config.status: creating etc/mpe_mpilog.conf
config.status: creating etc/mpe_mpitrace.conf
config.status: creating mpe_wrappers_conf.h
=== configuring in src/graphics (/tmp/sgthomas/mpich2-1.3.2p1/src/mpe2/src/graphics)
configure: running /bin/sh /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpe2/src/graphics/configure --disable-option-checking '--prefix=/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1-install'  '--enable-fast=O2' '--enable-shared' 'MPI_CC=/tmp/sgthomas/mpich2-1.3.2p1/bin/mpicc' 'MPI_F77=/tmp/sgthomas/mpich2-1.3.2p1/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lpthread  ' 'CPPFLAGS= -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers' 'F77=gfortran' 'FFLAGS=  -O2' --cache-file=/dev/null --srcdir=/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpe2/src/graphics
Configuring MPE X Graphics Library with  '--disable-option-checking' '--prefix=/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1-install' '--enable-fast=O2' '--enable-shared' 'MPI_CC=/tmp/sgthomas/mpich2-1.3.2p1/bin/mpicc' 'MPI_F77=/tmp/sgthomas/mpich2-1.3.2p1/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lpthread  ' 'CPPFLAGS= -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers' 'F77=gfortran' 'FFLAGS=  -O2' '--cache-file=/dev/null' '--srcdir=/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpe2/src/graphics'
checking size of void *... 4
checking for long pointer... no
checking for system... yes
configure: creating ./config.status
config.status: creating Makefile
config.status: creating src/Makefile
config.status: creating contrib/life/Makefile
config.status: creating contrib/mandel/Makefile
config.status: creating contrib/mastermind/Makefile
config.status: creating contrib/test/Makefile
config.status: creating etc/mpe_mpianim.conf
config.status: creating etc/mpe_graphics.conf
config.status: creating mpe_graphics_conf.h
=== configuring in src/collchk (/tmp/sgthomas/mpich2-1.3.2p1/src/mpe2/src/collchk)
configure: running /bin/sh /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpe2/src/collchk/configure --disable-option-checking '--prefix=/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1-install'  '--enable-fast=O2' '--enable-shared' 'MPI_CC=/tmp/sgthomas/mpich2-1.3.2p1/bin/mpicc' 'MPI_F77=/tmp/sgthomas/mpich2-1.3.2p1/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lpthread  ' 'CPPFLAGS= -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers' 'F77=gfortran' 'FFLAGS=  -O2' --cache-file=/dev/null --srcdir=/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpe2/src/collchk
Configuring MPE Collective and Datatype Checking Library with  '--disable-option-checking' '--prefix=/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1-install' '--enable-fast=O2' '--enable-shared' 'MPI_CC=/tmp/sgthomas/mpich2-1.3.2p1/bin/mpicc' 'MPI_F77=/tmp/sgthomas/mpich2-1.3.2p1/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lpthread  ' 'CPPFLAGS= -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers' 'F77=gfortran' 'FFLAGS=  -O2' '--cache-file=/dev/null' '--srcdir=/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpe2/src/collchk'
checking for virtual path format... VPATH
config.status: creating test/Makefile
config.status: creating etc/mpe_mpicheck.conf
config.status: creating mpe_collchk_conf.h
=== configuring in src/slog2sdk (/tmp/sgthomas/mpich2-1.3.2p1/src/mpe2/src/slog2sdk)
configure: running /bin/sh /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpe2/src/slog2sdk/configure --disable-option-checking '--prefix=/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1-install'  '--enable-fast=O2' '--enable-shared' 'MPI_CC=/tmp/sgthomas/mpich2-1.3.2p1/bin/mpicc' 'MPI_F77=/tmp/sgthomas/mpich2-1.3.2p1/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lpthread  ' 'CPPFLAGS= -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers' 'F77=gfortran' 'FFLAGS=  -O2' --cache-file=/dev/null --srcdir=/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpe2/src/slog2sdk
Configuring SLOG2SDK with  '--disable-option-checking' '--prefix=/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1-install' '--enable-fast=O2' '--enable-shared' 'MPI_CC=/tmp/sgthomas/mpich2-1.3.2p1/bin/mpicc' 'MPI_F77=/tmp/sgthomas/mpich2-1.3.2p1/bin/mpif77' 'CC=gcc' 'CFLAGS=   -O2' 'LDFLAGS= ' 'LIBS=-lpthread  ' 'CPPFLAGS= -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers' 'F77=gfortran' 'FFLAGS=  -O2' '--cache-file=/dev/null' '--srcdir=/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpe2/src/slog2sdk'
checking for a BSD-compatible install... /usr/bin/install -c
checking whether install works... yes
checking if CLASSPATH is set... yes
checking if CLASSPATH contains current path... no, prepend . to CLASSPATH
checking for java in user's PATH... found /cygdrive/c/Windows/system32/java
checking if /cygdrive/c/Windows/system32/java runs simple java class... no
checking for java in user's PATH... not found
configure: WARNING:  No Java Virtual Machine can be found anywhere!
MPE2:  "src/misc" "src/callstack" "src/logging" "src/wrappers" "src/graphics" "src/collchk" have been configured
configure: ===== done with src/mpe2 configure =====
checking size of OPA_ptr_t... 4
checking the sizeof MPI_Offset... 8
checking whether the Fortran Offset type works with Fortran 77... yes
checking whether the Fortran Offset type works with Fortran 90... yes
Running Configure for Fortran 90 Type routines
configure: WARNING: unrecognized options: --enable-fast, --enable-shared
checking for fgrep... /usr/bin/grep -F
checking whether we are using the GNU Fortran compiler... yes
checking whether gfortran accepts -g... yes
checking for extension for Fortran 90 programs... f90
checking for the precision and range of reals...  6 , 37
checking for the precision and range of double precision...  15 , 307
checking for the range of integer...  9
checking whether we are using the GNU Fortran 77 compiler... yes
checking for linker for Fortran main programs... Use Fortran to link programs
checking for Fortran 77 name mangling... lower underscore
checking for available integer kinds...  2 , 1, 4 , 2, 9 , 4, 18 , 8,
checking for available integer ranges...  {  2 , 1 , 1 }, {  4 , 2 , 2 }, {  9 , 4 , 4 }, {  18 , 8 , 8 },
config.status: creating mpif90model.h
config.status: creating src/include/Makefile
config.status: creating src/include/mpich2info.h
config.status: creating mpich2-doxygen
config.status: creating src/include/mpichtimer.h
config.status: creating src/binding/Makefile
config.status: creating src/binding/cxx/Makefile
config.status: creating src/binding/cxx/mpicxx.h
config.status: creating src/binding/f77/Makefile
config.status: creating src/binding/f77/mpif.h
config.status: creating src/binding/f77/setbotf.f
config.status: creating src/binding/f77/setbot.c
config.status: creating src/binding/f90/Makefile
config.status: creating src/binding/f90/mpi_sizeofs.f90
config.status: creating src/binding/f90/mpi_base.f90
config.status: creating src/packaging/Makefile
config.status: creating src/packaging/pkgconfig/mpich2-c.pc
config.status: creating src/packaging/pkgconfig/mpich2-cxx.pc
config.status: creating src/packaging/pkgconfig/mpich2-f77.pc
config.status: creating src/packaging/pkgconfig/mpich2-f90.pc
config.status: creating src/packaging/pkgconfig/Makefile
config.status: creating src/packaging/envmods/mpich2.module
config.status: WARNING:  '/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/packaging/envmods/mpich2.module.in' seems to ignore the --datarootdir setting
config.status: creating src/packaging/envmods/Makefile
config.status: creating src/env/mpixxx_opts.conf
config.status: creating src/env/mpicc
config.status: creating src/env/mpicc.conf
config.status: creating src/env/mpicc.bash
config.status: creating src/env/mpicxx
config.status: creating src/env/mpicxx.conf
config.status: creating src/env/mpicxx.bash
config.status: creating src/env/mpif77
config.status: creating src/env/mpif77.conf
config.status: creating src/env/mpif77.bash
config.status: creating src/env/mpif90
config.status: creating src/env/mpif90.conf
config.status: creating src/env/mpif90.bash
config.status: creating src/env/parkill
config.status: creating src/env/Makefile
config.status: creating src/util/createshlib
config.status: creating src/mpi/Makefile
config.status: creating src/mpi/attr/Makefile
config.status: creating src/mpi/coll/Makefile
config.status: creating src/mpi/comm/Makefile
config.status: creating src/mpi/datatype/Makefile
config.status: creating src/mpi/debugger/Makefile
config.status: creating src/mpi/errhan/Makefile
config.status: creating src/mpi/group/Makefile
config.status: creating src/mpi/init/Makefile
config.status: creating src/mpi/misc/Makefile
config.status: creating src/mpi/pt2pt/Makefile
config.status: creating src/mpi/rma/Makefile
config.status: creating src/mpi/spawn/Makefile
config.status: creating src/mpi/timer/Makefile
config.status: creating src/mpi/topo/Makefile
config.status: creating src/mpid/Makefile
config.status: creating src/mpid/common/Makefile
config.status: creating src/mpid/common/datatype/Makefile
config.status: creating src/mpid/common/datatype/dataloop/Makefile
config.status: creating src/pm/Makefile
config.status: creating src/pmi/Makefile
config.status: creating src/pmi/simple/Makefile
config.status: creating src/nameserv/Makefile
config.status: creating src/nameserv/file/Makefile
config.status: creating src/nameserv/mpd/Makefile
config.status: creating src/nameserv/pmi/Makefile
config.status: creating src/nameserv/test/Makefile
config.status: creating src/util/Makefile
config.status: creating src/util/info/Makefile
config.status: creating src/util/instrm/Makefile
config.status: creating src/util/thread/Makefile
config.status: creating src/util/mem/Makefile
config.status: creating src/util/msgs/Makefile
config.status: creating src/util/param/Makefile
config.status: creating src/util/dbg/Makefile
config.status: creating src/util/dbg/getfuncstack
config.status: creating src/util/osserv/Makefile
config.status: creating src/util/procmap/Makefile
config.status: creating src/util/other/Makefile
config.status: creating src/include/mpi.h
config.status: creating test/util/Makefile
config.status: creating test/basic/Makefile
config.status: creating test/commands/Makefile
config.status: creating test/commands/cmdtests
config.status: creating test/mpid/Makefile
config.status: creating test/mpid/ch3/Makefile
config.status: creating test/util/timer/Makefile
config.status: creating examples/Makefile
config.status: creating examples/f77/Makefile
config.status: creating examples/f90/Makefile
config.status: creating examples/cxx/Makefile
config.status: creating src/util/logging/Makefile
config.status: creating src/util/logging/common/Makefile
config.status: creating doc/Makefile
config.status: creating doc/mansrc/Makefile
config.status: creating doc/mansrc/createhtmlindex
config.status: creating doc/refman/Makefile
config.status: creating doc/installguide/Makefile
config.status: creating doc/userguide/Makefile
config.status: creating doc/logging/Makefile
config.status: creating doc/design/Makefile
config.status: creating doc/smpd/Makefile
config.status: creating doc/windev/Makefile
config.status: creating src/include/mpichconf.h
config.status: executing default-2 commands
config.status: executing default-3 commands
config.status: executing default-4 commands
config.status: executing default-5 commands
config.status: executing default-6 commands
config.status: executing default-7 commands
config.status: executing default-8 commands
config.status: executing default-9 commands
config.status: executing default-10 commands
config.status: executing default-11 commands
config.status: executing default-12 commands
config.status: executing default-13 commands
config.status: executing default-14 commands
=== configuring in test/mpi (/tmp/sgthomas/mpich2-1.3.2p1/test/mpi)
configure: running /bin/sh /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/test/mpi/configure --disable-option-checking '--prefix=/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1-install'  '--enable-fast=O2' '--enable-shared' --cache-file=/dev/null --srcdir=/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/test/mpi
RUNNING CONFIGURE FOR MPI TESTS
checking for make... make
checking whether clock skew breaks make... no
checking whether make supports include... yes
checking whether make allows comments in actions... yes
checking whether make sets CFLAGS... yes
checking whether /tmp/sgthomas/mpich2-1.3.2p1/bin/mpicc accepts -g... yes
checking for /tmp/sgthomas/mpich2-1.3.2p1/bin/mpicc option to accept ISO C89... none needed
checking whether long double is supported... yes
checking whether long long is supported... yes
checking for C/C++ restrict keyword... __restrict
checking how to run the C preprocessor... /tmp/sgthomas/mpich2-1.3.2p1/bin/mpicc -E
checking sys/time.h usability... yes
checking sys/time.h presence... yes
checking for sys/time.h... yes
checking for int8_t... yes
checking for int16_t... yes
checking for int32_t... yes
checking for int64_t... yes
checking for uint8_t... yes
checking for uint16_t... yes
checking for uint32_t... yes
checking for uint64_t... yes
checking for _Bool... yes
checking for float _Complex... yes
checking for double _Complex... yes
checking for long double _Complex... yes
checking pthread.h usability... yes
checking pthread.h presence... yes
checking for pthread.h... yes
checking for library containing pthread_barrier_init... no
checking for pthread_create... yes
checking for pthread_yield... yes
checking for pthread_barrier_init... no
checking for pthread_barrier_wait... no
checking whether struct hostent contains h_addr_list... no
checking for major version of MPI... 2
checking for minor version of MPI... 2
checking whether /tmp/sgthomas/mpich2-1.3.2p1/bin/mpif77 accepts -g... yes
checking whether integer*4 is supported... yes
checking whether integer*8 is supported... yes
checking whether integer*16 is supported... no
checking for Fortran libraries needed for getarg... none needed
checking whether Fortran 77 supports Cray-style pointer... with -fcray-pointer
checking whether /tmp/sgthomas/mpich2-1.3.2p1/bin/mpif90 accepts -g... yes
checking whether the Fortran 90 compiler (/tmp/sgthomas/mpich2-1.3.2p1/bin/mpif90  -nativelinking  ) works... yes
checking whether the Fortran 90 compiler (/tmp/sgthomas/mpich2-1.3.2p1/bin/mpif90  -nativelinking  ) is a cross-compiler... no
checking whether Fortran 90 supports Cray-style pointer... with -fcray-pointer
checking for Fortran flag needed to allow free-form source... none
checking whether we are using the GNU C++ compiler... yes
checking whether /tmp/sgthomas/mpich2-1.3.2p1/bin/mpicxx accepts -g... yes
checking whether <iostream> available... yes
checking whether the compiler implements namespaces... yes
checking whether the compiler implements the namespace std... yes
checking whether MPI_2DOUBLE_COMPLEX is available... no
checking whether MPI_2COMPLEX is available... no
checking size of int... 4
checking size of long... 4
checking size of long long... 8
checking size of short... 2
checking for C integer type of address size... int
checking for perl... /usr/bin/perl
config.status: creating maint/testmerge
config.status: creating runtests
config.status: creating basic/Makefile
config.status: creating attr/Makefile
config.status: creating util/Makefile
config.status: creating coll/Makefile
config.status: creating comm/Makefile
config.status: creating datatype/Makefile
config.status: creating errhan/Makefile
config.status: creating group/Makefile
config.status: creating info/Makefile
config.status: creating init/Makefile
config.status: creating pt2pt/Makefile
config.status: creating rma/Makefile
config.status: creating spawn/Makefile
config.status: creating topo/Makefile
config.status: creating io/Makefile
config.status: creating f77/Makefile
config.status: creating f77/attr/Makefile
config.status: creating f77/attr/attraints.h
config.status: creating f77/pt2pt/attr1aints.h
config.status: creating f77/ext/add1size.h
config.status: creating f77/datatype/Makefile
config.status: creating f77/datatype/typeaints.h
config.status: creating f77/util/Makefile
config.status: creating f77/coll/Makefile
config.status: creating f77/comm/Makefile
config.status: creating f77/topo/Makefile
config.status: creating f77/init/Makefile
config.status: creating f77/rma/addsize.h
config.status: creating f77/pt2pt/Makefile
config.status: creating f77/info/Makefile
config.status: creating f77/spawn/Makefile
config.status: creating f77/spawn/type1aint.h
config.status: creating f77/rma/Makefile
config.status: creating f77/ext/Makefile
config.status: creating f77/ext/testlist
config.status: creating f77/io/Makefile
config.status: creating f77/io/iooffset.h
config.status: creating f77/io/iodisp.h
config.status: creating f77/io/ioaint.h
config.status: creating f90/Makefile
config.status: creating f90/attr/Makefile
config.status: creating f90/datatype/Makefile
config.status: creating f90/f90types/Makefile
config.status: creating f90/util/Makefile
config.status: creating f90/coll/Makefile
config.status: creating f90/comm/Makefile
config.status: creating f90/topo/Makefile
config.status: creating f90/init/Makefile
config.status: creating f90/pt2pt/Makefile
config.status: creating f90/rma/Makefile
config.status: creating f90/info/Makefile
config.status: creating f90/spawn/Makefile
config.status: creating f90/timer/Makefile
config.status: creating f90/ext/Makefile
config.status: creating f90/ext/testlist
config.status: creating f90/io/Makefile
config.status: creating f90/misc/Makefile
config.status: creating cxx/Makefile
config.status: creating cxx/util/Makefile
config.status: creating cxx/attr/Makefile
config.status: creating cxx/pt2pt/Makefile
config.status: creating cxx/comm/Makefile
config.status: creating cxx/coll/Makefile
config.status: creating cxx/errhan/Makefile
config.status: creating cxx/info/Makefile
config.status: creating cxx/datatype/Makefile
config.status: creating cxx/io/Makefile
config.status: creating cxx/init/Makefile
config.status: creating cxx/rma/Makefile
config.status: creating cxx/spawn/Makefile
config.status: creating threads/Makefile
config.status: creating threads/pt2pt/Makefile
config.status: creating threads/util/Makefile
config.status: creating threads/comm/Makefile
config.status: creating threads/init/Makefile
config.status: creating threads/spawn/Makefile
config.status: creating errors/Makefile
config.status: creating errors/attr/Makefile
config.status: creating errors/basic/Makefile
config.status: creating errors/coll/Makefile
config.status: creating errors/comm/Makefile
config.status: creating errors/faults/Makefile
config.status: creating errors/group/Makefile
config.status: creating errors/pt2pt/Makefile
config.status: creating errors/rma/Makefile
config.status: creating errors/spawn/Makefile
config.status: creating errors/topo/Makefile
config.status: creating errors/io/Makefile
config.status: creating errors/cxx/Makefile
config.status: creating errors/cxx/errhan/Makefile
config.status: creating errors/cxx/io/Makefile
config.status: creating errors/f77/Makefile
config.status: creating errors/f90/Makefile
config.status: creating manual/Makefile
config.status: creating manual/manyconnect
config.status: creating perf/Makefile
config.status: creating testlist
config.status: creating cxx/testlist
config.status: creating f77/testlist
config.status: creating f90/testlist
config.status: creating threads/testlist
config.status: creating errors/testlist
config.status: creating errors/cxx/testlist
config.status: creating include/mpitestconf.h
config.status: include/mpitestconf.h is unchanged
config.status: executing default-1 commands
Configuration completed.
Beginning make
Using variables CC='gcc' CFLAGS='   -O2' LDFLAGS=' ' F77='gfortran' FFLAGS='  -O2' FC='gfortran' FCFLAGS='  -O2' CXX='c++' CXXFLAGS='  -O2' AR='ar' CPP='gcc -E' CPPFLAGS=' -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers'
make all-local
make[1]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1'
make[1]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1'
make[1]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpl'
  CC     mplstr.lo
  CC     mpltrmem.lo
  CC     mplenv.lo
  CCLD   libmpl.la
libtool: link: warning: undefined symbols not allowed in i686-pc-cygwin shared libraries
make[1]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpl'
make[1]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/openpa'
Making all in src
make[2]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src'
make  all-am
make[3]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src'
/bin/sh ../libtool --tag=CC   --mode=compile gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src      -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c -o opa_primitives.lo /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src/opa_primitives.c
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src/opa_primitives.c  -DDLL_EXPORT -DPIC -o .libs/opa_primitives.o
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src/opa_primitives.c -o opa_primitives.o >/dev/null 2>&1
mv -f .deps/opa_primitives.Tpo .deps/opa_primitives.Plo
/bin/sh ../libtool --tag=CC   --mode=compile gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src      -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c -o opa_queue.lo /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src/opa_queue.c
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src/opa_queue.c  -DDLL_EXPORT -DPIC -o .libs/opa_queue.o
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src/opa_queue.c -o opa_queue.o >/dev/null 2>&1
mv -f .deps/opa_queue.Tpo .deps/opa_queue.Plo
/bin/sh ../libtool --tag=CC   --mode=link gcc   -version-info 1:0  -o libopa.la -rpath /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1-install/lib opa_primitives.lo opa_queue.lo  -lpthread
libtool: link: ar cru .libs/libopa.a  opa_primitives.o opa_queue.o
libtool: link: ranlib .libs/libopa.a
libtool: link: ( cd ".libs" && rm -f "libopa.la" && ln -s "../libopa.la" "libopa.la" )
make[3]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src'
make[2]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src'
Making all in test
make[2]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/test'
make[2]: Nothing to be done for `all'.
make[2]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/test'
make[2]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/openpa'
make[2]: Nothing to be done for `all-am'.
make[2]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/openpa'
make[1]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/openpa'
make[1]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src'
make[2]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpl'
make[2]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpl'
make[2]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpid'
make[3]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common'
make[4]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype'
make[5]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop/.. -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop/dataloop.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop/.. -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop/segment.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop/.. -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop/segment_packunpack.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop/.. -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop/segment_flatten.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop/.. -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop/segment_count.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop/.. -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop/dataloop_create.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop/.. -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop/dataloop_create_contig.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop/.. -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop/dataloop_create_vector.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop/.. -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop/dataloop_create_blockindexed.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop/.. -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop/dataloop_create_indexed.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop/.. -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop/dataloop_create_struct.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop/.. -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop/dataloop_create_pairtype.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop/.. -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop/subarray_support.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop/.. -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop/darray_support.c
ar cr ../../../../../lib/libmpich.a dataloop.o segment.o segment_packunpack.o segment_flatten.o segment_count.o dataloop_create.o dataloop_create_contig.o dataloop_create_vector.o dataloop_create_blockindexed.o dataloop_create_indexed.o dataloop_create_struct.o dataloop_create_pairtype.o subarray_support.o darray_support.o
ranlib ../../../../../lib/libmpich.a
date > .libstamp0
make[6]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop/.. -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop/dataloop.c -o _sdataloop.o
mv -f _sdataloop.o dataloop.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop/.. -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop/segment.c -o _ssegment.o
mv -f _ssegment.o segment.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop/.. -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop/segment_packunpack.c -o _ssegment_packunpack.o
mv -f _ssegment_packunpack.o segment_packunpack.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop/.. -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop/segment_flatten.c -o _ssegment_flatten.o
mv -f _ssegment_flatten.o segment_flatten.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop/.. -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop/segment_count.c -o _ssegment_count.o
mv -f _ssegment_count.o segment_count.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop/.. -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop/dataloop_create.c -o _sdataloop_create.o
mv -f _sdataloop_create.o dataloop_create.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop/.. -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop/dataloop_create_contig.c -o _sdataloop_create_contig.o
mv -f _sdataloop_create_contig.o dataloop_create_contig.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop/.. -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop/dataloop_create_vector.c -o _sdataloop_create_vector.o
mv -f _sdataloop_create_vector.o dataloop_create_vector.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop/.. -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop/dataloop_create_blockindexed.c -o _sdataloop_create_blockindexed.o
mv -f _sdataloop_create_blockindexed.o dataloop_create_blockindexed.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop/.. -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop/dataloop_create_indexed.c -o _sdataloop_create_indexed.o
mv -f _sdataloop_create_indexed.o dataloop_create_indexed.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop/.. -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop/dataloop_create_struct.c -o _sdataloop_create_struct.o
mv -f _sdataloop_create_struct.o dataloop_create_struct.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop/.. -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop/dataloop_create_pairtype.c -o _sdataloop_create_pairtype.o
mv -f _sdataloop_create_pairtype.o dataloop_create_pairtype.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop/.. -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop/subarray_support.c -o _ssubarray_support.o
mv -f _ssubarray_support.o subarray_support.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop/.. -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop/darray_support.c -o _sdarray_support.o
mv -f _sdarray_support.o darray_support.lo
ar cr ../../../../../lib/libmpich.la dataloop.lo segment.lo segment_packunpack.lo segment_flatten.lo segment_count.lo dataloop_create.lo dataloop_create_contig.lo dataloop_create_vector.lo dataloop_create_blockindexed.lo dataloop_create_indexed.lo dataloop_create_struct.lo dataloop_create_pairtype.lo subarray_support.lo darray_support.lo
date > .libstamp1
make[6]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop'
make[5]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype/dataloop'
make all-local
make[5]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/mpid_type_debug.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/mpid_segment.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/mpid_ext32_segment.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/mpid_ext32_datatype.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/mpid_type_dup.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/mpir_type_get_contig_blocks.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/mpir_type_flatten.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/mpid_type_commit.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/mpid_type_zerolen.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/mpid_type_vector.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/mpid_type_contiguous.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/mpid_type_create_resized.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/mpid_type_blockindexed.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/mpid_type_indexed.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/mpid_type_struct.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/mpid_type_get_envelope.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/mpid_datatype_free.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/mpid_datatype_contents.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/mpid_type_get_contents.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/mpid_type_create_pairtype.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/mpid_contents_support.c
ar cr ../../../../lib/libmpich.a mpid_type_debug.o mpid_segment.o mpid_ext32_segment.o mpid_ext32_datatype.o mpid_type_dup.o mpir_type_get_contig_blocks.o mpir_type_flatten.o mpid_type_commit.o mpid_type_zerolen.o mpid_type_vector.o mpid_type_contiguous.o mpid_type_create_resized.o mpid_type_blockindexed.o mpid_type_indexed.o mpid_type_struct.o mpid_type_get_envelope.o mpid_datatype_free.o mpid_datatype_contents.o mpid_type_get_contents.o mpid_type_create_pairtype.o mpid_contents_support.o
ranlib ../../../../lib/libmpich.a
date > .libstamp0
make[6]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/mpid_type_debug.c -o _smpid_type_debug.o
mv -f _smpid_type_debug.o mpid_type_debug.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/mpid_segment.c -o _smpid_segment.o
mv -f _smpid_segment.o mpid_segment.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/mpid_ext32_segment.c -o _smpid_ext32_segment.o
mv -f _smpid_ext32_segment.o mpid_ext32_segment.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/mpid_ext32_datatype.c -o _smpid_ext32_datatype.o
mv -f _smpid_ext32_datatype.o mpid_ext32_datatype.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/mpid_type_dup.c -o _smpid_type_dup.o
mv -f _smpid_type_dup.o mpid_type_dup.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/mpir_type_get_contig_blocks.c -o _smpir_type_get_contig_blocks.o
mv -f _smpir_type_get_contig_blocks.o mpir_type_get_contig_blocks.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/mpir_type_flatten.c -o _smpir_type_flatten.o
mv -f _smpir_type_flatten.o mpir_type_flatten.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/mpid_type_commit.c -o _smpid_type_commit.o
mv -f _smpid_type_commit.o mpid_type_commit.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/mpid_type_zerolen.c -o _smpid_type_zerolen.o
mv -f _smpid_type_zerolen.o mpid_type_zerolen.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/mpid_type_vector.c -o _smpid_type_vector.o
mv -f _smpid_type_vector.o mpid_type_vector.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/mpid_type_contiguous.c -o _smpid_type_contiguous.o
mv -f _smpid_type_contiguous.o mpid_type_contiguous.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/mpid_type_create_resized.c -o _smpid_type_create_resized.o
mv -f _smpid_type_create_resized.o mpid_type_create_resized.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/mpid_type_blockindexed.c -o _smpid_type_blockindexed.o
mv -f _smpid_type_blockindexed.o mpid_type_blockindexed.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/mpid_type_indexed.c -o _smpid_type_indexed.o
mv -f _smpid_type_indexed.o mpid_type_indexed.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/mpid_type_struct.c -o _smpid_type_struct.o
mv -f _smpid_type_struct.o mpid_type_struct.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/mpid_type_get_envelope.c -o _smpid_type_get_envelope.o
mv -f _smpid_type_get_envelope.o mpid_type_get_envelope.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/mpid_datatype_free.c -o _smpid_datatype_free.o
mv -f _smpid_datatype_free.o mpid_datatype_free.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/mpid_datatype_contents.c -o _smpid_datatype_contents.o
mv -f _smpid_datatype_contents.o mpid_datatype_contents.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/mpid_type_get_contents.c -o _smpid_type_get_contents.o
mv -f _smpid_type_get_contents.o mpid_type_get_contents.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/mpid_type_create_pairtype.c -o _smpid_type_create_pairtype.o
mv -f _smpid_type_create_pairtype.o mpid_type_create_pairtype.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype/mpid_contents_support.c -o _smpid_contents_support.o
mv -f _smpid_contents_support.o mpid_contents_support.lo
ar cr ../../../../lib/libmpich.la mpid_type_debug.lo mpid_segment.lo mpid_ext32_segment.lo mpid_ext32_datatype.lo mpid_type_dup.lo mpir_type_get_contig_blocks.lo mpir_type_flatten.lo mpid_type_commit.lo mpid_type_zerolen.lo mpid_type_vector.lo mpid_type_contiguous.lo mpid_type_create_resized.lo mpid_type_blockindexed.lo mpid_type_indexed.lo mpid_type_struct.lo mpid_type_get_envelope.lo mpid_datatype_free.lo mpid_datatype_contents.lo mpid_type_get_contents.lo mpid_type_create_pairtype.lo mpid_contents_support.lo
date > .libstamp1
make[6]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype'
make[5]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype'
make[4]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype'
make[3]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common'
make[3]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3'
make[4]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels'
make[5]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis'
make[6]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis'
make[7]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src -I. -I../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_alloc.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src -I. -I../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_init.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src -I. -I../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_queue.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src -I. -I../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_barrier.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src -I. -I../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_mpich2.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src -I. -I../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_ckpt.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src -I. -I../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_finalize.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src -I. -I../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_network_poll.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src -I. -I../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_network.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src -I. -I../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_debug.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src -I. -I../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_lmt.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src -I. -I../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_lmt_shm.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src -I. -I../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c mpid_nem_net_array.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src -I. -I../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_lmt_dma.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src -I. -I../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_lmt_vmsplice.c
ar cr ../../../../../../../lib/libmpich.a mpid_nem_alloc.o mpid_nem_init.o mpid_nem_queue.o mpid_nem_barrier.o mpid_nem_mpich2.o mpid_nem_ckpt.o mpid_nem_finalize.o mpid_nem_network_poll.o mpid_nem_network.o mpid_nem_debug.o mpid_nem_lmt.o mpid_nem_lmt_shm.o mpid_nem_net_array.o mpid_nem_lmt_dma.o mpid_nem_lmt_vmsplice.o
ranlib ../../../../../../../lib/libmpich.a
date > .libstamp0
make[8]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src -I. -I../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_alloc.c -o _smpid_nem_alloc.o
mv -f _smpid_nem_alloc.o mpid_nem_alloc.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src -I. -I../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_init.c -o _smpid_nem_init.o
mv -f _smpid_nem_init.o mpid_nem_init.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src -I. -I../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_queue.c -o _smpid_nem_queue.o
mv -f _smpid_nem_queue.o mpid_nem_queue.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src -I. -I../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_barrier.c -o _smpid_nem_barrier.o
mv -f _smpid_nem_barrier.o mpid_nem_barrier.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src -I. -I../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_mpich2.c -o _smpid_nem_mpich2.o
mv -f _smpid_nem_mpich2.o mpid_nem_mpich2.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src -I. -I../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_ckpt.c -o _smpid_nem_ckpt.o
mv -f _smpid_nem_ckpt.o mpid_nem_ckpt.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src -I. -I../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_finalize.c -o _smpid_nem_finalize.o
mv -f _smpid_nem_finalize.o mpid_nem_finalize.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src -I. -I../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_network_poll.c -o _smpid_nem_network_poll.o
mv -f _smpid_nem_network_poll.o mpid_nem_network_poll.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src -I. -I../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_network.c -o _smpid_nem_network.o
mv -f _smpid_nem_network.o mpid_nem_network.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src -I. -I../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_debug.c -o _smpid_nem_debug.o
mv -f _smpid_nem_debug.o mpid_nem_debug.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src -I. -I../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_lmt.c -o _smpid_nem_lmt.o
mv -f _smpid_nem_lmt.o mpid_nem_lmt.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src -I. -I../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_lmt_shm.c -o _smpid_nem_lmt_shm.o
mv -f _smpid_nem_lmt_shm.o mpid_nem_lmt_shm.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src -I. -I../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c mpid_nem_net_array.c -o _smpid_nem_net_array.o
mv -f _smpid_nem_net_array.o mpid_nem_net_array.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src -I. -I../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_lmt_dma.c -o _smpid_nem_lmt_dma.o
mv -f _smpid_nem_lmt_dma.o mpid_nem_lmt_dma.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src -I. -I../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src/mpid_nem_lmt_vmsplice.c -o _smpid_nem_lmt_vmsplice.o
mv -f _smpid_nem_lmt_vmsplice.o mpid_nem_lmt_vmsplice.lo
ar cr ../../../../../../../lib/libmpich.la mpid_nem_alloc.lo mpid_nem_init.lo mpid_nem_queue.lo mpid_nem_barrier.lo mpid_nem_mpich2.lo mpid_nem_ckpt.lo mpid_nem_finalize.lo mpid_nem_network_poll.lo mpid_nem_network.lo mpid_nem_debug.lo mpid_nem_lmt.lo mpid_nem_lmt_shm.lo mpid_nem_net_array.lo mpid_nem_lmt_dma.lo mpid_nem_lmt_vmsplice.lo
date > .libstamp1
make[8]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src'
make[7]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/src'
make[7]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/netmod'
make[8]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp -I. -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp/tcp_finalize.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp -I. -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp/tcp_init.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp -I. -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp/tcp_send.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp -I. -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp/tcp_utility.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp -I. -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp/socksm.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp -I. -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp/tcp_getip.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp -I. -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp/tcp_ckpt.c
ar cr ../../../../../../../../lib/libmpich.a tcp_finalize.o tcp_init.o tcp_send.o tcp_utility.o socksm.o tcp_getip.o tcp_ckpt.o
ranlib ../../../../../../../../lib/libmpich.a
date > .libstamp0
make[9]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp -I. -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp/tcp_finalize.c -o _stcp_finalize.o
mv -f _stcp_finalize.o tcp_finalize.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp -I. -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp/tcp_init.c -o _stcp_init.o
mv -f _stcp_init.o tcp_init.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp -I. -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp/tcp_send.c -o _stcp_send.o
mv -f _stcp_send.o tcp_send.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp -I. -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp/tcp_utility.c -o _stcp_utility.o
mv -f _stcp_utility.o tcp_utility.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp -I. -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp/socksm.c -o _ssocksm.o
mv -f _ssocksm.o socksm.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp -I. -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp/tcp_getip.c -o _stcp_getip.o
mv -f _stcp_getip.o tcp_getip.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp -I. -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp/tcp_ckpt.c -o _stcp_ckpt.o
mv -f _stcp_ckpt.o tcp_ckpt.lo
ar cr ../../../../../../../../lib/libmpich.la tcp_finalize.lo tcp_init.lo tcp_send.lo tcp_utility.lo socksm.lo tcp_getip.lo tcp_ckpt.lo
date > .libstamp1
make[9]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp'
make[8]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/netmod/tcp'
make[7]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/netmod'
make[7]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils'
make[8]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I. -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor/papi_defs.c
ar cr ../../../../../../../../lib/libmpich.a papi_defs.o
date > .libstamp0
make[9]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I. -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor/papi_defs.c -o _spapi_defs.o
mv -f _spapi_defs.o papi_defs.lo
ar cr ../../../../../../../../lib/libmpich.la papi_defs.lo
date > .libstamp1
make[9]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor'
make[8]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor'
make[8]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/replacements'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/replacements -I. -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/replacements/mkstemp.c
ar cr ../../../../../../../../lib/libmpich.a mkstemp.o
date > .libstamp0
make[9]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/replacements'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/replacements -I. -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/replacements/mkstemp.c -o _smkstemp.o
mv -f _smkstemp.o mkstemp.lo
ar cr ../../../../../../../../lib/libmpich.la mkstemp.lo
date > .libstamp1
make[9]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/replacements'
make[8]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/replacements'
make[7]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils'
make[6]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis'
make[6]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/src'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/src -I../../../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/src/ch3_finalize.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/src -I../../../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/src/ch3_init.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/src -I../../../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/src/ch3_isend.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/src -I../../../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/src/ch3_isendv.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/src -I../../../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/src/ch3_istartmsg.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/src -I../../../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/src/ch3_istartmsgv.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/src -I../../../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/src/ch3_progress.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/src -I../../../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/src/ch3_abort.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/src -I../../../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/src/ch3i_comm.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/src -I../../../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/src/ch3i_eagernoncontig.c
ar cr ../../../../../../lib/libmpich.a ch3_finalize.o ch3_init.o ch3_isend.o ch3_isendv.o ch3_istartmsg.o ch3_istartmsgv.o ch3_progress.o ch3_abort.o ch3i_comm.o ch3i_eagernoncontig.o
ranlib ../../../../../../lib/libmpich.a
date > .libstamp0
make[7]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/src'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/src -I../../../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/src/ch3_finalize.c -o _sch3_finalize.o
mv -f _sch3_finalize.o ch3_finalize.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/src -I../../../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/src/ch3_init.c -o _sch3_init.o
mv -f _sch3_init.o ch3_init.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/src -I../../../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/src/ch3_isend.c -o _sch3_isend.o
mv -f _sch3_isend.o ch3_isend.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/src -I../../../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/src/ch3_isendv.c -o _sch3_isendv.o
mv -f _sch3_isendv.o ch3_isendv.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/src -I../../../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/src/ch3_istartmsg.c -o _sch3_istartmsg.o
mv -f _sch3_istartmsg.o ch3_istartmsg.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/src -I../../../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/src/ch3_istartmsgv.c -o _sch3_istartmsgv.o
mv -f _sch3_istartmsgv.o ch3_istartmsgv.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/src -I../../../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/src/ch3_progress.c -o _sch3_progress.o
mv -f _sch3_progress.o ch3_progress.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/src -I../../../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/src/ch3_abort.c -o _sch3_abort.o
mv -f _sch3_abort.o ch3_abort.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/src -I../../../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/src/ch3i_comm.c -o _sch3i_comm.o
mv -f _sch3i_comm.o ch3i_comm.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/src -I../../../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/src/ch3i_eagernoncontig.c -o _sch3i_eagernoncontig.o
mv -f _sch3i_eagernoncontig.o ch3i_eagernoncontig.lo
ar cr ../../../../../../lib/libmpich.la ch3_finalize.lo ch3_init.lo ch3_isend.lo ch3_isendv.lo ch3_istartmsg.lo ch3_istartmsgv.lo ch3_progress.lo ch3_abort.lo ch3i_comm.lo ch3i_eagernoncontig.lo
date > .libstamp1
make[7]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/src'
make[6]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/src'
make[5]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis'
make[4]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels'
make[4]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/src'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/ch3u_buffer.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/ch3u_comm_spawn_multiple.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/ch3u_handle_connection.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/ch3u_handle_recv_pkt.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/ch3u_handle_recv_req.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/ch3u_handle_send_req.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/ch3u_port.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/ch3u_recvq.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/ch3u_request.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/ch3u_rma_ops.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/ch3u_rma_sync.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/ch3u_rndv.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/ch3u_eager.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/ch3u_eagersync.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/mpid_abort.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/mpid_cancel_recv.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/mpid_cancel_send.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/mpid_comm_disconnect.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/mpid_comm_spawn_multiple.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/mpid_finalize.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/mpid_get_universe_size.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/mpid_getpname.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/mpid_init.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/mpid_iprobe.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/mpid_irecv.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/mpid_irsend.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/mpid_isend.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/mpid_issend.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/mpid_port.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/mpid_probe.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/mpid_recv.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/mpid_rsend.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/mpid_send.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/mpid_ssend.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/mpid_startall.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/mpid_vc.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/mpid_rma.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/mpidi_isend_self.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/mpidi_pg.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/mpidi_printf.c
ar cr ../../../../lib/libmpich.a ch3u_buffer.o ch3u_comm_spawn_multiple.o ch3u_handle_connection.o ch3u_handle_recv_pkt.o ch3u_handle_recv_req.o ch3u_handle_send_req.o ch3u_port.o ch3u_recvq.o ch3u_request.o ch3u_rma_ops.o ch3u_rma_sync.o ch3u_rndv.o ch3u_eager.o ch3u_eagersync.o mpid_abort.o mpid_cancel_recv.o mpid_cancel_send.o mpid_comm_disconnect.o mpid_comm_spawn_multiple.o mpid_finalize.o mpid_get_universe_size.o mpid_getpname.o mpid_init.o mpid_iprobe.o mpid_irecv.o mpid_irsend.o mpid_isend.o mpid_issend.o mpid_port.o mpid_probe.o mpid_recv.o mpid_rsend.o mpid_send.o mpid_ssend.o mpid_startall.o mpid_vc.o mpid_rma.o mpidi_isend_self.o mpidi_pg.o mpidi_printf.o
ranlib ../../../../lib/libmpich.a
date > .libstamp0
make[5]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/src'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/ch3u_buffer.c -o _sch3u_buffer.o
mv -f _sch3u_buffer.o ch3u_buffer.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/ch3u_comm_spawn_multiple.c -o _sch3u_comm_spawn_multiple.o
mv -f _sch3u_comm_spawn_multiple.o ch3u_comm_spawn_multiple.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/ch3u_handle_connection.c -o _sch3u_handle_connection.o
mv -f _sch3u_handle_connection.o ch3u_handle_connection.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/ch3u_handle_recv_pkt.c -o _sch3u_handle_recv_pkt.o
mv -f _sch3u_handle_recv_pkt.o ch3u_handle_recv_pkt.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/ch3u_handle_recv_req.c -o _sch3u_handle_recv_req.o
mv -f _sch3u_handle_recv_req.o ch3u_handle_recv_req.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/ch3u_handle_send_req.c -o _sch3u_handle_send_req.o
mv -f _sch3u_handle_send_req.o ch3u_handle_send_req.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/ch3u_port.c -o _sch3u_port.o
mv -f _sch3u_port.o ch3u_port.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/ch3u_recvq.c -o _sch3u_recvq.o
mv -f _sch3u_recvq.o ch3u_recvq.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/ch3u_request.c -o _sch3u_request.o
mv -f _sch3u_request.o ch3u_request.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/ch3u_rma_ops.c -o _sch3u_rma_ops.o
mv -f _sch3u_rma_ops.o ch3u_rma_ops.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/ch3u_rma_sync.c -o _sch3u_rma_sync.o
mv -f _sch3u_rma_sync.o ch3u_rma_sync.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/ch3u_rndv.c -o _sch3u_rndv.o
mv -f _sch3u_rndv.o ch3u_rndv.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/ch3u_eager.c -o _sch3u_eager.o
mv -f _sch3u_eager.o ch3u_eager.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/ch3u_eagersync.c -o _sch3u_eagersync.o
mv -f _sch3u_eagersync.o ch3u_eagersync.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/mpid_abort.c -o _smpid_abort.o
mv -f _smpid_abort.o mpid_abort.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/mpid_cancel_recv.c -o _smpid_cancel_recv.o
mv -f _smpid_cancel_recv.o mpid_cancel_recv.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/mpid_cancel_send.c -o _smpid_cancel_send.o
mv -f _smpid_cancel_send.o mpid_cancel_send.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/mpid_comm_disconnect.c -o _smpid_comm_disconnect.o
mv -f _smpid_comm_disconnect.o mpid_comm_disconnect.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/mpid_comm_spawn_multiple.c -o _smpid_comm_spawn_multiple.o
mv -f _smpid_comm_spawn_multiple.o mpid_comm_spawn_multiple.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/mpid_finalize.c -o _smpid_finalize.o
mv -f _smpid_finalize.o mpid_finalize.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/mpid_get_universe_size.c -o _smpid_get_universe_size.o
mv -f _smpid_get_universe_size.o mpid_get_universe_size.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/mpid_getpname.c -o _smpid_getpname.o
mv -f _smpid_getpname.o mpid_getpname.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/mpid_init.c -o _smpid_init.o
mv -f _smpid_init.o mpid_init.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/mpid_iprobe.c -o _smpid_iprobe.o
mv -f _smpid_iprobe.o mpid_iprobe.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/mpid_irecv.c -o _smpid_irecv.o
mv -f _smpid_irecv.o mpid_irecv.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/mpid_irsend.c -o _smpid_irsend.o
mv -f _smpid_irsend.o mpid_irsend.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/mpid_isend.c -o _smpid_isend.o
mv -f _smpid_isend.o mpid_isend.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/mpid_issend.c -o _smpid_issend.o
mv -f _smpid_issend.o mpid_issend.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/mpid_port.c -o _smpid_port.o
mv -f _smpid_port.o mpid_port.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/mpid_probe.c -o _smpid_probe.o
mv -f _smpid_probe.o mpid_probe.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/mpid_recv.c -o _smpid_recv.o
mv -f _smpid_recv.o mpid_recv.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/mpid_rsend.c -o _smpid_rsend.o
mv -f _smpid_rsend.o mpid_rsend.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/mpid_send.c -o _smpid_send.o
mv -f _smpid_send.o mpid_send.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/mpid_ssend.c -o _smpid_ssend.o
mv -f _smpid_ssend.o mpid_ssend.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/mpid_startall.c -o _smpid_startall.o
mv -f _smpid_startall.o mpid_startall.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/mpid_vc.c -o _smpid_vc.o
mv -f _smpid_vc.o mpid_vc.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/mpid_rma.c -o _smpid_rma.o
mv -f _smpid_rma.o mpid_rma.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/mpidi_isend_self.c -o _smpidi_isend_self.o
mv -f _smpidi_isend_self.o mpidi_isend_self.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/mpidi_pg.c -o _smpidi_pg.o
mv -f _smpidi_pg.o mpidi_pg.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src -I../../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/src/mpidi_printf.c -o _smpidi_printf.o
mv -f _smpidi_printf.o mpidi_printf.lo
ar cr ../../../../lib/libmpich.la ch3u_buffer.lo ch3u_comm_spawn_multiple.lo ch3u_handle_connection.lo ch3u_handle_recv_pkt.lo ch3u_handle_recv_req.lo ch3u_handle_send_req.lo ch3u_port.lo ch3u_recvq.lo ch3u_request.lo ch3u_rma_ops.lo ch3u_rma_sync.lo ch3u_rndv.lo ch3u_eager.lo ch3u_eagersync.lo mpid_abort.lo mpid_cancel_recv.lo mpid_cancel_send.lo mpid_comm_disconnect.lo mpid_comm_spawn_multiple.lo mpid_finalize.lo mpid_get_universe_size.lo mpid_getpname.lo mpid_init.lo mpid_iprobe.lo mpid_irecv.lo mpid_irsend.lo mpid_isend.lo mpid_issend.lo mpid_port.lo mpid_probe.lo mpid_recv.lo mpid_rsend.lo mpid_send.lo mpid_ssend.lo mpid_startall.lo mpid_vc.lo mpid_rma.lo mpidi_isend_self.lo mpidi_pg.lo mpidi_printf.lo
date > .libstamp1
make[5]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/src'
make[4]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/src'
make[4]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/util'
make[4]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/util'
make[3]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3'
make[2]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpid'
make[2]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi'
make[3]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/attr'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/attr_delete.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/attr_get.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/attr_put.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/comm_create_keyval.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/comm_delete_attr.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/comm_free_keyval.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/comm_get_attr.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/comm_set_attr.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/keyval_create.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/keyval_free.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/type_create_keyval.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/type_delete_attr.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/type_free_keyval.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/type_get_attr.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/type_set_attr.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/win_create_keyval.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/win_delete_attr.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/win_free_keyval.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/win_get_attr.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/win_set_attr.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/attrutil.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/dup_fn.c
ar cr ../../../lib/libmpich.a attr_delete.o attr_get.o attr_put.o comm_create_keyval.o comm_delete_attr.o comm_free_keyval.o comm_get_attr.o comm_set_attr.o keyval_create.o keyval_free.o type_create_keyval.o type_delete_attr.o type_free_keyval.o type_get_attr.o type_set_attr.o win_create_keyval.o win_delete_attr.o win_free_keyval.o win_get_attr.o win_set_attr.o attrutil.o dup_fn.o
ranlib ../../../lib/libmpich.a
date > .libstamp0
make[4]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/attr'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/attr_delete.c -o _attr_delete.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/attr_get.c -o _attr_get.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/attr_put.c -o _attr_put.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/comm_create_keyval.c -o _comm_create_keyval.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/comm_delete_attr.c -o _comm_delete_attr.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/comm_free_keyval.c -o _comm_free_keyval.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/comm_get_attr.c -o _comm_get_attr.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/comm_set_attr.c -o _comm_set_attr.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/keyval_create.c -o _keyval_create.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/keyval_free.c -o _keyval_free.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/type_create_keyval.c -o _type_create_keyval.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/type_delete_attr.c -o _type_delete_attr.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/type_free_keyval.c -o _type_free_keyval.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/type_get_attr.c -o _type_get_attr.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/type_set_attr.c -o _type_set_attr.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/win_create_keyval.c -o _win_create_keyval.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/win_delete_attr.c -o _win_delete_attr.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/win_free_keyval.c -o _win_free_keyval.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/win_get_attr.c -o _win_get_attr.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/win_set_attr.c -o _win_set_attr.o
ar cr ../../../lib/libmpich.a _attr_delete.o _attr_get.o _attr_put.o _comm_create_keyval.o _comm_delete_attr.o _comm_free_keyval.o _comm_get_attr.o _comm_set_attr.o _keyval_create.o _keyval_free.o _type_create_keyval.o _type_delete_attr.o _type_free_keyval.o _type_get_attr.o _type_set_attr.o _win_create_keyval.o _win_delete_attr.o _win_free_keyval.o _win_get_attr.o _win_set_attr.o
date > .libstamp2
make[4]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/attr'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/attr_delete.c -o _sattr_delete.o
mv -f _sattr_delete.o attr_delete.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/attr_get.c -o _sattr_get.o
mv -f _sattr_get.o attr_get.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/attr_put.c -o _sattr_put.o
mv -f _sattr_put.o attr_put.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/comm_create_keyval.c -o _scomm_create_keyval.o
mv -f _scomm_create_keyval.o comm_create_keyval.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/comm_delete_attr.c -o _scomm_delete_attr.o
mv -f _scomm_delete_attr.o comm_delete_attr.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/comm_free_keyval.c -o _scomm_free_keyval.o
mv -f _scomm_free_keyval.o comm_free_keyval.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/comm_get_attr.c -o _scomm_get_attr.o
mv -f _scomm_get_attr.o comm_get_attr.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/comm_set_attr.c -o _scomm_set_attr.o
mv -f _scomm_set_attr.o comm_set_attr.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/keyval_create.c -o _skeyval_create.o
mv -f _skeyval_create.o keyval_create.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/keyval_free.c -o _skeyval_free.o
mv -f _skeyval_free.o keyval_free.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/type_create_keyval.c -o _stype_create_keyval.o
mv -f _stype_create_keyval.o type_create_keyval.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/type_delete_attr.c -o _stype_delete_attr.o
mv -f _stype_delete_attr.o type_delete_attr.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/type_free_keyval.c -o _stype_free_keyval.o
mv -f _stype_free_keyval.o type_free_keyval.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/type_get_attr.c -o _stype_get_attr.o
mv -f _stype_get_attr.o type_get_attr.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/type_set_attr.c -o _stype_set_attr.o
mv -f _stype_set_attr.o type_set_attr.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/win_create_keyval.c -o _swin_create_keyval.o
mv -f _swin_create_keyval.o win_create_keyval.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/win_delete_attr.c -o _swin_delete_attr.o
mv -f _swin_delete_attr.o win_delete_attr.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/win_free_keyval.c -o _swin_free_keyval.o
mv -f _swin_free_keyval.o win_free_keyval.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/win_get_attr.c -o _swin_get_attr.o
mv -f _swin_get_attr.o win_get_attr.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/win_set_attr.c -o _swin_set_attr.o
mv -f _swin_set_attr.o win_set_attr.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/attrutil.c -o _sattrutil.o
mv -f _sattrutil.o attrutil.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/dup_fn.c -o _sdup_fn.o
mv -f _sdup_fn.o dup_fn.lo
ar cr ../../../lib/libmpich.la attr_delete.lo attr_get.lo attr_put.lo comm_create_keyval.lo comm_delete_attr.lo comm_free_keyval.lo comm_get_attr.lo comm_set_attr.lo keyval_create.lo keyval_free.lo type_create_keyval.lo type_delete_attr.lo type_free_keyval.lo type_get_attr.lo type_set_attr.lo win_create_keyval.lo win_delete_attr.lo win_free_keyval.lo win_get_attr.lo win_set_attr.lo attrutil.lo dup_fn.lo
date > .libstamp1
make[4]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/attr'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/attr_delete.c -o _attr_delete.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/attr_get.c -o _attr_get.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/attr_put.c -o _attr_put.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/comm_create_keyval.c -o _comm_create_keyval.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/comm_delete_attr.c -o _comm_delete_attr.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/comm_free_keyval.c -o _comm_free_keyval.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/comm_get_attr.c -o _comm_get_attr.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/comm_set_attr.c -o _comm_set_attr.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/keyval_create.c -o _keyval_create.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/keyval_free.c -o _keyval_free.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/type_create_keyval.c -o _type_create_keyval.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/type_delete_attr.c -o _type_delete_attr.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/type_free_keyval.c -o _type_free_keyval.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/type_get_attr.c -o _type_get_attr.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/type_set_attr.c -o _type_set_attr.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/win_create_keyval.c -o _win_create_keyval.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/win_delete_attr.c -o _win_delete_attr.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/win_free_keyval.c -o _win_free_keyval.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/win_get_attr.c -o _win_get_attr.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/attr/win_set_attr.c -o _win_set_attr.lo
ar cr ../../../lib/libmpich.la _attr_delete.lo _attr_get.lo _attr_put.lo _comm_create_keyval.lo _comm_delete_attr.lo _comm_free_keyval.lo _comm_get_attr.lo _comm_set_attr.lo _keyval_create.lo _keyval_free.lo _type_create_keyval.lo _type_delete_attr.lo _type_free_keyval.lo _type_get_attr.lo _type_set_attr.lo _win_create_keyval.lo _win_delete_attr.lo _win_free_keyval.lo _win_get_attr.lo _win_set_attr.lo
date > .libstamp3
make[4]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/attr'
make[3]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/attr'
make[3]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/coll'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/allreduce.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/barrier.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/op_create.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/op_free.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/bcast.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/alltoall.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/alltoallv.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/reduce.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/scatter.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/gather.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/scatterv.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/gatherv.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/scan.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/exscan.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/allgather.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/allgatherv.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/red_scat.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/alltoallw.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/reduce_local.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/op_commutative.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/red_scat_block.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/helper_fns.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/opsum.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/opmax.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/opmin.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/opband.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/opbor.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/opbxor.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/opland.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/oplor.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/oplxor.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/opprod.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/opminloc.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/opmaxloc.c
ar cr ../../../lib/libmpich.a allreduce.o barrier.o op_create.o op_free.o bcast.o alltoall.o alltoallv.o reduce.o scatter.o gather.o scatterv.o gatherv.o scan.o exscan.o allgather.o allgatherv.o red_scat.o alltoallw.o reduce_local.o op_commutative.o red_scat_block.o helper_fns.o opsum.o opmax.o opmin.o opband.o opbor.o opbxor.o opland.o oplor.o oplxor.o opprod.o opminloc.o opmaxloc.o
ranlib ../../../lib/libmpich.a
date > .libstamp0
make[4]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/coll'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/allreduce.c -o _allreduce.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/barrier.c -o _barrier.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/op_create.c -o _op_create.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/op_free.c -o _op_free.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/bcast.c -o _bcast.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/alltoall.c -o _alltoall.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/alltoallv.c -o _alltoallv.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/reduce.c -o _reduce.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/scatter.c -o _scatter.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/gather.c -o _gather.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/scatterv.c -o _scatterv.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/gatherv.c -o _gatherv.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/scan.c -o _scan.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/exscan.c -o _exscan.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/allgather.c -o _allgather.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/allgatherv.c -o _allgatherv.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/red_scat.c -o _red_scat.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/alltoallw.c -o _alltoallw.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/reduce_local.c -o _reduce_local.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/op_commutative.c -o _op_commutative.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/red_scat_block.c -o _red_scat_block.o
ar cr ../../../lib/libmpich.a _allreduce.o _barrier.o _op_create.o _op_free.o _bcast.o _alltoall.o _alltoallv.o _reduce.o _scatter.o _gather.o _scatterv.o _gatherv.o _scan.o _exscan.o _allgather.o _allgatherv.o _red_scat.o _alltoallw.o _reduce_local.o _op_commutative.o _red_scat_block.o
date > .libstamp2
make[4]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/coll'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/allreduce.c -o _sallreduce.o
mv -f _sallreduce.o allreduce.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/barrier.c -o _sbarrier.o
mv -f _sbarrier.o barrier.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/op_create.c -o _sop_create.o
mv -f _sop_create.o op_create.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/op_free.c -o _sop_free.o
mv -f _sop_free.o op_free.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/bcast.c -o _sbcast.o
mv -f _sbcast.o bcast.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/alltoall.c -o _salltoall.o
mv -f _salltoall.o alltoall.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/alltoallv.c -o _salltoallv.o
mv -f _salltoallv.o alltoallv.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/reduce.c -o _sreduce.o
mv -f _sreduce.o reduce.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/scatter.c -o _sscatter.o
mv -f _sscatter.o scatter.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/gather.c -o _sgather.o
mv -f _sgather.o gather.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/scatterv.c -o _sscatterv.o
mv -f _sscatterv.o scatterv.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/gatherv.c -o _sgatherv.o
mv -f _sgatherv.o gatherv.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/scan.c -o _sscan.o
mv -f _sscan.o scan.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/exscan.c -o _sexscan.o
mv -f _sexscan.o exscan.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/allgather.c -o _sallgather.o
mv -f _sallgather.o allgather.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/allgatherv.c -o _sallgatherv.o
mv -f _sallgatherv.o allgatherv.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/red_scat.c -o _sred_scat.o
mv -f _sred_scat.o red_scat.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/alltoallw.c -o _salltoallw.o
mv -f _salltoallw.o alltoallw.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/reduce_local.c -o _sreduce_local.o
mv -f _sreduce_local.o reduce_local.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/op_commutative.c -o _sop_commutative.o
mv -f _sop_commutative.o op_commutative.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/red_scat_block.c -o _sred_scat_block.o
mv -f _sred_scat_block.o red_scat_block.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/helper_fns.c -o _shelper_fns.o
mv -f _shelper_fns.o helper_fns.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/opsum.c -o _sopsum.o
mv -f _sopsum.o opsum.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/opmax.c -o _sopmax.o
mv -f _sopmax.o opmax.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/opmin.c -o _sopmin.o
mv -f _sopmin.o opmin.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/opband.c -o _sopband.o
mv -f _sopband.o opband.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/opbor.c -o _sopbor.o
mv -f _sopbor.o opbor.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/opbxor.c -o _sopbxor.o
mv -f _sopbxor.o opbxor.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/opland.c -o _sopland.o
mv -f _sopland.o opland.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/oplor.c -o _soplor.o
mv -f _soplor.o oplor.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/oplxor.c -o _soplxor.o
mv -f _soplxor.o oplxor.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/opprod.c -o _sopprod.o
mv -f _sopprod.o opprod.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/opminloc.c -o _sopminloc.o
mv -f _sopminloc.o opminloc.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/opmaxloc.c -o _sopmaxloc.o
mv -f _sopmaxloc.o opmaxloc.lo
ar cr ../../../lib/libmpich.la allreduce.lo barrier.lo op_create.lo op_free.lo bcast.lo alltoall.lo alltoallv.lo reduce.lo scatter.lo gather.lo scatterv.lo gatherv.lo scan.lo exscan.lo allgather.lo allgatherv.lo red_scat.lo alltoallw.lo reduce_local.lo op_commutative.lo red_scat_block.lo helper_fns.lo opsum.lo opmax.lo opmin.lo opband.lo opbor.lo opbxor.lo opland.lo oplor.lo oplxor.lo opprod.lo opminloc.lo opmaxloc.lo
date > .libstamp1
make[4]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/coll'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/allreduce.c -o _allreduce.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/barrier.c -o _barrier.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/op_create.c -o _op_create.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/op_free.c -o _op_free.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/bcast.c -o _bcast.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/alltoall.c -o _alltoall.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/alltoallv.c -o _alltoallv.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/reduce.c -o _reduce.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/scatter.c -o _scatter.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/gather.c -o _gather.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/scatterv.c -o _scatterv.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/gatherv.c -o _gatherv.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/scan.c -o _scan.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/exscan.c -o _exscan.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/allgather.c -o _allgather.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/allgatherv.c -o _allgatherv.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/red_scat.c -o _red_scat.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/alltoallw.c -o _alltoallw.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/reduce_local.c -o _reduce_local.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/op_commutative.c -o _op_commutative.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/coll/red_scat_block.c -o _red_scat_block.lo
ar cr ../../../lib/libmpich.la _allreduce.lo _barrier.lo _op_create.lo _op_free.lo _bcast.lo _alltoall.lo _alltoallv.lo _reduce.lo _scatter.lo _gather.lo _scatterv.lo _gatherv.lo _scan.lo _exscan.lo _allgather.lo _allgatherv.lo _red_scat.lo _alltoallw.lo _reduce_local.lo _op_commutative.lo _red_scat_block.lo
date > .libstamp3
make[4]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/coll'
make[3]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/coll'
make[3]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/comm'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/comm_compare.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/comm_create.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/comm_dup.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/comm_free.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/comm_get_name.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/comm_group.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/comm_rank.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/comm_size.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/comm_remote_group.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/comm_remote_size.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/comm_set_name.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/comm_split.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/comm_test_inter.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/intercomm_create.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/intercomm_merge.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/commutil.c
ar cr ../../../lib/libmpich.a comm_compare.o comm_create.o comm_dup.o comm_free.o comm_get_name.o comm_group.o comm_rank.o comm_size.o comm_remote_group.o comm_remote_size.o comm_set_name.o comm_split.o comm_test_inter.o intercomm_create.o intercomm_merge.o commutil.o
ranlib ../../../lib/libmpich.a
date > .libstamp0
make[4]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/comm'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/comm_compare.c -o _comm_compare.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/comm_create.c -o _comm_create.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/comm_dup.c -o _comm_dup.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/comm_free.c -o _comm_free.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/comm_get_name.c -o _comm_get_name.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/comm_group.c -o _comm_group.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/comm_rank.c -o _comm_rank.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/comm_size.c -o _comm_size.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/comm_remote_group.c -o _comm_remote_group.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/comm_remote_size.c -o _comm_remote_size.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/comm_set_name.c -o _comm_set_name.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/comm_split.c -o _comm_split.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/comm_test_inter.c -o _comm_test_inter.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/intercomm_create.c -o _intercomm_create.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/intercomm_merge.c -o _intercomm_merge.o
ar cr ../../../lib/libmpich.a _comm_compare.o _comm_create.o _comm_dup.o _comm_free.o _comm_get_name.o _comm_group.o _comm_rank.o _comm_size.o _comm_remote_group.o _comm_remote_size.o _comm_set_name.o _comm_split.o _comm_test_inter.o _intercomm_create.o _intercomm_merge.o
date > .libstamp2
make[4]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/comm'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/comm_compare.c -o _scomm_compare.o
mv -f _scomm_compare.o comm_compare.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/comm_create.c -o _scomm_create.o
mv -f _scomm_create.o comm_create.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/comm_dup.c -o _scomm_dup.o
mv -f _scomm_dup.o comm_dup.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/comm_free.c -o _scomm_free.o
mv -f _scomm_free.o comm_free.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/comm_get_name.c -o _scomm_get_name.o
mv -f _scomm_get_name.o comm_get_name.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/comm_group.c -o _scomm_group.o
mv -f _scomm_group.o comm_group.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/comm_rank.c -o _scomm_rank.o
mv -f _scomm_rank.o comm_rank.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/comm_size.c -o _scomm_size.o
mv -f _scomm_size.o comm_size.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/comm_remote_group.c -o _scomm_remote_group.o
mv -f _scomm_remote_group.o comm_remote_group.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/comm_remote_size.c -o _scomm_remote_size.o
mv -f _scomm_remote_size.o comm_remote_size.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/comm_set_name.c -o _scomm_set_name.o
mv -f _scomm_set_name.o comm_set_name.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/comm_split.c -o _scomm_split.o
mv -f _scomm_split.o comm_split.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/comm_test_inter.c -o _scomm_test_inter.o
mv -f _scomm_test_inter.o comm_test_inter.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/intercomm_create.c -o _sintercomm_create.o
mv -f _sintercomm_create.o intercomm_create.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/intercomm_merge.c -o _sintercomm_merge.o
mv -f _sintercomm_merge.o intercomm_merge.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/commutil.c -o _scommutil.o
mv -f _scommutil.o commutil.lo
ar cr ../../../lib/libmpich.la comm_compare.lo comm_create.lo comm_dup.lo comm_free.lo comm_get_name.lo comm_group.lo comm_rank.lo comm_size.lo comm_remote_group.lo comm_remote_size.lo comm_set_name.lo comm_split.lo comm_test_inter.lo intercomm_create.lo intercomm_merge.lo commutil.lo
date > .libstamp1
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/comm_compare.c -o _comm_compare.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/comm_create.c -o _comm_create.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/comm_dup.c -o _comm_dup.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/comm_free.c -o _comm_free.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/comm_get_name.c -o _comm_get_name.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/comm_group.c -o _comm_group.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/comm_rank.c -o _comm_rank.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/comm_size.c -o _comm_size.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/comm_remote_group.c -o _comm_remote_group.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/comm_remote_size.c -o _comm_remote_size.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/comm_set_name.c -o _comm_set_name.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/comm_split.c -o _comm_split.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/comm_test_inter.c -o _comm_test_inter.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/intercomm_create.c -o _intercomm_create.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/comm/intercomm_merge.c -o _intercomm_merge.lo
ar cr ../../../lib/libmpich.la _comm_compare.lo _comm_create.lo _comm_dup.lo _comm_free.lo _comm_get_name.lo _comm_group.lo _comm_rank.lo _comm_size.lo _comm_remote_group.lo _comm_remote_size.lo _comm_set_name.lo _comm_split.lo _comm_test_inter.lo _intercomm_create.lo _intercomm_merge.lo
date > .libstamp3
make[3]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/comm'
make[3]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/datatype'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/address.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/get_address.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/get_count.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/get_elements.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/pack.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/unpack.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/pack_size.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/status_set_elements.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_get_name.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_set_name.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_size.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_extent.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_vector.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_commit.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_indexed.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_hindexed.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_struct.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_contiguous.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_free.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_hvector.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_dup.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_get_envelope.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_get_contents.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_ub.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_lb.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_get_extent.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_get_true_extent.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_match_size.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_create_struct.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_create_hindexed.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_create_hvector.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/pack_external.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/pack_external_size.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/unpack_external.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_create_indexed_block.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_create_resized.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_create_darray.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_create_subarray.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/typeutil.c
ar cr ../../../lib/libmpich.a address.o get_address.o get_count.o get_elements.o pack.o unpack.o pack_size.o status_set_elements.o type_get_name.o type_set_name.o type_size.o type_extent.o type_vector.o type_commit.o type_indexed.o type_hindexed.o type_struct.o type_contiguous.o type_free.o type_hvector.o type_dup.o type_get_envelope.o type_get_contents.o type_ub.o type_lb.o type_get_extent.o type_get_true_extent.o type_match_size.o type_create_struct.o type_create_hindexed.o type_create_hvector.o pack_external.o pack_external_size.o unpack_external.o type_create_indexed_block.o type_create_resized.o type_create_darray.o type_create_subarray.o typeutil.o
ranlib ../../../lib/libmpich.a
date > .libstamp0
make[4]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/datatype'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/address.c -o _address.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/get_address.c -o _get_address.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/get_count.c -o _get_count.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/get_elements.c -o _get_elements.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/pack.c -o _pack.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/unpack.c -o _unpack.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/pack_size.c -o _pack_size.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/status_set_elements.c -o _status_set_elements.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_get_name.c -o _type_get_name.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_set_name.c -o _type_set_name.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_size.c -o _type_size.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_extent.c -o _type_extent.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_vector.c -o _type_vector.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_commit.c -o _type_commit.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_indexed.c -o _type_indexed.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_hindexed.c -o _type_hindexed.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_struct.c -o _type_struct.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_contiguous.c -o _type_contiguous.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_free.c -o _type_free.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_hvector.c -o _type_hvector.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_dup.c -o _type_dup.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_get_envelope.c -o _type_get_envelope.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_get_contents.c -o _type_get_contents.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_ub.c -o _type_ub.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_lb.c -o _type_lb.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_get_extent.c -o _type_get_extent.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_get_true_extent.c -o _type_get_true_extent.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_match_size.c -o _type_match_size.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_create_struct.c -o _type_create_struct.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_create_hindexed.c -o _type_create_hindexed.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_create_hvector.c -o _type_create_hvector.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/pack_external.c -o _pack_external.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/pack_external_size.c -o _pack_external_size.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/unpack_external.c -o _unpack_external.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_create_indexed_block.c -o _type_create_indexed_block.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_create_resized.c -o _type_create_resized.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_create_darray.c -o _type_create_darray.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_create_subarray.c -o _type_create_subarray.o
ar cr ../../../lib/libmpich.a _address.o _get_address.o _get_count.o _get_elements.o _pack.o _unpack.o _pack_size.o _status_set_elements.o _type_get_name.o _type_set_name.o _type_size.o _type_extent.o _type_vector.o _type_commit.o _type_indexed.o _type_hindexed.o _type_struct.o _type_contiguous.o _type_free.o _type_hvector.o _type_dup.o _type_get_envelope.o _type_get_contents.o _type_ub.o _type_lb.o _type_get_extent.o _type_get_true_extent.o _type_match_size.o _type_create_struct.o _type_create_hindexed.o _type_create_hvector.o _pack_external.o _pack_external_size.o _unpack_external.o _type_create_indexed_block.o _type_create_resized.o _type_create_darray.o _type_create_subarray.o
date > .libstamp2
make[4]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/datatype'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/address.c -o _saddress.o
mv -f _saddress.o address.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/get_address.c -o _sget_address.o
mv -f _sget_address.o get_address.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/get_count.c -o _sget_count.o
mv -f _sget_count.o get_count.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/get_elements.c -o _sget_elements.o
mv -f _sget_elements.o get_elements.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/pack.c -o _spack.o
mv -f _spack.o pack.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/unpack.c -o _sunpack.o
mv -f _sunpack.o unpack.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/pack_size.c -o _spack_size.o
mv -f _spack_size.o pack_size.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/status_set_elements.c -o _sstatus_set_elements.o
mv -f _sstatus_set_elements.o status_set_elements.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_get_name.c -o _stype_get_name.o
mv -f _stype_get_name.o type_get_name.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_set_name.c -o _stype_set_name.o
mv -f _stype_set_name.o type_set_name.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_size.c -o _stype_size.o
mv -f _stype_size.o type_size.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_extent.c -o _stype_extent.o
mv -f _stype_extent.o type_extent.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_vector.c -o _stype_vector.o
mv -f _stype_vector.o type_vector.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_commit.c -o _stype_commit.o
mv -f _stype_commit.o type_commit.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_indexed.c -o _stype_indexed.o
mv -f _stype_indexed.o type_indexed.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_hindexed.c -o _stype_hindexed.o
mv -f _stype_hindexed.o type_hindexed.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_struct.c -o _stype_struct.o
mv -f _stype_struct.o type_struct.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_contiguous.c -o _stype_contiguous.o
mv -f _stype_contiguous.o type_contiguous.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_free.c -o _stype_free.o
mv -f _stype_free.o type_free.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_hvector.c -o _stype_hvector.o
mv -f _stype_hvector.o type_hvector.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_dup.c -o _stype_dup.o
mv -f _stype_dup.o type_dup.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_get_envelope.c -o _stype_get_envelope.o
mv -f _stype_get_envelope.o type_get_envelope.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_get_contents.c -o _stype_get_contents.o
mv -f _stype_get_contents.o type_get_contents.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_ub.c -o _stype_ub.o
mv -f _stype_ub.o type_ub.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_lb.c -o _stype_lb.o
mv -f _stype_lb.o type_lb.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_get_extent.c -o _stype_get_extent.o
mv -f _stype_get_extent.o type_get_extent.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_get_true_extent.c -o _stype_get_true_extent.o
mv -f _stype_get_true_extent.o type_get_true_extent.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_match_size.c -o _stype_match_size.o
mv -f _stype_match_size.o type_match_size.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_create_struct.c -o _stype_create_struct.o
mv -f _stype_create_struct.o type_create_struct.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_create_hindexed.c -o _stype_create_hindexed.o
mv -f _stype_create_hindexed.o type_create_hindexed.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_create_hvector.c -o _stype_create_hvector.o
mv -f _stype_create_hvector.o type_create_hvector.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/pack_external.c -o _spack_external.o
mv -f _spack_external.o pack_external.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/pack_external_size.c -o _spack_external_size.o
mv -f _spack_external_size.o pack_external_size.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/unpack_external.c -o _sunpack_external.o
mv -f _sunpack_external.o unpack_external.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_create_indexed_block.c -o _stype_create_indexed_block.o
mv -f _stype_create_indexed_block.o type_create_indexed_block.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_create_resized.c -o _stype_create_resized.o
mv -f _stype_create_resized.o type_create_resized.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_create_darray.c -o _stype_create_darray.o
mv -f _stype_create_darray.o type_create_darray.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_create_subarray.c -o _stype_create_subarray.o
mv -f _stype_create_subarray.o type_create_subarray.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/typeutil.c -o _stypeutil.o
mv -f _stypeutil.o typeutil.lo
ar cr ../../../lib/libmpich.la address.lo get_address.lo get_count.lo get_elements.lo pack.lo unpack.lo pack_size.lo status_set_elements.lo type_get_name.lo type_set_name.lo type_size.lo type_extent.lo type_vector.lo type_commit.lo type_indexed.lo type_hindexed.lo type_struct.lo type_contiguous.lo type_free.lo type_hvector.lo type_dup.lo type_get_envelope.lo type_get_contents.lo type_ub.lo type_lb.lo type_get_extent.lo type_get_true_extent.lo type_match_size.lo type_create_struct.lo type_create_hindexed.lo type_create_hvector.lo pack_external.lo pack_external_size.lo unpack_external.lo type_create_indexed_block.lo type_create_resized.lo type_create_darray.lo type_create_subarray.lo typeutil.lo
date > .libstamp1
make[4]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/datatype'
make[4]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/datatype'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/address.c -o _address.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/get_address.c -o _get_address.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/get_count.c -o _get_count.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/get_elements.c -o _get_elements.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/pack.c -o _pack.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/unpack.c -o _unpack.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/pack_size.c -o _pack_size.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/status_set_elements.c -o _status_set_elements.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_get_name.c -o _type_get_name.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_set_name.c -o _type_set_name.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_size.c -o _type_size.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_extent.c -o _type_extent.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_vector.c -o _type_vector.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_commit.c -o _type_commit.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_indexed.c -o _type_indexed.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_hindexed.c -o _type_hindexed.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_struct.c -o _type_struct.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_contiguous.c -o _type_contiguous.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_free.c -o _type_free.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_hvector.c -o _type_hvector.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_dup.c -o _type_dup.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_get_envelope.c -o _type_get_envelope.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_get_contents.c -o _type_get_contents.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_ub.c -o _type_ub.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_lb.c -o _type_lb.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_get_extent.c -o _type_get_extent.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_get_true_extent.c -o _type_get_true_extent.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_match_size.c -o _type_match_size.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_create_struct.c -o _type_create_struct.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_create_hindexed.c -o _type_create_hindexed.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_create_hvector.c -o _type_create_hvector.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/pack_external.c -o _pack_external.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/pack_external_size.c -o _pack_external_size.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/unpack_external.c -o _unpack_external.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_create_indexed_block.c -o _type_create_indexed_block.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_create_resized.c -o _type_create_resized.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_create_darray.c -o _type_create_darray.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype/type_create_subarray.c -o _type_create_subarray.lo
ar cr ../../../lib/libmpich.la _address.lo _get_address.lo _get_count.lo _get_elements.lo _pack.lo _unpack.lo _pack_size.lo _status_set_elements.lo _type_get_name.lo _type_set_name.lo _type_size.lo _type_extent.lo _type_vector.lo _type_commit.lo _type_indexed.lo _type_hindexed.lo _type_struct.lo _type_contiguous.lo _type_free.lo _type_hvector.lo _type_dup.lo _type_get_envelope.lo _type_get_contents.lo _type_ub.lo _type_lb.lo _type_get_extent.lo _type_get_true_extent.lo _type_match_size.lo _type_create_struct.lo _type_create_hindexed.lo _type_create_hvector.lo _pack_external.lo _pack_external_size.lo _unpack_external.lo _type_create_indexed_block.lo _type_create_resized.lo _type_create_darray.lo _type_create_subarray.lo
date > .libstamp3
make[3]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/datatype'
make[3]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/errhan'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/add_error_code.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/add_error_class.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/add_error_string.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/comm_call_errhandler.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/comm_create_errhandler.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/comm_get_errhandler.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/comm_set_errhandler.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/errhandler_create.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/errhandler_free.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/errhandler_get.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/errhandler_set.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/error_class.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/error_string.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/file_create_errhandler.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/file_get_errhandler.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/file_set_errhandler.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/file_call_errhandler.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/win_create_errhandler.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/win_call_errhandler.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/win_get_errhandler.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/win_set_errhandler.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/errutil.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/dynerrutil.c
ar cr ../../../lib/libmpich.a add_error_code.o add_error_class.o add_error_string.o comm_call_errhandler.o comm_create_errhandler.o comm_get_errhandler.o comm_set_errhandler.o errhandler_create.o errhandler_free.o errhandler_get.o errhandler_set.o error_class.o error_string.o file_create_errhandler.o file_get_errhandler.o file_set_errhandler.o file_call_errhandler.o win_create_errhandler.o win_call_errhandler.o win_get_errhandler.o win_set_errhandler.o errutil.o dynerrutil.o
ranlib ../../../lib/libmpich.a
date > .libstamp0
make[4]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/errhan'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/add_error_code.c -o _add_error_code.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/add_error_class.c -o _add_error_class.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/add_error_string.c -o _add_error_string.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/comm_call_errhandler.c -o _comm_call_errhandler.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/comm_create_errhandler.c -o _comm_create_errhandler.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/comm_get_errhandler.c -o _comm_get_errhandler.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/comm_set_errhandler.c -o _comm_set_errhandler.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/errhandler_create.c -o _errhandler_create.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/errhandler_free.c -o _errhandler_free.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/errhandler_get.c -o _errhandler_get.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/errhandler_set.c -o _errhandler_set.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/error_class.c -o _error_class.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/error_string.c -o _error_string.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/file_create_errhandler.c -o _file_create_errhandler.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/file_get_errhandler.c -o _file_get_errhandler.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/file_set_errhandler.c -o _file_set_errhandler.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/file_call_errhandler.c -o _file_call_errhandler.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/win_create_errhandler.c -o _win_create_errhandler.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/win_call_errhandler.c -o _win_call_errhandler.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/win_get_errhandler.c -o _win_get_errhandler.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/win_set_errhandler.c -o _win_set_errhandler.o
ar cr ../../../lib/libmpich.a _add_error_code.o _add_error_class.o _add_error_string.o _comm_call_errhandler.o _comm_create_errhandler.o _comm_get_errhandler.o _comm_set_errhandler.o _errhandler_create.o _errhandler_free.o _errhandler_get.o _errhandler_set.o _error_class.o _error_string.o _file_create_errhandler.o _file_get_errhandler.o _file_set_errhandler.o _file_call_errhandler.o _win_create_errhandler.o _win_call_errhandler.o _win_get_errhandler.o _win_set_errhandler.o
date > .libstamp2
make[4]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/errhan'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/add_error_code.c -o _sadd_error_code.o
mv -f _sadd_error_code.o add_error_code.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/add_error_class.c -o _sadd_error_class.o
mv -f _sadd_error_class.o add_error_class.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/add_error_string.c -o _sadd_error_string.o
mv -f _sadd_error_string.o add_error_string.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/comm_call_errhandler.c -o _scomm_call_errhandler.o
mv -f _scomm_call_errhandler.o comm_call_errhandler.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/comm_create_errhandler.c -o _scomm_create_errhandler.o
mv -f _scomm_create_errhandler.o comm_create_errhandler.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/comm_get_errhandler.c -o _scomm_get_errhandler.o
mv -f _scomm_get_errhandler.o comm_get_errhandler.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/comm_set_errhandler.c -o _scomm_set_errhandler.o
mv -f _scomm_set_errhandler.o comm_set_errhandler.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/errhandler_create.c -o _serrhandler_create.o
mv -f _serrhandler_create.o errhandler_create.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/errhandler_free.c -o _serrhandler_free.o
mv -f _serrhandler_free.o errhandler_free.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/errhandler_get.c -o _serrhandler_get.o
mv -f _serrhandler_get.o errhandler_get.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/errhandler_set.c -o _serrhandler_set.o
mv -f _serrhandler_set.o errhandler_set.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/error_class.c -o _serror_class.o
mv -f _serror_class.o error_class.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/error_string.c -o _serror_string.o
mv -f _serror_string.o error_string.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/file_create_errhandler.c -o _sfile_create_errhandler.o
mv -f _sfile_create_errhandler.o file_create_errhandler.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/file_get_errhandler.c -o _sfile_get_errhandler.o
mv -f _sfile_get_errhandler.o file_get_errhandler.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/file_set_errhandler.c -o _sfile_set_errhandler.o
mv -f _sfile_set_errhandler.o file_set_errhandler.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/file_call_errhandler.c -o _sfile_call_errhandler.o
mv -f _sfile_call_errhandler.o file_call_errhandler.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/win_create_errhandler.c -o _swin_create_errhandler.o
mv -f _swin_create_errhandler.o win_create_errhandler.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/win_call_errhandler.c -o _swin_call_errhandler.o
mv -f _swin_call_errhandler.o win_call_errhandler.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/win_get_errhandler.c -o _swin_get_errhandler.o
mv -f _swin_get_errhandler.o win_get_errhandler.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/win_set_errhandler.c -o _swin_set_errhandler.o
mv -f _swin_set_errhandler.o win_set_errhandler.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/errutil.c -o _serrutil.o
mv -f _serrutil.o errutil.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/dynerrutil.c -o _sdynerrutil.o
mv -f _sdynerrutil.o dynerrutil.lo
ar cr ../../../lib/libmpich.la add_error_code.lo add_error_class.lo add_error_string.lo comm_call_errhandler.lo comm_create_errhandler.lo comm_get_errhandler.lo comm_set_errhandler.lo errhandler_create.lo errhandler_free.lo errhandler_get.lo errhandler_set.lo error_class.lo error_string.lo file_create_errhandler.lo file_get_errhandler.lo file_set_errhandler.lo file_call_errhandler.lo win_create_errhandler.lo win_call_errhandler.lo win_get_errhandler.lo win_set_errhandler.lo errutil.lo dynerrutil.lo
date > .libstamp1
make[4]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/errhan'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/add_error_code.c -o _add_error_code.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/add_error_class.c -o _add_error_class.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/add_error_string.c -o _add_error_string.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/comm_call_errhandler.c -o _comm_call_errhandler.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/comm_create_errhandler.c -o _comm_create_errhandler.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/comm_get_errhandler.c -o _comm_get_errhandler.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/comm_set_errhandler.c -o _comm_set_errhandler.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/errhandler_create.c -o _errhandler_create.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/errhandler_free.c -o _errhandler_free.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/errhandler_get.c -o _errhandler_get.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/errhandler_set.c -o _errhandler_set.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/error_class.c -o _error_class.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/error_string.c -o _error_string.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/file_create_errhandler.c -o _file_create_errhandler.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/file_get_errhandler.c -o _file_get_errhandler.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/file_set_errhandler.c -o _file_set_errhandler.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/file_call_errhandler.c -o _file_call_errhandler.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/win_create_errhandler.c -o _win_create_errhandler.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/win_call_errhandler.c -o _win_call_errhandler.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/win_get_errhandler.c -o _win_get_errhandler.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/errhan/win_set_errhandler.c -o _win_set_errhandler.lo
ar cr ../../../lib/libmpich.la _add_error_code.lo _add_error_class.lo _add_error_string.lo _comm_call_errhandler.lo _comm_create_errhandler.lo _comm_get_errhandler.lo _comm_set_errhandler.lo _errhandler_create.lo _errhandler_free.lo _errhandler_get.lo _errhandler_set.lo _error_class.lo _error_string.lo _file_create_errhandler.lo _file_get_errhandler.lo _file_set_errhandler.lo _file_call_errhandler.lo _win_create_errhandler.lo _win_call_errhandler.lo _win_get_errhandler.lo _win_set_errhandler.lo
date > .libstamp3
make[4]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/errhan'
make[3]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/errhan'
make[3]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/group'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group/group_compare.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group/group_difference.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group/group_excl.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group/group_free.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group/group_incl.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group/group_intersection.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group/group_range_excl.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group/group_range_incl.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group/group_rank.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group/group_size.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group/group_translate_ranks.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group/group_union.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group/grouputil.c
ar cr ../../../lib/libmpich.a group_compare.o group_difference.o group_excl.o group_free.o group_incl.o group_intersection.o group_range_excl.o group_range_incl.o group_rank.o group_size.o group_translate_ranks.o group_union.o grouputil.o
ranlib ../../../lib/libmpich.a
date > .libstamp0
make[4]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/group'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group/group_compare.c -o _group_compare.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group/group_difference.c -o _group_difference.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group/group_excl.c -o _group_excl.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group/group_free.c -o _group_free.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group/group_incl.c -o _group_incl.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group/group_intersection.c -o _group_intersection.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group/group_range_excl.c -o _group_range_excl.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group/group_range_incl.c -o _group_range_incl.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group/group_rank.c -o _group_rank.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group/group_size.c -o _group_size.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group/group_translate_ranks.c -o _group_translate_ranks.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group/group_union.c -o _group_union.o
ar cr ../../../lib/libmpich.a _group_compare.o _group_difference.o _group_excl.o _group_free.o _group_incl.o _group_intersection.o _group_range_excl.o _group_range_incl.o _group_rank.o _group_size.o _group_translate_ranks.o _group_union.o
date > .libstamp2
make[4]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/group'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group/group_compare.c -o _sgroup_compare.o
mv -f _sgroup_compare.o group_compare.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group/group_difference.c -o _sgroup_difference.o
mv -f _sgroup_difference.o group_difference.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group/group_excl.c -o _sgroup_excl.o
mv -f _sgroup_excl.o group_excl.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group/group_free.c -o _sgroup_free.o
mv -f _sgroup_free.o group_free.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group/group_incl.c -o _sgroup_incl.o
mv -f _sgroup_incl.o group_incl.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group/group_intersection.c -o _sgroup_intersection.o
mv -f _sgroup_intersection.o group_intersection.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group/group_range_excl.c -o _sgroup_range_excl.o
mv -f _sgroup_range_excl.o group_range_excl.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group/group_range_incl.c -o _sgroup_range_incl.o
mv -f _sgroup_range_incl.o group_range_incl.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group/group_rank.c -o _sgroup_rank.o
mv -f _sgroup_rank.o group_rank.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group/group_size.c -o _sgroup_size.o
mv -f _sgroup_size.o group_size.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group/group_translate_ranks.c -o _sgroup_translate_ranks.o
mv -f _sgroup_translate_ranks.o group_translate_ranks.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group/group_union.c -o _sgroup_union.o
mv -f _sgroup_union.o group_union.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group/grouputil.c -o _sgrouputil.o
mv -f _sgrouputil.o grouputil.lo
ar cr ../../../lib/libmpich.la group_compare.lo group_difference.lo group_excl.lo group_free.lo group_incl.lo group_intersection.lo group_range_excl.lo group_range_incl.lo group_rank.lo group_size.lo group_translate_ranks.lo group_union.lo grouputil.lo
date > .libstamp1
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group/group_compare.c -o _group_compare.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group/group_difference.c -o _group_difference.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group/group_excl.c -o _group_excl.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group/group_free.c -o _group_free.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group/group_incl.c -o _group_incl.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group/group_intersection.c -o _group_intersection.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group/group_range_excl.c -o _group_range_excl.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group/group_range_incl.c -o _group_range_incl.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group/group_rank.c -o _group_rank.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group/group_size.c -o _group_size.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group/group_translate_ranks.c -o _group_translate_ranks.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/group/group_union.c -o _group_union.lo
ar cr ../../../lib/libmpich.la _group_compare.lo _group_difference.lo _group_excl.lo _group_free.lo _group_incl.lo _group_intersection.lo _group_range_excl.lo _group_range_incl.lo _group_rank.lo _group_size.lo _group_translate_ranks.lo _group_union.lo
date > .libstamp3
make[3]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/group'
make[3]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/init'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init/abort.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init/init.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init/initialized.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init/initthread.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init/ismain.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init/finalize.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init/finalized.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init/querythread.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init/initinfo.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init/async.c
ar cr ../../../lib/libmpich.a abort.o init.o initialized.o initthread.o ismain.o finalize.o finalized.o querythread.o initinfo.o async.o
ranlib ../../../lib/libmpich.a
date > .libstamp0
make[4]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/init'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init/abort.c -o _abort.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init/init.c -o _init.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init/initialized.c -o _initialized.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init/initthread.c -o _initthread.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init/ismain.c -o _ismain.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init/finalize.c -o _finalize.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init/finalized.c -o _finalized.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init/querythread.c -o _querythread.o
ar cr ../../../lib/libmpich.a _abort.o _init.o _initialized.o _initthread.o _ismain.o _finalize.o _finalized.o _querythread.o
date > .libstamp2
make[4]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/init'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init/abort.c -o _sabort.o
mv -f _sabort.o abort.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init/init.c -o _sinit.o
mv -f _sinit.o init.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init/initialized.c -o _sinitialized.o
mv -f _sinitialized.o initialized.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init/initthread.c -o _sinitthread.o
mv -f _sinitthread.o initthread.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init/ismain.c -o _sismain.o
mv -f _sismain.o ismain.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init/finalize.c -o _sfinalize.o
mv -f _sfinalize.o finalize.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init/finalized.c -o _sfinalized.o
mv -f _sfinalized.o finalized.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init/querythread.c -o _squerythread.o
mv -f _squerythread.o querythread.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init/initinfo.c -o _sinitinfo.o
mv -f _sinitinfo.o initinfo.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init/async.c -o _sasync.o
mv -f _sasync.o async.lo
ar cr ../../../lib/libmpich.la abort.lo init.lo initialized.lo initthread.lo ismain.lo finalize.lo finalized.lo querythread.lo initinfo.lo async.lo
date > .libstamp1
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init/abort.c -o _abort.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init/init.c -o _init.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init/initialized.c -o _initialized.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init/initthread.c -o _initthread.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init/ismain.c -o _ismain.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init/finalize.c -o _finalize.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init/finalized.c -o _finalized.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/init/querythread.c -o _querythread.lo
ar cr ../../../lib/libmpich.la _abort.lo _init.lo _initialized.lo _initthread.lo _ismain.lo _finalize.lo _finalized.lo _querythread.lo
date > .libstamp3
make[3]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/init'
make[3]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/misc'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/misc -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/misc/getpname.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/misc -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/misc/pcontrol.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/misc -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/misc/version.c
ar cr ../../../lib/libmpich.a getpname.o pcontrol.o version.o
date > .libstamp0
make[4]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/misc'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/misc -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/misc/getpname.c -o _getpname.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/misc -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/misc/pcontrol.c -o _pcontrol.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/misc -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/misc/version.c -o _version.o
ar cr ../../../lib/libmpich.a _getpname.o _pcontrol.o _version.o
date > .libstamp2
make[4]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/misc'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/misc -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/misc/getpname.c -o _sgetpname.o
mv -f _sgetpname.o getpname.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/misc -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/misc/pcontrol.c -o _spcontrol.o
mv -f _spcontrol.o pcontrol.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/misc -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/misc/version.c -o _sversion.o
mv -f _sversion.o version.lo
ar cr ../../../lib/libmpich.la getpname.lo pcontrol.lo version.lo
date > .libstamp1
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/misc -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/misc/getpname.c -o _getpname.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/misc -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/misc/pcontrol.c -o _pcontrol.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/misc -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/misc/version.c -o _version.lo
ar cr ../../../lib/libmpich.la _getpname.lo _pcontrol.lo _version.lo
date > .libstamp3
make[3]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/misc'
make[3]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/pt2pt'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/bsend.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/bsend_init.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/bufattach.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/buffree.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/cancel.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/greq_start.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/greq_complete.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/ibsend.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/iprobe.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/irecv.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/irsend.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/isend.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/issend.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/probe.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/recv.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/recv_init.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/request_free.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/request_get_status.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/rsend.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/rsend_init.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/send.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/send_init.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/sendrecv.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/sendrecv_rep.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/status_set_cancelled.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/ssend.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/ssend_init.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/start.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/startall.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/test.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/test_cancelled.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/testall.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/testany.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/testsome.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/wait.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/waitall.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/waitany.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/waitsome.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/bsendutil.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/mpir_request.c
ar cr ../../../lib/libmpich.a bsend.o bsend_init.o bufattach.o buffree.o cancel.o greq_start.o greq_complete.o ibsend.o iprobe.o irecv.o irsend.o isend.o issend.o probe.o recv.o recv_init.o request_free.o request_get_status.o rsend.o rsend_init.o send.o send_init.o sendrecv.o sendrecv_rep.o status_set_cancelled.o ssend.o ssend_init.o start.o startall.o test.o test_cancelled.o testall.o testany.o testsome.o wait.o waitall.o waitany.o waitsome.o bsendutil.o mpir_request.o
ranlib ../../../lib/libmpich.a
date > .libstamp0
make[4]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/pt2pt'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/bsend.c -o _bsend.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/bsend_init.c -o _bsend_init.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/bufattach.c -o _bufattach.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/buffree.c -o _buffree.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/cancel.c -o _cancel.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/greq_start.c -o _greq_start.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/greq_complete.c -o _greq_complete.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/ibsend.c -o _ibsend.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/iprobe.c -o _iprobe.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/irecv.c -o _irecv.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/irsend.c -o _irsend.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/isend.c -o _isend.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/issend.c -o _issend.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/probe.c -o _probe.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/recv.c -o _recv.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/recv_init.c -o _recv_init.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/request_free.c -o _request_free.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/request_get_status.c -o _request_get_status.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/rsend.c -o _rsend.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/rsend_init.c -o _rsend_init.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/send.c -o _send.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/send_init.c -o _send_init.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/sendrecv.c -o _sendrecv.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/sendrecv_rep.c -o _sendrecv_rep.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/status_set_cancelled.c -o _status_set_cancelled.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/ssend.c -o _ssend.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/ssend_init.c -o _ssend_init.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/start.c -o _start.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/startall.c -o _startall.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/test.c -o _test.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/test_cancelled.c -o _test_cancelled.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/testall.c -o _testall.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/testany.c -o _testany.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/testsome.c -o _testsome.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/wait.c -o _wait.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/waitall.c -o _waitall.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/waitany.c -o _waitany.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/waitsome.c -o _waitsome.o
ar cr ../../../lib/libmpich.a _bsend.o _bsend_init.o _bufattach.o _buffree.o _cancel.o _greq_start.o _greq_complete.o _ibsend.o _iprobe.o _irecv.o _irsend.o _isend.o _issend.o _probe.o _recv.o _recv_init.o _request_free.o _request_get_status.o _rsend.o _rsend_init.o _send.o _send_init.o _sendrecv.o _sendrecv_rep.o _status_set_cancelled.o _ssend.o _ssend_init.o _start.o _startall.o _test.o _test_cancelled.o _testall.o _testany.o _testsome.o _wait.o _waitall.o _waitany.o _waitsome.o
date > .libstamp2
make[4]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/pt2pt'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/bsend.c -o _sbsend.o
mv -f _sbsend.o bsend.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/bsend_init.c -o _sbsend_init.o
mv -f _sbsend_init.o bsend_init.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/bufattach.c -o _sbufattach.o
mv -f _sbufattach.o bufattach.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/buffree.c -o _sbuffree.o
mv -f _sbuffree.o buffree.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/cancel.c -o _scancel.o
mv -f _scancel.o cancel.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/greq_start.c -o _sgreq_start.o
mv -f _sgreq_start.o greq_start.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/greq_complete.c -o _sgreq_complete.o
mv -f _sgreq_complete.o greq_complete.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/ibsend.c -o _sibsend.o
mv -f _sibsend.o ibsend.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/iprobe.c -o _siprobe.o
mv -f _siprobe.o iprobe.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/irecv.c -o _sirecv.o
mv -f _sirecv.o irecv.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/irsend.c -o _sirsend.o
mv -f _sirsend.o irsend.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/isend.c -o _sisend.o
mv -f _sisend.o isend.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/issend.c -o _sissend.o
mv -f _sissend.o issend.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/probe.c -o _sprobe.o
mv -f _sprobe.o probe.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/recv.c -o _srecv.o
mv -f _srecv.o recv.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/recv_init.c -o _srecv_init.o
mv -f _srecv_init.o recv_init.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/request_free.c -o _srequest_free.o
mv -f _srequest_free.o request_free.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/request_get_status.c -o _srequest_get_status.o
mv -f _srequest_get_status.o request_get_status.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/rsend.c -o _srsend.o
mv -f _srsend.o rsend.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/rsend_init.c -o _srsend_init.o
mv -f _srsend_init.o rsend_init.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/send.c -o _ssend.o
mv -f _ssend.o send.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/send_init.c -o _ssend_init.o
mv -f _ssend_init.o send_init.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/sendrecv.c -o _ssendrecv.o
mv -f _ssendrecv.o sendrecv.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/sendrecv_rep.c -o _ssendrecv_rep.o
mv -f _ssendrecv_rep.o sendrecv_rep.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/status_set_cancelled.c -o _sstatus_set_cancelled.o
mv -f _sstatus_set_cancelled.o status_set_cancelled.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/ssend.c -o _sssend.o
mv -f _sssend.o ssend.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/ssend_init.c -o _sssend_init.o
mv -f _sssend_init.o ssend_init.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/start.c -o _sstart.o
mv -f _sstart.o start.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/startall.c -o _sstartall.o
mv -f _sstartall.o startall.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/test.c -o _stest.o
mv -f _stest.o test.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/test_cancelled.c -o _stest_cancelled.o
mv -f _stest_cancelled.o test_cancelled.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/testall.c -o _stestall.o
mv -f _stestall.o testall.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/testany.c -o _stestany.o
mv -f _stestany.o testany.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/testsome.c -o _stestsome.o
mv -f _stestsome.o testsome.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/wait.c -o _swait.o
mv -f _swait.o wait.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/waitall.c -o _swaitall.o
mv -f _swaitall.o waitall.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/waitany.c -o _swaitany.o
mv -f _swaitany.o waitany.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/waitsome.c -o _swaitsome.o
mv -f _swaitsome.o waitsome.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/bsendutil.c -o _sbsendutil.o
mv -f _sbsendutil.o bsendutil.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/mpir_request.c -o _smpir_request.o
mv -f _smpir_request.o mpir_request.lo
ar cr ../../../lib/libmpich.la bsend.lo bsend_init.lo bufattach.lo buffree.lo cancel.lo greq_start.lo greq_complete.lo ibsend.lo iprobe.lo irecv.lo irsend.lo isend.lo issend.lo probe.lo recv.lo recv_init.lo request_free.lo request_get_status.lo rsend.lo rsend_init.lo send.lo send_init.lo sendrecv.lo sendrecv_rep.lo status_set_cancelled.lo ssend.lo ssend_init.lo start.lo startall.lo test.lo test_cancelled.lo testall.lo testany.lo testsome.lo wait.lo waitall.lo waitany.lo waitsome.lo bsendutil.lo mpir_request.lo
date > .libstamp1
make[4]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/pt2pt'
make[4]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/pt2pt'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/bsend.c -o _bsend.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/bsend_init.c -o _bsend_init.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/bufattach.c -o _bufattach.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/buffree.c -o _buffree.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/cancel.c -o _cancel.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/greq_start.c -o _greq_start.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/greq_complete.c -o _greq_complete.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/ibsend.c -o _ibsend.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/iprobe.c -o _iprobe.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/irecv.c -o _irecv.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/irsend.c -o _irsend.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/isend.c -o _isend.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/issend.c -o _issend.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/probe.c -o _probe.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/recv.c -o _recv.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/recv_init.c -o _recv_init.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/request_free.c -o _request_free.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/request_get_status.c -o _request_get_status.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/rsend.c -o _rsend.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/rsend_init.c -o _rsend_init.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/send.c -o _send.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/send_init.c -o _send_init.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/sendrecv.c -o _sendrecv.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/sendrecv_rep.c -o _sendrecv_rep.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/status_set_cancelled.c -o _status_set_cancelled.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/ssend.c -o _ssend.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/ssend_init.c -o _ssend_init.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/start.c -o _start.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/startall.c -o _startall.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/test.c -o _test.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/test_cancelled.c -o _test_cancelled.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/testall.c -o _testall.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/testany.c -o _testany.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/testsome.c -o _testsome.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/wait.c -o _wait.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/waitall.c -o _waitall.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/waitany.c -o _waitany.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/pt2pt/waitsome.c -o _waitsome.lo
ar cr ../../../lib/libmpich.la _bsend.lo _bsend_init.lo _bufattach.lo _buffree.lo _cancel.lo _greq_start.lo _greq_complete.lo _ibsend.lo _iprobe.lo _irecv.lo _irsend.lo _isend.lo _issend.lo _probe.lo _recv.lo _recv_init.lo _request_free.lo _request_get_status.lo _rsend.lo _rsend_init.lo _send.lo _send_init.lo _sendrecv.lo _sendrecv_rep.lo _status_set_cancelled.lo _ssend.lo _ssend_init.lo _start.lo _startall.lo _test.lo _test_cancelled.lo _testall.lo _testany.lo _testsome.lo _wait.lo _waitall.lo _waitany.lo _waitsome.lo
date > .libstamp3
make[3]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/pt2pt'
make[3]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/rma'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/accumulate.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/alloc_mem.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/free_mem.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/get.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/put.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/win_complete.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/win_create.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/win_fence.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/win_free.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/win_get_group.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/win_get_name.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/win_lock.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/win_post.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/win_set_name.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/win_start.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/win_unlock.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/win_wait.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/win_test.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/winutil.c
ar cr ../../../lib/libmpich.a accumulate.o alloc_mem.o free_mem.o get.o put.o win_complete.o win_create.o win_fence.o win_free.o win_get_group.o win_get_name.o win_lock.o win_post.o win_set_name.o win_start.o win_unlock.o win_wait.o win_test.o winutil.o
ranlib ../../../lib/libmpich.a
date > .libstamp0
make[4]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/rma'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/accumulate.c -o _accumulate.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/alloc_mem.c -o _alloc_mem.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/free_mem.c -o _free_mem.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/get.c -o _get.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/put.c -o _put.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/win_complete.c -o _win_complete.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/win_create.c -o _win_create.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/win_fence.c -o _win_fence.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/win_free.c -o _win_free.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/win_get_group.c -o _win_get_group.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/win_get_name.c -o _win_get_name.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/win_lock.c -o _win_lock.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/win_post.c -o _win_post.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/win_set_name.c -o _win_set_name.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/win_start.c -o _win_start.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/win_unlock.c -o _win_unlock.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/win_wait.c -o _win_wait.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/win_test.c -o _win_test.o
ar cr ../../../lib/libmpich.a _accumulate.o _alloc_mem.o _free_mem.o _get.o _put.o _win_complete.o _win_create.o _win_fence.o _win_free.o _win_get_group.o _win_get_name.o _win_lock.o _win_post.o _win_set_name.o _win_start.o _win_unlock.o _win_wait.o _win_test.o
date > .libstamp2
make[4]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/rma'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/accumulate.c -o _saccumulate.o
mv -f _saccumulate.o accumulate.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/alloc_mem.c -o _salloc_mem.o
mv -f _salloc_mem.o alloc_mem.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/free_mem.c -o _sfree_mem.o
mv -f _sfree_mem.o free_mem.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/get.c -o _sget.o
mv -f _sget.o get.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/put.c -o _sput.o
mv -f _sput.o put.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/win_complete.c -o _swin_complete.o
mv -f _swin_complete.o win_complete.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/win_create.c -o _swin_create.o
mv -f _swin_create.o win_create.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/win_fence.c -o _swin_fence.o
mv -f _swin_fence.o win_fence.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/win_free.c -o _swin_free.o
mv -f _swin_free.o win_free.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/win_get_group.c -o _swin_get_group.o
mv -f _swin_get_group.o win_get_group.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/win_get_name.c -o _swin_get_name.o
mv -f _swin_get_name.o win_get_name.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/win_lock.c -o _swin_lock.o
mv -f _swin_lock.o win_lock.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/win_post.c -o _swin_post.o
mv -f _swin_post.o win_post.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/win_set_name.c -o _swin_set_name.o
mv -f _swin_set_name.o win_set_name.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/win_start.c -o _swin_start.o
mv -f _swin_start.o win_start.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/win_unlock.c -o _swin_unlock.o
mv -f _swin_unlock.o win_unlock.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/win_wait.c -o _swin_wait.o
mv -f _swin_wait.o win_wait.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/win_test.c -o _swin_test.o
mv -f _swin_test.o win_test.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/winutil.c -o _swinutil.o
mv -f _swinutil.o winutil.lo
ar cr ../../../lib/libmpich.la accumulate.lo alloc_mem.lo free_mem.lo get.lo put.lo win_complete.lo win_create.lo win_fence.lo win_free.lo win_get_group.lo win_get_name.lo win_lock.lo win_post.lo win_set_name.lo win_start.lo win_unlock.lo win_wait.lo win_test.lo winutil.lo
date > .libstamp1
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/accumulate.c -o _accumulate.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/alloc_mem.c -o _alloc_mem.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/free_mem.c -o _free_mem.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/get.c -o _get.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/put.c -o _put.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/win_complete.c -o _win_complete.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/win_create.c -o _win_create.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/win_fence.c -o _win_fence.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/win_free.c -o _win_free.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/win_get_group.c -o _win_get_group.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/win_get_name.c -o _win_get_name.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/win_lock.c -o _win_lock.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/win_post.c -o _win_post.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/win_set_name.c -o _win_set_name.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/win_start.c -o _win_start.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/win_unlock.c -o _win_unlock.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/win_wait.c -o _win_wait.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/rma/win_test.c -o _win_test.lo
ar cr ../../../lib/libmpich.la _accumulate.lo _alloc_mem.lo _free_mem.lo _get.lo _put.lo _win_complete.lo _win_create.lo _win_fence.lo _win_free.lo _win_get_group.lo _win_get_name.lo _win_lock.lo _win_post.lo _win_set_name.lo _win_start.lo _win_unlock.lo _win_wait.lo _win_test.lo
date > .libstamp3
make[3]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/rma'
make[3]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/spawn'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn/comm_disconnect.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn/comm_get_parent.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn/comm_join.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn/comm_spawn.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn/comm_spawn_multiple.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn/lookup_name.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn/publish_name.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn/unpublish_name.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn/open_port.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn/close_port.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn/comm_connect.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn/comm_accept.c
ar cr ../../../lib/libmpich.a comm_disconnect.o comm_get_parent.o comm_join.o comm_spawn.o comm_spawn_multiple.o lookup_name.o publish_name.o unpublish_name.o open_port.o close_port.o comm_connect.o comm_accept.o
ranlib ../../../lib/libmpich.a
date > .libstamp0
make[4]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/spawn'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn/comm_disconnect.c -o _comm_disconnect.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn/comm_get_parent.c -o _comm_get_parent.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn/comm_join.c -o _comm_join.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn/comm_spawn.c -o _comm_spawn.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn/comm_spawn_multiple.c -o _comm_spawn_multiple.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn/lookup_name.c -o _lookup_name.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn/publish_name.c -o _publish_name.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn/unpublish_name.c -o _unpublish_name.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn/open_port.c -o _open_port.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn/close_port.c -o _close_port.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn/comm_connect.c -o _comm_connect.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn/comm_accept.c -o _comm_accept.o
ar cr ../../../lib/libmpich.a _comm_disconnect.o _comm_get_parent.o _comm_join.o _comm_spawn.o _comm_spawn_multiple.o _lookup_name.o _publish_name.o _unpublish_name.o _open_port.o _close_port.o _comm_connect.o _comm_accept.o
date > .libstamp2
make[4]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/spawn'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn/comm_disconnect.c -o _scomm_disconnect.o
mv -f _scomm_disconnect.o comm_disconnect.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn/comm_get_parent.c -o _scomm_get_parent.o
mv -f _scomm_get_parent.o comm_get_parent.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn/comm_join.c -o _scomm_join.o
mv -f _scomm_join.o comm_join.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn/comm_spawn.c -o _scomm_spawn.o
mv -f _scomm_spawn.o comm_spawn.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn/comm_spawn_multiple.c -o _scomm_spawn_multiple.o
mv -f _scomm_spawn_multiple.o comm_spawn_multiple.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn/lookup_name.c -o _slookup_name.o
mv -f _slookup_name.o lookup_name.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn/publish_name.c -o _spublish_name.o
mv -f _spublish_name.o publish_name.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn/unpublish_name.c -o _sunpublish_name.o
mv -f _sunpublish_name.o unpublish_name.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn/open_port.c -o _sopen_port.o
mv -f _sopen_port.o open_port.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn/close_port.c -o _sclose_port.o
mv -f _sclose_port.o close_port.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn/comm_connect.c -o _scomm_connect.o
mv -f _scomm_connect.o comm_connect.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn/comm_accept.c -o _scomm_accept.o
mv -f _scomm_accept.o comm_accept.lo
ar cr ../../../lib/libmpich.la comm_disconnect.lo comm_get_parent.lo comm_join.lo comm_spawn.lo comm_spawn_multiple.lo lookup_name.lo publish_name.lo unpublish_name.lo open_port.lo close_port.lo comm_connect.lo comm_accept.lo
date > .libstamp1
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn/comm_disconnect.c -o _comm_disconnect.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn/comm_get_parent.c -o _comm_get_parent.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn/comm_join.c -o _comm_join.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn/comm_spawn.c -o _comm_spawn.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn/comm_spawn_multiple.c -o _comm_spawn_multiple.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn/lookup_name.c -o _lookup_name.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn/publish_name.c -o _publish_name.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn/unpublish_name.c -o _unpublish_name.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn/open_port.c -o _open_port.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn/close_port.c -o _close_port.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn/comm_connect.c -o _comm_connect.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/spawn/comm_accept.c -o _comm_accept.lo
ar cr ../../../lib/libmpich.la _comm_disconnect.lo _comm_get_parent.lo _comm_join.lo _comm_spawn.lo _comm_spawn_multiple.lo _lookup_name.lo _publish_name.lo _unpublish_name.lo _open_port.lo _close_port.lo _comm_connect.lo _comm_accept.lo
date > .libstamp3
make[3]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/spawn'
make[3]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/timer'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/timer -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/timer/wtime.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/timer -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/timer/wtick.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/timer -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/timer/mpidtime.c
ar cr ../../../lib/libmpich.a wtime.o wtick.o mpidtime.o
ranlib ../../../lib/libmpich.a
date > .libstamp0
make[4]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/timer'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/timer -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/timer/wtime.c -o _wtime.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/timer -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/timer/wtick.c -o _wtick.o
ar cr ../../../lib/libmpich.a _wtime.o _wtick.o
date > .libstamp2
make[4]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/timer'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/timer -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/timer/wtime.c -o _swtime.o
mv -f _swtime.o wtime.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/timer -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/timer/wtick.c -o _swtick.o
mv -f _swtick.o wtick.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/timer -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/timer/mpidtime.c -o _smpidtime.o
mv -f _smpidtime.o mpidtime.lo
ar cr ../../../lib/libmpich.la wtime.lo wtick.lo mpidtime.lo
date > .libstamp1
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/timer -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/timer/wtime.c -o _wtime.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/timer -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/timer/wtick.c -o _wtick.lo
ar cr ../../../lib/libmpich.la _wtime.lo _wtick.lo
date > .libstamp3
make[3]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/timer'
make[3]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/topo'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/cart_coords.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/cart_create.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/cart_get.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/cart_map.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/cart_rank.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/cart_shift.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/cart_sub.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/dims_create.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/graph_get.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/graph_map.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/graph_nbr.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/graphcreate.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/graphdimsget.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/graphnbrcnt.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/cartdim_get.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/topo_test.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/dist_gr_create_adj.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/dist_gr_create.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/dist_gr_neighb_count.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/dist_gr_neighb.c
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/topoutil.c
ar cr ../../../lib/libmpich.a cart_coords.o cart_create.o cart_get.o cart_map.o cart_rank.o cart_shift.o cart_sub.o dims_create.o graph_get.o graph_map.o graph_nbr.o graphcreate.o graphdimsget.o graphnbrcnt.o cartdim_get.o topo_test.o dist_gr_create_adj.o dist_gr_create.o dist_gr_neighb_count.o dist_gr_neighb.o topoutil.o
date > .libstamp0
make[4]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/topo'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/cart_coords.c -o _cart_coords.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/cart_create.c -o _cart_create.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/cart_get.c -o _cart_get.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/cart_map.c -o _cart_map.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/cart_rank.c -o _cart_rank.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/cart_shift.c -o _cart_shift.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/cart_sub.c -o _cart_sub.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/dims_create.c -o _dims_create.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/graph_get.c -o _graph_get.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/graph_map.c -o _graph_map.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/graph_nbr.c -o _graph_nbr.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/graphcreate.c -o _graphcreate.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/graphdimsget.c -o _graphdimsget.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/graphnbrcnt.c -o _graphnbrcnt.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/cartdim_get.c -o _cartdim_get.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/topo_test.c -o _topo_test.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/dist_gr_create_adj.c -o _dist_gr_create_adj.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/dist_gr_create.c -o _dist_gr_create.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/dist_gr_neighb_count.c -o _dist_gr_neighb_count.o
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/dist_gr_neighb.c -o _dist_gr_neighb.o
ar cr ../../../lib/libmpich.a _cart_coords.o _cart_create.o _cart_get.o _cart_map.o _cart_rank.o _cart_shift.o _cart_sub.o _dims_create.o _graph_get.o _graph_map.o _graph_nbr.o _graphcreate.o _graphdimsget.o _graphnbrcnt.o _cartdim_get.o _topo_test.o _dist_gr_create_adj.o _dist_gr_create.o _dist_gr_neighb_count.o _dist_gr_neighb.o
ranlib ../../../lib/libmpich.a
date > .libstamp2
make[4]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/topo'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/cart_coords.c -o _scart_coords.o
mv -f _scart_coords.o cart_coords.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/cart_create.c -o _scart_create.o
mv -f _scart_create.o cart_create.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/cart_get.c -o _scart_get.o
mv -f _scart_get.o cart_get.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/cart_map.c -o _scart_map.o
mv -f _scart_map.o cart_map.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/cart_rank.c -o _scart_rank.o
mv -f _scart_rank.o cart_rank.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/cart_shift.c -o _scart_shift.o
mv -f _scart_shift.o cart_shift.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/cart_sub.c -o _scart_sub.o
mv -f _scart_sub.o cart_sub.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/dims_create.c -o _sdims_create.o
mv -f _sdims_create.o dims_create.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/graph_get.c -o _sgraph_get.o
mv -f _sgraph_get.o graph_get.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/graph_map.c -o _sgraph_map.o
mv -f _sgraph_map.o graph_map.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/graph_nbr.c -o _sgraph_nbr.o
mv -f _sgraph_nbr.o graph_nbr.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/graphcreate.c -o _sgraphcreate.o
mv -f _sgraphcreate.o graphcreate.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/graphdimsget.c -o _sgraphdimsget.o
mv -f _sgraphdimsget.o graphdimsget.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/graphnbrcnt.c -o _sgraphnbrcnt.o
mv -f _sgraphnbrcnt.o graphnbrcnt.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/cartdim_get.c -o _scartdim_get.o
mv -f _scartdim_get.o cartdim_get.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/topo_test.c -o _stopo_test.o
mv -f _stopo_test.o topo_test.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/dist_gr_create_adj.c -o _sdist_gr_create_adj.o
mv -f _sdist_gr_create_adj.o dist_gr_create_adj.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/dist_gr_create.c -o _sdist_gr_create.o
mv -f _sdist_gr_create.o dist_gr_create.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/dist_gr_neighb_count.c -o _sdist_gr_neighb_count.o
mv -f _sdist_gr_neighb_count.o dist_gr_neighb_count.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/dist_gr_neighb.c -o _sdist_gr_neighb.o
mv -f _sdist_gr_neighb.o dist_gr_neighb.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/topoutil.c -o _stopoutil.o
mv -f _stopoutil.o topoutil.lo
ar cr ../../../lib/libmpich.la cart_coords.lo cart_create.lo cart_get.lo cart_map.lo cart_rank.lo cart_shift.lo cart_sub.lo dims_create.lo graph_get.lo graph_map.lo graph_nbr.lo graphcreate.lo graphdimsget.lo graphnbrcnt.lo cartdim_get.lo topo_test.lo dist_gr_create_adj.lo dist_gr_create.lo dist_gr_neighb_count.lo dist_gr_neighb.lo topoutil.lo
date > .libstamp1
make[4]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/topo'
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/cart_coords.c -o _cart_coords.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/cart_create.c -o _cart_create.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/cart_get.c -o _cart_get.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/cart_map.c -o _cart_map.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/cart_rank.c -o _cart_rank.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/cart_shift.c -o _cart_shift.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/cart_sub.c -o _cart_sub.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/dims_create.c -o _dims_create.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/graph_get.c -o _graph_get.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/graph_map.c -o _graph_map.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/graph_nbr.c -o _graph_nbr.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/graphcreate.c -o _graphcreate.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/graphdimsget.c -o _graphdimsget.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/graphnbrcnt.c -o _graphnbrcnt.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/cartdim_get.c -o _cartdim_get.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/topo_test.c -o _topo_test.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/dist_gr_create_adj.c -o _dist_gr_create_adj.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/dist_gr_create.c -o _dist_gr_create.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/dist_gr_neighb_count.c -o _dist_gr_neighb_count.lo
gcc -DHAVE_CONFIG_H -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo -I../../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/include -O2 -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c -DMPICH_MPI_FROM_PMPI /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/topo/dist_gr_neighb.c -o _dist_gr_neighb.lo
ar cr ../../../lib/libmpich.la _cart_coords.lo _cart_create.lo _cart_get.lo _cart_map.lo _cart_rank.lo _cart_shift.lo _cart_sub.lo _dims_create.lo _graph_get.lo _graph_map.lo _graph_nbr.lo _graphcreate.lo _graphdimsget.lo _graphnbrcnt.lo _cartdim_get.lo _topo_test.lo _dist_gr_create_adj.lo _dist_gr_create.lo _dist_gr_neighb_count.lo _dist_gr_neighb.lo
date > .libstamp3
make[4]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/topo'
make[3]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/topo'
make[3]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/romio'
make mpiolib
make[4]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/romio'
compiling ROMIO in directory mpi-io
make[5]: Entering directory `/tmp/sgthomas/mpich2-1.3.2p1/src/mpi/romio/mpi-io'
gcc -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -DHAVE_ROMIOCONF_H -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/romio/mpi-io/close.c
gcc -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -DHAVE_ROMIOCONF_H -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/romio/mpi-io/read.c
gcc -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -DHAVE_ROMIOCONF_H -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/romio/mpi-io/open.c
gcc -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -DHAVE_ROMIOCONF_H -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/romio/mpi-io/write.c
gcc -I. -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/romio/mpi-io -I../include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/romio/mpi-io/../adio/include -I../adio/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/romio/mpi-io/../../../include -I../../../include -O2 -DFORTRANUNDERSCORE -DHAVE_ROMIOCONF_H -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpl/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/openpa/src -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/datatype -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/datatype -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/common/locks -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/common/locks -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/include -I/tmp/sgthomas/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpid/ch3/channels/nemesis/nemesis/utils/monitor -I/tmp/sgthomas/mpich2-1.3.2p1/src/util/wrappers -I/cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/util/wrappers -c /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/mpi/romio/mpi-io/set_view.c
