[mpich-discuss] Possible setup problem
Andy_Holland at URSCorp.com Andy_Holland at URSCorp.com
Mon Apr 25 14:00:38 CDT 2011
I've attached the log for running cpi using the same machinefile.
Thank you,
Andy Holland
Air Quality Modeler
URS Corporation
1600 Perimeter Park Drive
Suite 400
Morrisville, NC 27560
Direct: (303) 796-4694
Cell: (919) 619-4218
Fax: (919) 461-1415
andy_holland at urscorp.com
This e-mail and any attachments contain URS Corporation confidential
information that may be proprietary or privileged. If you receive this
message in error or are not the intended recipient, you should not retain,
distribute, disclose or use any of this information and you should destroy
the e-mail and any attachments or copies.
Darius Buntinas <buntinas at mcs.anl.gov>
Sent by: mpich-discuss-bounces at mcs.anl.gov
04/25/2011 02:51 PM
Please respond to
mpich-discuss at mcs.anl.gov
To
cc
Subject
Re: [mpich-discuss] Possible setup problem
Hi Andy,
Can you try running cpi from the examples directory of the MPICH2 source
tree with the same number of processes and the same machine file?  Let us
know if that works, and, if not, send us the output, please.
-d
On Apr 25, 2011, at 1:30 PM, Andy_Holland at URSCorp.com wrote:
> It was suggested that I send out all the error messages.  I've attached
a log file from the model.
> Thank you,
> Andy Holland
> Air Quality Modeler
> URS Corporation
> Suite 400
> Fax: (919) 461-1415
> Dave Goodell <goodell at mcs.anl.gov>
> 04/25/2011 02:22 PM
> Please respond to
> To
> cc
> Subject
> On Apr 25, 2011, at 12:59 PM CDT, Andy_Holland at URSCorp.com wrote:
> > When I run from either machine using CPUs from both machines the run
stops with many mpi messages.  Below is the last message in the list:
> > main (/usr/local/mpich2-1.3.2p1/src/pm/hydra/ui/mpich/mpiexec.c:404):
process manager error waiting for completion
> Can you send us all of the error messages?  Typically the first error
messages are the most useful/relevant; the last ones often are just
messages announcing some sort of cleanup or secondary error caused by the
original error.
> -Dave
> mpich-discuss mailing list
> <run.cctm.parallel.txt>_______________________________________________
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110425/6f1918e0/attachment.htm>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110425/6f1918e0/attachment.txt>
