[mpich-discuss] MPICH2 Error
Jayesh Krishna jayesh at mcs.anl.gov
Mon Apr 18 12:56:25 CDT 2011
 This looks like a network connectivity issue between the machines. Can you ping one machine from the other ? If there are any firewalls running on any of the machines try after turning them off on both the machines.
Jayesh
----- Original Message -----
Sent: Monday, April 18, 2011 8:49:10 AM
Subject: [mpich-discuss] MPICH2 Error
I found a problem when i used mpich2 in windows. First, I use mpich2 to run a parallel program A. Then, program A will call another parallel program B using mpich2 too. However, program B will not be excuted which show a error code of 10061. Below are the error informations. Could you help me fix this problem? thank you Da Xingya
[01:5080]..ERROR:Connect on sock (host=PC2010070315tdx ::1 169.254.133.133 182.128.140.243 , port=2953) failed, exhaused all end points
SMPDU_Sock_post_connect failed.
[0] PMI_ConnectToHost failed: unable to post a connect to PC2010070315tdx ::1 169.254.133.133 182.128.140.243 :2953, error: Undefined dynamic error code
uPMI_ConnectToHost returning PMI_FAIL
[0] PMI_Init failed.
Fatal error in MPI_Init: Other MPI error, error stack:
MPIR_Init_thread(394): Initialization failed
MPID_Init(103).......: channel initialization failed
MPID_Init(374).......: PMI_Init returned -1
体验网易邮箱2G超大附件,轻松发优质大电影、大照片,提速3倍!
mpich-discuss mailing list
