[mpich-discuss] MPICH2 on Windows 7
A BCD noniabcd at gmail.com
Fri Apr 22 18:50:44 CDT 2011
Thanks a lot Jayesh! I unistalled MPICH2 and reinstalled it from the command
line. I also ran wmpiregister from the command line (passed windows
domain\username and password) and ran mpixec from the command line too
(passed "behappy") at the command prompt but got the following error
message. Any pointers will be very helpful!
Best Regards,
Noni
C:\Program Files\MPICH2\bin>mpiexec.exe -n 1
C:\Dev-Cpp\Projects\FirstShot\First_Shot.exe
Please specify an authentication passphrase for smpd:
Unable to connect to 'AGR-2104-SMWLT:8676', sock error: generic socket
failure, error stack:
MPIDU_Sock_post_connect(1228): unable to connect to AGR-2104-SMWLT on port
8676,  exhausted all endpoints (errno -1)
MPIDU_Sock_post_connect(1275): unable to connect to AGR-2104-SMWLT on port
8676,  No connection could be made because the target machine actively
refused it. (er rno 10061)
On Fri, Apr 22, 2011 at 2:27 PM, Jayesh Krishna <jayesh at mcs.anl.gov> wrote:
> Hi,
>  You should register a valid Windows username and password with mpiexec
> (mpiexec -register OR wmpiregister) . The "behappy" passphrase should be
> specified during the installation process (by default it is specified for
> you).
>  This could be an issue with the MPICH2 installation on Windows 7. I would
> recommend following the instructions in Section 9.4 of the Installer's guide
> (available at
> http://www.mcs.anl.gov/research/projects/mpich2/documentation/index.php?s=docs-- don't follow instructions in Section 9.1) to install MPICH2.
>  Let us know if it works.
> Regards,
> Jayesh
> From: "A BCD" <noniabcd at gmail.com>
> To: jayesh at mcs.anl.gov
> Sent: Friday, April 22, 2011 12:27:32 PM
> Subject: MPICH2 on Windows 7
> Hi Jayesh,
> I got your email id while browsing through the following discussion list:
> http://lists.mcs.anl.gov/pipermail/mpich-discuss/2010-February/006529.html
> I am trying to run MPICH2 from the Windows 7 environment but I can't get
> the wmpiexec.exe working and get the following error message:
> Error: No smpd passphrase specified through the registry or .smpd file,
> exiting.
> I did the installation as per the instructions on the folowing link but I
> am not sure what info I should provide for account name and password when I
> run wmpiregister.exe. I tried several combinations of account name and
> password (admin account name from which I installed/my login account name
> and "behappy" password and the passwords associated with the account names.
> http://auriza.site40.net/notes/mpi/mpich2-on-windows-xp/
> Any pointers will be appreciated!
> Thanks & Regards!
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110422/e7263fd7/attachment.htm>
