[mpich-discuss] MPI_File_open() fails on local + NFS file system
Audet, Martin Martin.Audet at imi.cnrc-nrc.gc.ca
Thu Apr 21 16:20:47 CDT 2011
Hi MPICH_Developers,
We are unable to use MPI_File_open() on a cluster where the first node (master node) mount a local file system and export it via NFS to a few cluster nodes so that /home on both the master node and the compute node refers to the same directory.
When a job composed on one (or more) process on the master node and one (or more) process on a client node is started, MPI_File_open() to create a new file either make the program to abort (if the process of rank 0 is on the master node using the local file system) or to freeze (if the process of rank 0 is on a compute node acessing the file via NFS).
When the program freeze, an inspection with gdb shows that the process of rank 0 is stuck into a MPI_Bcast() called by MPI_File_open().
Note that this happens with many mpich2 versions from 1.0.7 to 1.4rc2.
So we would like to know if the configuration we use is local or not.
Martin Audet
